My monitor keeps turning off if i press the power button around 50 times it sumtimes stays on
  • 20 Answers
I have had the same problem with some of the monitors in my offices. Usually if I unplug the power cord for about 10 seconds and plug it back it it seems to reset it and it doesn't do it for a while. But it is usually a good sign that it has seen its days.
Hope this helps.
Posted on Apr 24, 2009
Samsung startup problem
serial number on 6.17.8.1
Sep 21, 2013 | Televison & Video
I followed the instruction to install the new lamp and the power light green keep flashing when turn on then turn red. After that lamp light starting flashing every 5 second. Did you know what's the...
You have to reset the lamp timer. Turn the power back on. While pressing the VOL button on the projection display, hold down the PIP button on the remote control simultaneously for more than 5 seconds. The screen should show something that says "LAMP TIME WAS RESET TO 0. The lamp indicator should go out.
Mar 04, 2010 | Panasonic PT-50LC13 50" Rear Projection...
HP Pavilion MD5020N 50 in. HDTV DLP TV keeps shutting down
ok this is what you do folks.... un-plug the tv from the power supply. once that is done hold the power button down on the side of the television for 30 seconds. this will release all electricity out of the tv.... then before you plug it back in hold the channel down vol up button along with the power button at the side on the tv this should reset the tv and it will start up automatically on video one. Select your source and scan for your cable channels again. If the problem is not solved then contact someone to come and clean the filter for the tv because it may be clogged along with this it can be the color wheel and may shut itself off like 3 times until it feels it is right.
Apr 08, 2009 | HP Pavilion MD5020N 50" DLP HDTV
Powers on to blue screen and nothing else
press the input button until it cycles through all of the inputs.
Feb 11, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Rca hdtv wont turn on
you need a new flyback and a CP150 Capacitor. If your chassis is the ITC222 you need flyback number 259296 you can get replacement flyback and the CP150 at the following link and they send detailed photo instructions so you can easially do the repair yourself.
http://servicemanuals.vstore.ca/
Jan 15, 2009 | RCA Televison & Video
Follow up questions
Normal sequence is the power led should blink 5 times then shutoff when power is pressed. If the led stays lit the DM is suspect. You will need to have the DM trouble shooted to determine whats preventing normal boot sequence from completeing. If you need further assistance. please let me know.
Your chassis is the ATC322
Jul 07, 2008 | RCA HD50LPW164 50" Rear Projection HDTV
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Will not turn on
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Oct 06, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Tv Powers up and immediately back off
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB
Aug 08, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Electro Med Services...
