Question about Lexmark X5150 All-In-One InkJet Printer
Lexmark x2356 all in one printer
When feeding paper, it only seems to "catch" the feeder on the right hand side - it then all goes lopsided and jams.
I had same problem. Check inside at lower alighnment rollers for any obstructions. Mine was a Sharpie marker wedged at rollers.
Posted on Jul 22, 2008
Lexmark 4650 paper wont feed when printing. It starts the feed process but does not catch the paper. when it does it will take several sheets.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 20, 2011 | Lexmark X4650 InkJet Printer
Hi, My Lexmark 2350 is not feeding paper through. It pulls on the right hand side but doesn't feed through and then says there's not paper in the tray. Any suggestions? Karla
Try to remove the sheets of paper from the feeder. Grab a flashlight and take a look into the feeder for any foreign objects that might have accidentally fallen into it. If none, unplug and replug your printer into your power source to reset it. If problem continues, please contact Lexmark technical support for additional assistance. Thanks.
Mar 06, 2011 | Lexmark X2350 All-In-One InkJet Printer
Lexmark x5435 paper feeder broken
Feeder goes halfway down & stops on Lexmark #5270 & would like free answer
Mar 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
"My Mom's 'Lexmark X75' Printer Does Not Load Paper to Printer".
Please follow these steps it may help you , ....Good luck..
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck
Feb 27, 2009 | Lexmark X75 All-In-One InkJet Printer
Paper not feeding on the left hand side of our lexmark 5100
open the backdoor and try to move the rollers in upward direction...if the roller on the left is hard to move then..replace the machine.
Nov 25, 2008 | Office Equipment & Supplies
Paper jams sideways and gets munched up - will not print
Check the paper path way , and also leds that directing paper.
hope that help you
thanks
Hamedo
Oct 25, 2008 | Dell 922 All-In-One InkJet Printer
LEXMARK 2470 PAPER FEEDER PROBLEM
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck....
Sep 13, 2008 | Office Equipment & Supplies
Paper jam
I had this problem the other day. I turned out that I had a small bit of polystyrene foam had got trapped just before the white plastic rollers you can see in front of the toner sponge where the cartridge head runs when you lift the lid to change ink.
I discovered it by noting that on power-up these rollers turn as if to feed paper back into the paper feeder (i.e. "backwards through the printer"), so I tried to see if I could get a sheet to feed backwards and noticed something was trying to stop the right-hand side of the paper feeding in. Soon after I noticed the bit of foam through the right-hand side slot in the white plastic section above the roller. A quick removal with small tweezers et viola!
Andy
Feb 10, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Paper wont feed propaly
Something probably fell into that tiny pinch of an area where the paper goes. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over, poke it if you have to, and shake it around til the little bugger falls out.
Sep 22, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
123 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
