Question about Samsung Televison & Video
I recently had to disconnect all of my TV, DVD etc and do cannot find the manuals to connect it all. I have a Samsung HD TV, PVR, DVD, Video to connect and would like to know if you have a diagram I could use please? If I have to make do without one of these it would probably be the PVR as I our TV has freeview incorporated. Any advice would be much appreciated. Many thanks.
Thanks but no thanks for your offer of the premium service - I can buy the new manual for the same price so I will look for my manual and reject your assistance. Besides I can't be expected to pay for your solution yet give you my solution if I found it for free surely! Cheeky.
Posted on Jul 14, 2008
Want to write out keepsake HD titles from my Panasonic HW-220 onto Dual Layer BD-R(W) discs for my personal collection, and to free up space/slots on the unit...
The video in the PVR is not in DVD or Blu ray format. You'll need software to convert the video format on the PVR to DVD first. there are several converters that will do that. Google video to dvd converters.
Apr 02, 2015 | Panasonic Televison & Video
I have a Yamaha RX-V340RDS amplifier and need to know how to connect my tv, dvd recorder and hd-pvr
manual found here: http://www2.yamaha.co.jp/manual/pdf/av/english/re/RXV340.pdf
Mar 23, 2014 | Pioneer VSX-D608 Receiver
Connecting
did you check this out yet? (from the owners manual)
IMPORTANT NOTE: If the AVR's video output resolution
is set higher than the capabilities of the actual connection,
you will not see a picture. If the best available video connection
from the AVR to the TV is composite video, press this button
and change the resolution to 480i.
Oct 06, 2012 | Harman Kardon AVR 3600
I have an HD PVR (Explorer 8300) and have connected to my Samsung TV using HDMI cable. My question is can I connect my SONY STR DE605 receiver or do I need a new one?
Depending on your tv output, you shpuld be able to hook your TV to receiver via audio output. Running your video components through your receiver will not give you the best performance anyway. Run your HD DVR to TV the way you have it then, if it's possible to run audio out from TV, via, RCA, digital optical, etc., to your receiver. The sound will be transfered through the TV. You may also be able to utilize component out from your HD DVR and a separate audio cable.
May 22, 2011 | Sony STR-DE605 Receiver
How to access the usb port on a samsung le32b450
according to the user manual,the USB port is intended only for software upgrade, here are some of the supported inputs for your TV : VCR / DVD / Cable STB / Satellite STB / PVR STB / AV Receiver / Game / Camcorder / PC / DVI PC / DVI / TV / IPTV /
Blu- ray / HD DVD / DMA
Aug 29, 2009 | Samsung Televison & Video
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
May 07, 2008 | Televison & Video
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
Digital optical connection is creating any sound
Check to ensure the Home Theater is outputting the digital audio via the optical cable.
Nov 21, 2007 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
I am having problems hooking it up to an HD Receiver from Direct TV
playback and record are 2 different things. playback, you connect the DVD player audio-video OUT to the audio-video IN of the TV. recording, you connect the DVD player from the audio-video IN to the audio-video OUT of the source (i.e. cable box, set-top box, etc) hope this helps!
Oct 29, 2006 | Samsung DVDR120 DVD Recorder
Televison & Video Logo
44 people viewed this question
Henry  Thomas
Henry Thomas
