Question about Sony Cybershot DSC-T200 Digital Camera
Flash stopped working
Hey guys, my flash suddenly stopped working one day.
When i hit the menu on the camera for flash. there is no longer an option available to switch flash "on" or to put it on "auto flash". only option which is there is "flash switched off ". how do i get my flash working again ??
your help will be very much appreciated.
  • sarafena Oct 20, 2008
    My flash stopped working as well, not in burst mode. It always shows the no flash icon on the right of the screen. All my pics come out blurry. So frustrated. When I touch the flash, where there used to be many flash options, now the only one is no flash!
    Help!
I had the same problem, "BBWS" found this "solution":
Turn the camera on as if to take photos (not to review photos).
Press "Home" (upper left corner)
Press the camera tab (bottom left-most tab)
Press "Scene Selection (SCN)"
Press "OK" at the "Select type of scene" prompt
However, I still don't have flash available in the PGM or AUTO modes, which tells me it is still broken.
Posted on Jul 13, 2008
  • dsc-t200-fix Jul 13, 2008
    I poked around some more and found that "somebody" (SO) put the camera in burst mode. In burst mode, the camera will continue taking photos as long as the shutter is held down, and the flash will be disabled. The burst mode icon looks like a stack of photos and appears in the upper right corner under the photos-remaining count.
    Press the Menu icon, the first item is REC Mode, set it to single shot.
Kodak easyshare C183 flash not working
Check settigns or possible burned bulb.
Aug 23, 2012 | Kodak Easyshare C183
My camera wont flash ... How do i get it to flash ?
Most cameras have a button that looks like a lightning bolt. Hit that button and it will usually switch between flash options or it will bring up a flash menu. Some camera modes will automatically set your camera to auto flash, so if the room is dark, flash is on, and room is light enough the flash shuts off. You might need to switch to a different picture mode, like P or Programmable that lets you manually set your camera options.
Nov 08, 2010 | Cameras
Canon G9 Flash not firing and not able to find flash on the menu
Assuming there's not really a fault on the camera. Have you got it dialed into a pre-set photo option ? This may negate the flash. Suggest going through the settings menu, putting everything to auto and trying again.
Mar 07, 2010 | Canon PowerShot G9 Digital Camera
Flash does not work
Please note that:
1. You can not use the Flash when the Camera is set to Burst or Multi Burst mode.
2. You can not use the Flash when the ISO or Twilight mode is selected in the Scene Selection.
3. You can not use the Flash when mode dial is set to Movie.
Also try these steps and check:
4. Ensure that the battery is fully charged and the flash is turned ON.
Please set the Landscape mode or Snow mode or Beach mode in the Scene Selection and check if the flash is working.
5. Try initializing the Camera and check if it works normally.
NOTE: Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
6. Please press the Menu button on the Camera. Then, select the SETUP menu and select the SETUP 1 option of the Camera. Then, select the Initialize option to OK.
7. Try to power reset the Camera and check if it helps to resolve the issue. I suggest that you reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
8. If the issue still persists then the Camera requires service.
Good Luck!!!!!!!
Oct 26, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Olympus e500 internal flash not working
try resetting the camera back to factory defaults by putting camera in P mode, menu, custom reset
Jun 08, 2008 | Olympus EVOLT E-500 Digital Camera
Flash not working
I had the same problem with my flash not working on any setting, but I found a way to fix it: hit the menu button, make sure the "rec mode" choice is set to normal instead of burst. I think the burst mode takes multiple shots in a row, so the flash isn't compatible with that setting?
Feb 15, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Flash can not be turned on
I had the exact same problem as Dude2891 and it took me ages to work out what was wrong. The problem turned out to be that when I first got it and was playing with the menus, I managed to put it on burst mode, and in burst mode flash is automatically set to off. So you need to turn it on, press menu bottom left and scroll to REC mode (the first option) and then check that you're on Normal not Burst. That fixed it for me! See also Sony's tips at http://support.sony-europe.com/DIME/faq/faq.asp?l=en&c=DIME&sc=DSC&m=DSC-T200&f=mod_dsc_W_H_T
Hope that works guys, let me know how you get on.
Dec 16, 2007 | Sony Cybershot DSC-T200 Digital Camera
Flash
Did you try to reinitialize? Setup menu go down to the third Setup#1 menu and make sure you click OK to reinitialize. That's what the manual said.
Apr 28, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cybershot DSC-T200 Digital Camera Logo
108 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
