Question about Pioneer VSX-D810S Receiver
Vsx-d810s anlogue to digital switching problem
Have just attempted to configure this amp. I select 7.1 input, noticed the signal is set at analogue. I can't work out how to change it to digital. As a result I cant get any sound. Also when going through setup surround sound my tests only get out put from Fr Center and Fl. No sound from either rear or the Sub. These speakers all worked as I have used them in this location with a different amp. Any thoughts Please??
Regards
Graeme
  • solar408 May 11, 2010
    do you have your input doing in digitally? Optical or Coaxial?
The 7.1 input is for the discrete *analog* inputs, ie your dvd player has a built in decoder and has
eight analog outputs for the eight 810 inputs. Digital stopped at the dvd player.
Posted on May 06, 2009
What is the code need to change older analogue tv to digital?
there is no code you need to buy a set top box to convert analogue signal to digital
Nov 07, 2014 | Televison & Video
Baird tv
Two things you can try:
Check the remote control and press the button for Digital input. Someone may have set the tv to expect an analogue signal from the aerial while you were pouring your wine. Because the analogue tv signal has been switched off the tv won\'t be receiving anything off-air. It will need setting back to digital to receive Freeview.
OR
The television set may be dropping itself into "AV" mode and is expecting an input through a SCART or HDMI socket. Sometimes an external device (video or DVD player) will hijack the television if the set-up hs been configured for this. Try unplugging all external devices (Sky box, DVD, VCR, games console or whatever you have plugged in). Make sure that the telly is configured to digital input and tuned to BBC1. Then see if the it will show the programme.
If the television is actually broke then you should return it if it\'s still under guarantee.
Jul 15, 2013 | Televison & Video
Pioneer vsx-d810s only dvd 7.1 input works and static on all other inputs
Try resetting the receiver the Pioneer Web site should have the reset procedure for your model if that doesn't work time to send to the shop.
Oct 03, 2011 | Pioneer VSX-D810S Receiver
Vsx-815h,power on hear the click as normal but no sound from any sources.The hdmi is allowing pictures so that side is ok.Has happened before and i left it unplugged from the mains for a short time and it...
Hello
At first check does the amp tunes to radio stations and can you hear sound from it. Your amp has no HDMI input function. The setup may have changed to your DVD or Blu-Ray player. Without knowing the device you connected to it, it is difficult to point out the exact fault. Anyway , just try these as your amps' maual indicates.
The user manul of your set points out these reasons only for absence of sound with your amp.
Go to the signal select setup and select "Auto" there. If it is selected to AUTO mode when you input a digital signal or analogue signal, the set will detect it automatically.
check whether MUTE finction is ON. If it is ON, turn it to OFF.
Check the speaker select function.
OK
Apr 12, 2011 | Pioneer VSX-815-K Receiver
My Denon AVR1611 powers up and the TV sound works just fine, but after 5 seconds or so the sound quits and I have to press the quick select sat/cable button to start it up again.
hi,
There are two types of input for sat/cable in your amplifier. One is the Digital input and the other is the Analogue input. You didn't specified which one is currently used by you.
However, if you connect the digital input then you have to configure the input assignment to digital and for analogue input configure as analogue.
If you use analogue input and input assignment is in digital mode then the problem mentioned by you can occur.
First of all check the input assignment for sat cable. for that do the following
1. Press the menu button on the amplifier's remote.
2. Select input setup
3.select input assinment ( check the input assignment for sat/cable, If you are using the analogue
input select it as analogue,if your are using the digital input then select it as digital.
ok
Feb 17, 2011 | Denon AVR1611 5 Channels Receiver
I am trying to hook my playstation 3 up to the pioneer vsx 510 using a digital optic cable. I have everything set on the playstation but still cannot get any sound. I am not that familiar with the reciever...
Be sure youve selected the optical output option on your ps3 (in sound options on your XMB) ... now on the back on the amp under the optical input it says CD. Select CD input using the toggle know or your remote and then on the front of the amp press the button labeled"signal select"(in between DSP select
Jul 10, 2010 | Pioneer VSX-D510 Receiver
I had only static on back speaker of pioneer vsx-d810s. Now I can not get the back speaker to work at all. Tried every step in the manual ten times. Now I can not turn DTS on or off. Monitor only show...
well you must config the surrond back speaker , check in operators manual how you do-it and pag.17 to 19 . please check for When “SB*” is selected in SPEAKERS setting mode,
the SURROUND BACK distance cannot be set.
so if you dont have check this site, who has the manual to help you how to config.
http://safemanuals.com/user-guide-instructions-owner-manual/PIONEER/VSX-D710S-_E is from 710s, but have 810s also
Jan 08, 2010 | Pioneer VSX-D810S Receiver
PIONEER VSX D810S POWEROFF
Hay que chequear los alambres de los parlantes..yo tuve el mismo problema..desconectè todos los alambres de los altavoces y luego los reconectè...y allì estuvo la soluciòn...
Mar 30, 2008 | Pioneer VSX-D810S Receiver
VSX D511 No input select
I am getting no sound via my optical cable input. The back of the AMP says that the optical is TV/SAT but i can't change the input to digital it will only go to analog. DVD player is set to Bitstream all dvd options set to DTS, but still no sound going through. Any help would be apprecaited
Jan 29, 2008 | Pioneer VSX-D511 Receiver
Open Questions:
See all Pioneer VSX-D810S Receiver Questions
Pioneer VSX-D810S Receiver Logo
199 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
