Question about Abit AW9D-MAX Motherboard
Sata raid config
I have sata 1-2-3-4 set up as raid and would like to install a HD DVD blue-ray drive but will not find same....tried in sata 5-6&7 but still won't work
How can I overcome this? have been told I have to get rid of my raid setup if this is so can I have 2 sata connetors as one drive and end up with 3 raid setups if this is so can you help me with this problem
Thanks
Jim Reilly
  • 721 Answers
First check your bios & see what raid chips are enabled,usually there's 2. Your main raid is on the first 4 sata connectors, the other chipset probably controlls the remaining sata ports. So if there's an option to disable one raid chip,disable one,just not the one that you're using. I don't know what your bios screen looks like,so this is just a general view based on my experences with various boards,mainly asus.
Posted on May 17, 2010
Tip
Problem Using Windows Install Disc with RAID? Some Tips:
After going through some issues installing Windows onto a RAID partition using this Motherboard, I found some things that were helpful.<br /><br /><span style="font-weight: bold;">#1 Install hangs, or I get an error after Installing RAID Driver.</span> Nowhere in the manual does it tell you this (or at least I didn't see it) but when you install the RAID driver during the windows install, the Motherboard automatically sets SATA connectors 1, 2, 3, and 4 to be RAID. That means if the DVD/CD Rom you are using is plugged in to any of those connections, the minute you install the RAID Driver, the Optical Drive will no longer work. You have to use SATA 5 connector on the motherboard for your optical drive<br /><br /><span style="font-weight: bold;">#2 Multiple Optical Drives with RAID</span>. Because of the issue in #1, there is really only 1 internal SATA Port you can plug an Optical drive into when you have RAID configured. There are some solutions if you want more than 1 Optical Drive alongside your RAID configurations. <br /><br />You can use the ESATA port on the back of the Motherboard with an extra-long SATA cable. If your case has grommets on the back for water-cooling lines, you can run the cable through there, or just in an unused PCI slot on the back.<br /><br />You can use an old-school PATA DVDrom. If you are installing 2 Optical drives, and one is a DVD burner or reader, you could get a PATA DVD Burner or reader instead. This Motherboard does have a good old fashioned ribbon connection, so it's possible. Typically DVDs or CDs don't move enough data to see a difference between PATA and SATA, but when you start getting into any DVD reading/Writing above 8X or so, you will be throttled.<br /><br />Get a PCIe controller card. I think of this as the last resort for this board because of it's possibility with graphics cards. Hooking up anything unnecessary to any of the PCI slots would be defeating the purpose of having 2 full 16X PCIe slots. You might be able to squeeze one in on one of the 1X connections, or maybe the bottom full slot, but it could get cramped if you have 2 or more Video cards.<br /><br /><span style="font-weight: bold;">#3 Windows Installation Issues. DVD Drive Stops Reading during install.</span> I had this issue even after finding out my issue from tip #1. I found that some windows install discs mixed with some manufacturer's DVD drives don't get along well. It would start the installation OK, and get most of the way through it, then it would hang and throw up an error. It seems that during Installation, the SATA DVD drive decides that doesn't like the generic drivers anymore, and just stops working. I fixed this by pulling a PATA DVD drive out of an older PC to use until Windows was fully installed. Once Windows was installed, I pulled that drive back out, and Installed my SATA DVD drive, and Windows installed the drivers with no problems.<br /><br /><span style="font-weight: bold;">#4 RAID Performance. </span>I'm not too sure that I'm getting the best performance from this RAID-0 configuration. I'm running 2 WD Caviar Black 500GB HDDs. My Windows Experience score for the drives is still 5.9. Perhaps the RAID configuration would work better with some faster drives, like Samsung drives, or WD Velociraptors... But I'm unsure.<br />
on Apr 03, 2011 | ASUS M4A79T Deluxe ( M4A79T DLX MB PHENOM...
NO HARD DISK FOUND DELL POWERDGE 1600SC
Is the HD SAS/SCSI/SATA on a raid controller?
If so you need to enter the RAID config (not the bios, but there will be a RAID config option during the boot process CTRL+M I believe.. but it will say on screen.) Then you need to set up the raid config, then initialise, then the drive will be detected for loading the OS.
Either that or the drive(s) shafted.
What sort of disks are you using?
Aug 20, 2010 | Dell PowerEdge 1600SC Server
I have a abit 1c7g motherboard intel 3.2ghz processor twin western digital raptors sata raid 0 config ... 1 sony dru 710a on ide 1 (slave) trying to install plextor 880sa dvd burner having conflict with...
Suggest you connect the plextor to the SATA port 3 and set it's jumper to Master. All SATA drives are seen as Master drives. (Check the serial number on your WD SATA drive "Primary".
Enter the bios menu. Within page 3-7 section 3-3 Advanced bios features. Check, 1st, 2nd and third boot devices.
Floppy disk drive as, 1st boot device. 2nd boot device, "Primary WD SATA port 1". 3rd boot device, CD-ROM drive SATA port 2, Plextor 880sa drive". Save and exit the bios. If you no longer have you're manual you can download it from the link provided below;
http://ftp.abit.com.tw/pub/download/fae/ic7-g_eng_v101.pdf
Check page 3-13. See OnChip serial ATA Mode. As noted, the RAID option is available when the item "OnChip serial ATA" is set as [Enhanced Mode].
Cheers'
Mike
Jun 27, 2010 | Abit IC7-G Motherboard
Unable to complete full boot with SATA Blu-Ray Player installed
Try reducing the size of the raid to under 2TB. If the system install, then try expanding the raid.
Jul 10, 2009 | Gigabyte GA-MA790X-UD4P Motherboard
A new sata LG dvd room,it work correctly,but i can't boot from it
First make sure that the DVD drive is the only drive listed to be booted from. Make it the first and only drive. Unfortunately most motherboards have an issue with booting from a SATA DVD drive. Secondly turn off Sata RAID if you have it. If this doesn't work then your motherboard isn't capable. It is too old and from what I can tell from the manual it is running SATA 986p, which is only 150mp/s thats not even Sata 1.5. Early Sata controllers couldn't do installations of OSs at all.
Apr 18, 2009 | MSI 661FM3-V SIS661FX LGA775 2DDR 400 2...
Software raid/ide
it won't touch them, it should ask you which partition you want to boot from, or which version of windows if your boot.ini files are on the same drive.
Dec 18, 2008 | Computers & Internet
ABit-Th7 raid Drivers
This problem is very simple.... Using RAID in booting in cd/dvd cannot be done in this kind of processing. you have to change the setting of Hard Disk and CD/DVD to IDE in BIOS . To change the setting in the BIOS you need to press the Delete After you power on the computer.. In Main menu in the bios you will find the hard disk or cd/dvd settings to IDE, SATA, and RAID. change both hard disk and cd/dvd to IDE configuration. make sure the first boot in the Boot menu is the cd/dvd, where your windows cd installer is inserted. Save the settings by pressing F10 key in the keyboard.. I have the same problem as of you because i try it to change SATA, RAID but cannot boot to cd and cannot detect the hard disk when installing OS, but in IDE settings its okay.. and it works perfect.. after you installed the windows properly, you can change the Hard Disk or cd/dvd configuration to SATA or RAID. TY
HOPE I CAN HELP
Dec 08, 2008 | Abit KT7A-RAID Motherboard
Slow transfer from SATA II (IDE) drive to 3 SATA II Drives configured as RAID (1). Drives wouldn't format until we installed the OS onto the RAID -- but it wouldn't install completely. We boot from the...
It appears you have made an error with the RAID configuration. RAID 1 is mirroring and requires an EVEN number of drives unless one is a hot spare. Also, RAID 1 is for redundancy and is slower than a single drive or RAID 0. Verify your RAID configuration and make sure you have RAID 1 and not RAID 0 or RAID 5 which can be an even or odd number of drives.
Nov 17, 2008 | Computers & Internet
Abit AW9D-MAX Motherboard Logo
221 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
