Related Tags:
This problem should be removed because:
Problem with Apple iPhone 3G
iPhone 3G Error 0xE8000001
Bought a 3G yesterday and I can't sync it with my iTunes. I use an iMac with the Leopard. When I plug the iPhone 3G into the iMac I get an error message, "iTunes could not connect to the iPhone because an unknown error occurred (0xE8000001)."
I re-installed the latest version of iTunes (7.7), restored my iPhone 3G and I still get the same message as soon as I plug into my computer.
Please help, I was so excited to get my iPhone 3G & now i really want to enjoy my iPhone 3G.
Thanks for helping.
Solutions (12)
Best Solution
I just had this problem and it turned out to be... It didn't like my iPod cable. Switched to the iPhone cable and it worked.
Seems to be an iPhone 2.0 prob, or 3g prob, since I was using the iPod cable to sync my old iPhone just fine.
all i had to do when my pc wouldnt connect to my iphone was simply sign out of my itunes account, then sign back in. it worked perfectly after that.
Follow these steps to remove and reinstall the Apple Mobile Device Service on Mac OS X. You will need to authenticate an administrator account and password to complete these steps.
Step 1 - In the Finder, locate iTunes in the Applications folder and drag it to the Trash.
Step 2 - Move the iTunes icon to the Trash
Step 3 - Choose Go > Go to Folder.
Step 4 - Enter /System/Library/Extensions and click Go.
Step 5 - Locate the file AppleMobileDevice.kext and drag it to the Trash.
Step 6 - Choose Go > Go to Folder.
Step 7 - Enter /Library/Receipts/ and click Go.
Step 8 - Locate the file AppleMobileDeviceSupport.pkg and drag it to the Trash.
Authenticate with the admin password.
Step 9 - Choose Finder > Empty Trash and restart the computer.
Step 10 - Now download & install the newest iTunes version.
Hope it helped you,
Good luck,
Enjoy your iPhone 3G
If your on PC, i solved it by creating a new user logon account, then reloaded itunes under the new user - works fine
Uncheck Sync from iPhoto under the Photos tab. Fixed mine.
Thought I would flag that I just solved this by rechecking my USB Hub (started into some of the more complicated solutions here then saw this on another forum). Ends up during some moving, the USB seemed to be powered but was not. Just thought I would note that in my case not enough power to the iphone connection to the Hub got it working again - JT
The real solution for this problem is based on the "lockdown" folder in the user's library. What I had to do was log in as root and delete it. iTouch (or iPhone) will connect fine..
I have the same freak'n problem!!!! I too have an new iMac. I've been on countless calls with Apple over this (yes I bought my 3G on the 11th)
Basically it's something in our user account settings. I've tried the above remedy to no avail. Create a different user and plug the iPhone in and it will work fine but then you have to transfer units...
it's very very lame and I want to know what in my user settings is creating this error!
for mac and pc simply try all usb ports , one of mine was fooked. delighted. thanks guys xxxx
Solution #7 worked for me. I had hacked the lockdown folder to make YouTube work and that had the bad effect of making iTunes no longer connect.
Renaming the lockdown folder to lockdown.save makes itunes sync and breaks YouTube.
This is all using iPhone (pwnage) 3.0 on a 2nd generation iPhone.
Since solution numbers change, this is the one I'm referring to:
Hi Friends,
Apple iPhone 3G's main problems are Display and Bluetooth problems.
For Display and Bluetooth problems you can visit a link by just Click Here .
For any other problems with this Phone you can Click Here .
On an old iMac, I solved this problem by killing the iTunes Helper process. This is on an old iMac with USB 1.1 ports. I connected a first generation iPod Touch.
Bought a 3G yesterday and I can't sync it with my iTunes. I use an iMac with the Leopard. When I plug the iPhone 3G into the iMac I get...
0xE8000001
hi, my name is Frossini and I'm from Greece. I bought 7 months ago an iPhone 3G and everything were perfect. But I downloaded the...
I have in iPod Touch 3rd Gen with blackra1n
I have in iPod Touch 3rd Gen with blackra1n installed on it. I accidentally shut down my iPod all the way (which for blackra1n users causes...
how do i download everything on my iphone 3g onto
how do i download everything on my iphone 3g onto my iphone 4 by using itunes
Add Your Solution
forgot password on my Cricket Huawei Ascend II
phone is locked and cant do nothing
my iphone totaly dead when i charged.. it heat and...
please help me.
unable to delete notes from my iphone 3g. i...
unable to delete notes from my iphone 3g. i can't get icons in notes
The bottom row of icons on iphone 3g do not work.
The icons on the top part of the screen works except for the bottom row. I have replace the lcd screen and I still have...
Fix-O-Meter
16,068
16,068 people viewed this problem
- 27 people found this problem to be helpful.
- 1 person is following this problem
Top Apple PDA Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
