Question about HP Compaq nx6110 PC Laptop
Notebook wont boot up
When I press the On Button while the Power supply is connected , nothing happens. If I disconnect the Power supply the power light comes on for a couple of seconds then dies. If I remove battery and Power supply is connected still nothing.
  • Anonymous Apr 24, 2009
    Removed the battery replaced the the psu checked it with a multimeter digital voltage is correct but the laptop will not switch on
    An expert who has written 2 tips or uploaded 1 video tip.
  • 171 Answers
It may be power supply unit problem , if it is in warranty contact the authorized service center
Posted on Jul 15, 2008
Hello, Last night I shut down my Dell E510 desktop - the proper way - by going to the start menu, shut down, turn power off. Then, today, I pressed the power button on the front of my tower and...
This sounds like a definite power issue. This means that the problem could range from being as simple as the power button itself not working/disconnected to the power supply being dead.
Things to try:
1. Have the side of your computer open and press the power button. Notice if any fans start to move or anything that happens.
2. Do you notice the Hard drive light flashing at all when turning on?
3. Has anyone else been using or been close in proximity to the computer that could have bumped it, causing something to come loose?
4. ONLY if you feel competent enough, check the cable connections inside the computer. Make sure to disconnect from the wall for 30 seconds and reconnect before touching any cables inside. Leaving the cable connected allows the computer case itself to act as a ground to prevent static shock.
Dec 23, 2010 | Dell Dimension E510 PC Desktop
My compaq presario V6000 is stop working out of blue..Don't know why..the power cable is connected but hit the power button,nothing happens..any solution ??
Disconnect all cables from the computer. Press and hold down the power button for about 20 seconds. Reconnect only the power cable and try to turn on the computer on pressing the power button If it turns on then good otherwise, switch the power cable of the computer with the power cable of the monitor as they are the same cable as the power cable could be bad but this rarely happens. Open the computer and see if you see any light on the motherboard, if you do then the power supply is bad. If you dont then both power supply and the motherboard could be bad.
May 03, 2010 | Compaq Presario 5000 PC Desktop
Not powering on at all - I have been built a new computer from scratch with all brand new components. After hooking all of them up and plugging in the power source. Nothing is happening when the power...
1. Could be as simple as not having the Power Switch on the right jumper...double check.
2. The board will power up with nothing hooked to it... just power, CPU, MEM... disconect everything to just to get the board up to the bios.
3. Make sure PS is securly connected to the MB.
4. Check Jumper on the Board to make sure the Test Jumpers are not set
5. Memory is seated correctly... if you pull them out the board will start and beep...
Dec 31, 2009 | Gigabyte GA-G41M-ES2L Motherboard
My printer will not turn on. We had a storm
Solution one: Press and quickly release the Power button Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button . Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Check the electrical connections and outlet
  1. Unplug the power cord from the electrical outlet, or the power strip or surge suppressor. Power module Power cord c00745315.gif c00057913.jpg
    NOTE: The power cord detaches from the power module. The term power supply refers to both the power module and the power cord.
  2. Carefully inspect the power cord for visible damage. c01733891.gif If the power cord or power module shows any damage, contact HP to replace the power supply.
  3. Disconnect the power supply from the back of the product.
  4. Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor. c01733891.gif If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.
  5. Reconnect the power module to the product.
  6. Press and quickly release the Power button (c01602202.gif ) to turn the product on.
  7. If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn on the product.
    • If the product turns on , the electrical outlet in the original room caused the issue.
    • If the product still does not turn on , continue with the next solution.
Solution three: Check the USB cable
  1. Disconnect the USB cable from the back of the product. Figure 2: Disconnect the USB cable from the HP productc01896072.gif
  2. Press the Power button (c01602202.gif ) to turn on the product.
    • If the product turns on with the USB cable disconnected , replace the USB cable.
    • If the product still does not turn on , continue to the next solution.
Solution four: Check the batteryIf your HP product has a battery, follow these steps:
  1. Check the battery light. If the light is red, recharge the battery.
  2. If the battery light is still red after recharge, replace the battery. Figure 3: Removing a battery (example only)c01468528.jpg 1 - Slide the battery release slider in the direction of the arrow 2 - Remove the battery
Instructions for recharging and replacing a battery are available on the HP Web site. Solution five: Replace the power supplyIf you have completed all of the troubleshooting steps and are still experiencing a problem, contact HP to replace the power supply for your product. Solution six: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Nov 25, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Nothing happens when I press the power button. No
What about the power supply? I bet it's supply's issue. Otherwise make sure that PWR button wires are connected properly and to the correct terminals of the motherboard
Jun 29, 2009 | Intel D915GAG Socket 775 Motherboard -...
HP computer doesn't turn on
Your power supply is bad--you will need to replace. I suggest looking at tigerdiect for a replacement.
Dec 12, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Acer aspire 5610
remove power supply then remove battery.
then connect to power supply and try to boot, if no luck then remove power supply and press and hold power button on laptop atleast 10 seconds then in the same postion connect the power supply.
if still no luck then you should take a tour to service centre.
For any more question just ask me.
Jun 29, 2008 | Acer Aspire 5610-4648 Notebook
Power Issue
sounds suspiciosly like your chord fitting is damaged(loose wires at connection)and shorting.if possible try a friends power supply with same connecter type before renewing cos could be faulty(loose)connection at pc(inside)constant pushing and pulling of connections often causes 1. loose split or disconnected wires at male connection or 2.loose pins on motherboard female connection or broken housing (not difficult to repair)more difficult to find out how to get to internal connection.
Mar 04, 2008 | Toshiba Satellite M65-S9092 Notebook
HP Compaq nx6110 PC Laptop Logo
117 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
