Disk drives usually have two main plugs, one for power and the other is a multplug for system communication. power is small with only one connecter. the other multi connecters in the plug. they only fit one way in drives. Just match them up. Power/multi are linked in pairs so that you know which go to any one drive. there are at least two pairs in a desktop. if its a laptop only one pair and you have to take it apart to get at wiring. Desktop, just open case panel to access inside.
SOURCE: DVDs won't play on my hard drive
Your drive has had it then matey,
you can pick cheap ones up on ebay now, you can even go to ebuyer.co.uk and pic up a blu ray drive!
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
make sure
that your RAM and Cmos battery are securely seated
Test all leads that attach to your hard drive including
electrical extensions,IDE,SATA
the leads from your ((motherboard
to your hard drive)) make sure they have a secure connection and are not
faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and
to have and end to function
the beeps are
post pre operating system searching for some hardware it could be RAM cd/dvd
hard drive or motherboard all of these must have secure connections for the
computer to work
make
sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have
secure make sure the connections and are not faulty even the electrical
extensions or just replace them they could be faulty a computer needs all
electric current and computer data to travel to and through every working
device and have an end to work properly click start right click on my computer
so any faulty leads will end up with a computer error
hope
this helps
make sure that your RAM is securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function
obvisously the beeps are windows searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
