Question about Toshiba Computers & Internet
I HAVE RECENTLY BOUGHT A TOSHIBA EQUIUM L300-146 AND IT CONSTANTLY HAS PROBLEMS CONNECTING TO MY WIRELESS NETWORK. IT KEEPS REPORTING LOW SIGNAL AND DISCONNECTING, HOWEVER OTHER LAPTOPS IN MY HOUSEHOLD HAVE NO PROBLEMS CONNECTING TO THE SAME WIRELESS NETWORK. I'VE TRIED ADJUSTING MY FIREWALL SETTINGS ETC, AND HAVE ALSO TURNED OFF OTHER DEVICES (I.E CORDLESS PHONE) THAT MAY BE INTERFERING.
  • 177 Answers
What OS are you using? Try updating your drivers on your Toshiba.
Posted on Jul 13, 2008
Two toshiba laptops, one less than a year old running win7...the other 3 yrs old runnign xp. both worked fine connecting wireless to my router sat. sun the win7 machine said the dns server was not...
Did you press a button (or move a slider-switch) on the WIN7 laptop, to "disable" the wireless adapter?
Can you login to the web-server "inside" the wireless router, and look at the "log-files" that the router keeps of "recent" events (such as connection-attempts from wireless devices), to see if there is any useful information in those logs?
Does the WIN7 laptop connect to _any_ wireless network (Starbucks, university, shopping mall), or does it fail ONLY when connecting to your wireless router?
Have you tried a "factory-reset" on your router, just in case that it might be the problem?
Feb 21, 2011 | Toshiba (PA3212U) Wireless Adapter
ZyAIR G-302 (760559111205) 802.11g/b Wireless Adapter: Hi, i have recently installed the G302 v3 wireless...
Have exactly the same problem. Is it problem of current drivers? Or any other solution beside waiting for next version?
May 17, 2010 | Zyxel ZyAIR G-302 (760559111205) 802.11g/b...
Wireless Network Connection constantly reading low/vlow/no signal
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply).
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Jan 04, 2010 | Computers & Internet
Toshiba equium A210-17i wireles problems
It doesnt sound like a problem with you laptop, rather its most likely to be the router.
People can edit the settings so that only their IP adress can connect.
If you can connect with limited connectivity, again its the router, not connecting properly.
Can you connect to any router? i take it you're not connection to your own XD
Ed
Feb 02, 2009 | Toshiba Equium 7100S PC Desktop
TOSHIBA EQUIUM WIRELESS PROBLEM
You might deleted your driver to wireless connection or you perhaps upgraded Service Pack to higher version. If your wireless connection will work on lower SP then that device won't work or vice versa.
Another thing, try to check connections. Click menu and look for connections and try to enable wireless connections.
Thanks
Jan 11, 2009 | Computers & Internet
Connect another laptop using Vista operation system to my wireless network
thank u for the clarification..if it says "low signal strength" then u will have to reduce the distance between the laptop and the wireless router..also please ensure there are no big objects,walls etc between the two..u can get better signal strength by doing these..also other nearby wireless networks and cordless phones can hamper with signal..hope it helps!regards!
Nov 02, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a toshiba Equium L300 & it cannot connect to a wireless router. I have been advised that it is missing a ethernet/wireless driver. Please advise
From what I see about the Equium, the name Equium is in use in UK only. In other European & countries USA the name is Satellite. From the specs of the model you mentioned you DO have a onboard NIC. You might have to uninstall the driver that you have due to corruption and the operating system will install a generic driver for you to use. Or you can go to Toshiba if you’re in Europe
http://www.toshiba-europe.com locate support and you can download the driver there.
If you have a driver your probably not setting (configuring the router and your computer) the network up properly.
Networking Networking: Network adapter
Wireless LAN Supported: Yes
Wireless NIC: Realtek RTL8187B
Data Link Protocol: Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Compliant Standards: IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED
Jun 29, 2008 | Toshiba Computers & Internet
Wirless Network keeps failing
It is possible that you need to further fine tune your WEP configuration. To verify if it's the security lock, try running the laptop and the router without the WEP security (disabled) and determine if you still get the "Limited connection or no connectivity".
If yes, you have just eliminated that area and could consider other possibilities, otherwise you then have to concentrate on the WEP security.
Hope this be of initial help/idea. Pls post back on any developments (or lack thereof) or should you need additional information.
Good luck and kind regards.
Feb 10, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Wireless switch
Make sure you have the latest drivers, router and NB.
Does it connect on reboot with the SSID off?
Does it work on repair?
if so, check your energy settings, some times they power down the wireless to save energy. There are also settings on how it behaves.
Jan 04, 2008 | Toshiba Equium 7100S PC Desktop
WIRELESS NETWORKING
There are several problems reported that may cause disconnection. First is the hiding of the SSID (wireless network name) and enabling WEP or WPA encryption. The recommended solution for that is to unhide the SSID in the router configuration.
Second is that there are more and more wireless devices and occasionally interference occurs on a single channel (even from non computer devices like wireless phones. As routers are often set to channel 6 you may be competing for radio communications with your neighbors. The recommendation is to switch the router to either channel 1 or 11. If your first choice does not work try the other.
Dec 24, 2007 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Computers & Internet Logo
107 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
