I have win xp with sp2 and installed software for iogear bluetooth 2.0 usb adapter. rebooted pc but even when i plug in the adapter the found new hardware wizard will not pop up. So i am unable to use the adapter at all since it keeps saying that i should insert bluetooth device, even after i do plug it in.
  • 3 Answers
Go to control panel and add hardware option if it dects the process should be fine from then on !
Posted on Jul 13, 2008
Bluetooth usb micro adapter not working
Check out http://www.sevenforums.com/hardware-devices/156598-bluetooth-initial-configuration-will-not-launch.html
finally I found a solution that worked
May 17, 2010 | IOGear Bluetooth 20 USB Micro Adapter...
Hi there... Iogear Bluetooth micro adapter 2.1 for USB port, software installed... After inserting the adapter, laptop freezes.
What is the operating system of your computer? Can you tell me the exact model number of your Bluetooth Adapter (it usually starts with GBU)?
Check the link below, and see the system requirements:
http://www.iogear.com/product/GBU421/
You need to check also the system type of your computer (32 or 64-bit OS). Some IOGEAR devices could only support 32-bit OS. If you are running 64-bit OS, that could cause the problem.
Try to uninstall the Bluetooth driver. Reboot the computer, then reload the installation disk that came with it. Once the hardware wizard ask you to plug the device it, just continue the installation, BUT DO NOT plug the device.
After the installation is done, reboot the computer again, the PLUG the device in WHILE the computer is shutting down. Once the computer comes back up, then it should install the other necessary driver. And that should work.
Apr 24, 2010 | IOGear (GBU211) Bluetooth Wireless Adapter
Can print from mac, cannot print from pc. have checked, both applications have correct printer selected
What is the operating system of your PC? Is this working before with your PC or is this the first time you are trying to install this Bluetotth Printer Kit?
If this is the first time, verify the OS of your PC. Because the USB Bluetooth adapter (GBU311) of this wireless printer server (GBP302KIT) could only support Win 98SE up to XP 32-bit (according to the system requirements).
But if this has worked before and then suddenly stopped working, try to uninstall/re-install the Bluetooth driver that's in your PC.
Everytime you are trying to detect the Bluetooth adapter that's on the printer, make sure that the Blue light is blinking (printer light).
If same problem occur, contact IOGEAR (866-946-4327). It's a free customer service support.
Thank you and good luck!
Apr 17, 2010 | IOGear (GBP302KIT) Print Server
I need a vista compatible driver for an IOgear gbu311 bluetooth wireless adapter
GBU311 does not have a Vista driver. Because it could only support the Win 2000, Win ME, 98SE, and XP. It does not support Win Vista and later versions.
If you wish to have a Bluetooth adapter that is compatible with Vista and Windows 7, you need to have the GBU421 Bluetooth 2.1 USB Micro Adapter. Here, check the link:
Sep 28, 2009 | IOGear GBU311 Bluetooth Wireless Adapter
Problem with installaion of WUSB54G Adaper. computer keeps reboot
Normally this means that its either an IRQ or basically conflicting with another device. or there is something wrong with your USB ports. Can you try antoher port on the computer?
Feb 06, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
No System Tray Blue Tooth Icon
The GBU321 installation software that comes with the CD was the problem. Called their tech service who made me uninstall the BlueTooth Drivers that the CD and Windows 2000 installed first, and then "directly" download and install the BROADCOM drivers. The adapter works very well now. Thanks.
Aug 30, 2008 | IOGear (GBU211) Bluetooth Wireless Adapter
Bluetooth iogear adapter
My Toshiba Laptop was setup to create automatic "System Restore Points"...I simply went back to the system restore point one day prior to installing the Iogear Bluetooth software: (my computer>accessories>toshiba tools>system restore).
I now have my Windows XP Welcome Screen back - -any changes or program installations I've made after the restore date will need to be reinstalled or reapplied, but I didn't have much on the laptop anyway, since I had just got it!
I would suggest backing up any files or data you may want to save before doing the system restore on any computer (maybe on a flashdrive or sd card, someplace other than the harddrive - then you can select what you want to install - excluding the culprit that caused you the problem). The system restore option will backup certain system files - notifying you of the new filenames after the restore has completed.
If the system restore process doesn't work, you do have the option of 'going back' to the last system settings, or trying another 'System Restore Point'.
If any desktop or laptop pc has a 'System Restore' option, I highly recommend turning this feature on....it may prevent a lot of headaches and problems!
One suggestion - BACKUP your system somewhere before making any major changes to your system...especially before installing new applications, or even before changing your system profiles or connectivity options...so many things can't easily be 'undone' !
Jun 22, 2008 | IOGear (GBU211) Bluetooth Wireless Adapter
What happened
1.
This may sound silly, but did you turn bluetooth ON in your phone and detect the adapter?
2.
I assume Windows here, so I would suggest you unplug it, uninstall the drivers, reboot, reinstall the drivers, then plug it back in. Don't plug the adapter into the usb port until the drivers are installed first.
Geno
Feb 09, 2008 | IOGear (GBU211) Bluetooth Wireless Adapter
3com usb bluetooth adaptor wont work at all
The Bluetooth adapter should be able to be used with Win XP's own drivers, try uninstalling the drivers that you got with the adapter and dis connect it. Re-connect your adapter back in and right click on an item you want to send via bluetooth and it will say 'send to bluetooth device'. Please note this will only work with Win XP SP2 not SP1
Nov 16, 2006 | 3Com AirConnect Wireless Adapter
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
