Question about Hitachi 53FDX01B 53" Rear Projection Television
Convergence Adjust The set is displaying blue shadows with possibly some yellow secondary shadows. When I push the Convergence Adjust button all lines are centered except the blue cross lines. The blue horizontal line is straight; however, the vertical blue line is bowed (not straight at all). I have the Hitachi CLU-5711TSI remote if that will help in any way. It does not appear that the Convergence Adjust button will do anything but display the cross lines (basically, I do not know how to adjust the lines that are there). Please help. Thanks Bob
  • twosunsets Jul 13, 2008
    Would a layman be able to fix this problem? I do not know what to look for or where the convergence IC would be. Also, approximately, how much would a replacement convergence IC cost? Once again, thanks for your help. Bob
  • Hitachi Master
  • 19,396 Answers
It means probably one of the two convergence ICs has blown
Posted on Jul 13, 2008
  • Ginko
    Ginko Jul 13, 2008
    To use the convergence adjust you need to press the button, holding it in while pressing the input button on the remote. Then you need to use the grid pattern to get it
    dead-on. If horizontal or convergence lines stay visible, bowing up on the outer edge on top and bowing down on bottom, then there is an additional convergence problem.
    Then the most likely is that (one or both) convergence ICs had blown. You need to replace the two stk392-110. Possibly replace them with the stk392-150 kit that is better.
  • Ginko
    Ginko Jul 13, 2008
    Well the ICs are worth around $10, the whole convergence board is about $60. having the job done by a repairman may range from $120 to $200
Mitsubishi ws-48311 blue and yellow shadows
I would suggest you go into the menu and select convergence and then advanced convergence (set will display on screen instructions) and call up the grid of lines by doing that---the grid of lines you see should all be yellow---if you see red or blue lines out of position try with the Mitsubishi remote to adjust them.
If they will not adjust the set needs the convergence circuit repaired.
For many if this is the issue it can be a do it yourself repair--I have complete instructions for this repair in this set---start to finish.
Look first to see if this is your problem.
SD TECH
Apr 22, 2012 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi RPTV has a blue shadow/image alignment problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 23, 2010 | Mitsubishi WS-65809 65" Rear Projection...
PICTURE HAS BLUE AND YELLOW SHADOWS AND cc is in yellow not white vs 50609
  • Screen looks 3D
Mar 11, 2010 | Mitsubishi VS-50605 50" Rear Projection...
Has blue shadows
  • Screen looks 3D
Jan 09, 2010 | Hitachi 50UX26B/27K 50" Rear Projection...
HITACHI 57UWX20B has blue ghost shadows how do I
  • Screen looks 3D
Jan 05, 2010 | Hitachi 57UWX20B 57" Rear Projection...
Mitsubishi TV Model #WS65903 - Green Shadow Lines on Screen
Something is not right here--The green is adjustable in the TECH menu--did this person adjust or try to adjust in the customer or the TECH menu?
If you confirm actual model number I can tell you how to get into the TECH menu--yes--green will not adjust in customer menu--it determines geometry and is only adjusted in the TECH menu.
Also, this set requires any convergence adjustments to be done in 480 and then in 1080--if only adjusted in one mode the other will still be bad.
Let me know if you know how to adjust in TECH menu or not--with exact model number I can tell you how to get there.
If this helps you rate this solution as I do this here for free.
SD TECH
Dec 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
I have a yellow line on the right side of my Toshiba 50 rear projection TV and yellow shadows around people
It sounds like a convergence problem---go into the customer menu and select convergence---set should offer center and multipoint adjustment--in the multipoint look to see if the outer crosses adjust--if red or blue will not adjust somewhere--bad convergence IC's.
Jul 17, 2009 | Toshiba 42H83 42" Rear Projection...
Have colored shadows around everything on my Mitsubishi HDTV 1080
  • Screen looks 3D
Jun 24, 2009 | Mitsubishi WS-55613 55" Rear Projection...
THE OUTER EDGES OF THE PICTURE ARE BOWED .
  • Screen looks 3D
Jul 25, 2008 | RCA HD56W66 56" HDTV
Hitachi 53FDX01B 53" Rear Projection Television Logo
258 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
