Question about Epson Stylus CX6600 All-In-One InkJet Printer
Scaner I can't figuer out how to use my epson Cx6600 all in one to scan pic to my computer can you halp if so email is ashieswife05@yahoo.com thank you tina
  • Epson Master
  • 691 Answers
As you have not mentioned your computer set up, I will have to assume you are using a PC and not a Mac and are running Windows XP.
Download Epson Scan (2.7u) from the Epson Web Site. This will enable you to control scanning via PC.
Posted on Jul 16, 2008
Scaner does not work with Windows 7, are there any
Hi
Yes there is a scanner driver available, this however is a Twain driver and you will need to use the "Import" or "Aquire" function from within word, office scanning utility, Adobe Standard etc for this to work.
Check out this link and use the "TWAIN" driver.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=41664&prodoid=46253282&infoType=Downloads&platform=Windows
Dec 09, 2009 | Epson Stylus CX6600 All-In-One InkJet...
I want to scan a document to my computer
have you installed all the scanning software that came with the scanner, Install them and go through these steps to scan a document using Twain;
Overview of the Basic Procedure
This section outlines the basic scanning procedure using a TWAIN-compliant application. For detailed procedure, see the Scanning an Image.
Make sure the CX6600's power cord is plugged in.
Place your materials on the document table.
Start a TWAIN-compliant application.
In the application, open EPSON Scan.
Full Auto Mode:
EPSON Scan automatically previews the images and recognizes the document source and type. images are automatically optimized and scanned.
Home Mode or Professional Mode:
Make settings to optimize images and click Scan.
The scanned images are sent to the application.
Save the scanned images in the application.
Scanning / How to Scan
Scanning an Image
Turning on the CX6600
Placing your materials on the document table
Starting the software and scanning an image
EPSON Scan provides three modes for you to make any scanning settings; Full Auto Mode, Home Mode, and Professional Mode. This section describes how to scan an image in the Full Auto Mode. The Full Auto Mode lets you scan images using automatically-adjusted settings. For more details, see Choosing a Scanning Mode.
Note:
You cannot scan an image with a size that exceeds the available memory or disk space. If you try to scan the image, an alert appears on the screen.
Note for Macintosh users:
Most illustrations shown in this section are for Windows, so they may vary in appearance from what actually appears on your screen. The instructions are the same, except as noted.
Caution:
Before starting the following steps, make sure that all the necessary software including EPSON Scan has been installed. For details about how to install the software, see the Start Here sheet.
Before turning on the CX6600, make sure it is connected to your computer.
Press the On button to turn on the CX6600. All mode lights flash, then the mode button for the mode you used last lights, meaning it has completed its initialization.
You can scan reflective documents (like photos or paper). See Placing Photos and Documents on the Document Table.
You can start EPSON Scan in the following ways.
* Start EPSON Scan directly as a stand alone application
* Start EPSON Scan from a TWAIN-compliant application
This section provides information on how to start EPSON Scan from ArcSoft PhotoImpression. For details on starting EPSON Scan as a stand-alone application, see Starting EPSON Scan.
Note; if you are using Windows 98:
ArcSoft PhotoImpression 5 supports Windows 98 Second Edition or later. For version earlier than Windows 98 Second Edition, use EPSON Scan or other TWAIN compliant applications. See Starting EPSON Scan for details.
Start ArcSoft PhotoImpression.
For Windows users:
Click Start, point to All Programs (for Windows XP users) or Programs (for Windows 98, Me, or 2000 users), and select ArcSoft PhotoImpression 5. Click PhotoImpression 5.
For Macintosh users:
Double-click the Applications folder on your Macintosh HD, then double-click the PhotoImpression folder. Finally, double-click the PhotoImpression 5 icon.
Click the Camera/Scanner button.
Select a file format, location, and file name, then click Epson Stylus CX6600. EPSON Scan starts. See File formats for information on file formats.
Note for Windows XP users:
Do not choose WIA-Epson Stylus CX6600 from the menu to select the CX6600. If you select it, you cannot use the Epson scanner function fully.
EPSON Scan automatically previews the image, and recognizes the document source and type.
If you want to select more settings, click Pause, then click Options to open the Options dialog box. For more details on settings, click the Help button in the Option dialog box.
After EPSON Scan has previewed and recognized the document type, the following window appears. You can see the document type in the window.
EPSON Scan automatically locates the target images, modifies their skew, and starts scanning.
Caution:
Do not open the scanner unit during scanning or copying; otherwise, you may damage the CX6600.
Note:
Be aware that clicking Cancel on this screen closes EPSON Scan.
The scanned image is sent to ArcSoft PhotoImpression.
Note:
* Depending on the image you want to scan, you may not get the expected scanned image. In this case, scan the image in the Home Mode or Professional Mode.
* When you scan in the Full Auto Mode, black and white documents might be recognized as a color document. In this case, scan the image in the Home Mode or Professional Mode.
If you still experience problem scanning, un-install the entire software and re-install them all over. Install all the packages in the CD. Cheers!
May 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Epson cx6600 printer to new vista platform
Download the driver you need for the Epson weblink below and let the computer install the printer and you tell it where to find the driver. I ususaly place it right on the hard driver   (for example    C:\ DRIVER   )   where DRIVER is the name of the driver that you downloaded, either the 32 or the 64 bit VISTA.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=41664&prodoid=46253282&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=33&y=7
Mar 05, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Epson CX6600 printer does not print
Make sure the tape is removed from the cartridges and that they are the correct ones for your model printer.
Jan 17, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Red light
Your printer appears to have hit he "ink overflow protection counter" meaning that it thinks the waste ink pads in the base are full.
If the printer is in warranty, get Epson out to it. If not you can sort the error yourself using the rescue kit for the CX6600 available here: http://www.tradebit.com/filedetail.php/2379162-stylus-cx6600-rescue-kit-zip
Oct 13, 2008 | Epson Stylus CX6600 All-In-One InkJet...
CX6600 SCANNER
Download the Reference guide for your machine from th eEpson web site. It will inform you what you need to do to complete the scanning options. you can also download the Epson Scan utility to help with scanning to email etc.
Jun 02, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Film viewing and scanning
Sorry, but you won't be able to do that with a CX6600. In order to scan film negatives, you need a printer that includes a transparency unit in the lid, that is, a panel that lights the film from behind. Also, the CX6600's scan resolution wasn't designed for detailed film scans. Try the online Epson Store at www.epsonstore.com where you can often find good deals on refurbished stand-alone scanners with transparency units.
Jan 21, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Cx6600
does it state call for servicing if so i have servicing software for all epson even new ones get back to me thanks
Nov 16, 2007 | Epson Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
53 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
