Question about Dryers
Front load frigidaire dryer
My dryer is a three prone plug. My house dryer socket reguires a four prone plug. My question to you is once i connect the four prone plug to the dryer. The green wire can i connect it to the ground connector at the back of the washer even though this was is grounded thru a link.
muttandjeff
  • 359 Answers
SOURCE: Using 4 wire plug on 3 wire dryer
YES TAKE THE GROUND WIRE OF THE NEW PLUG AND CONNECT IT TO THE FRAME OF THE DRYER UNDER AN EXISTING SCREW OR USE A SELF TAPPING SCREW THE FOUR WIRE SYSTEM WAS PUT INTO THE CODE MOSTLY TO INSURE GOOD GROUNDING ON MOBILE HOMES AND THE METHOD WILL WOKE FINE AS I HAVE GIVEN YOU
Posted on Nov 16, 2008
WRMtech
  • 70 Answers
SOURCE: Connection
the green wire will attach to the dryer cabinet. The white wire will attach to the middle and the other two(red& black) will attach to the outside of the terminal block.
Good Luck!!
Posted on Feb 24, 2009
rockitman187
  • 2559 Answers
SOURCE: Where to wire the ground when changing a three prong to a four pr
This cover is all different sizes and shapes depending on the manufacturer of the dryer, but it is typically very close to where the cord enters the dryer. The cover is typically held in place with 1 - 4 screws. See image to the right of a Maytag Performa dryer access panel.
04b796a.jpg With the cover open you will see a terminal block with three wires. Black on one end, white in the middle and red on the other end. Use your 3/8′ nutdriver to remove the nuts or a phillips screwdriver to remove the bolts (depending on your dryer) and remove each dryer cord wire from the terminal block. When you remove the nuts or bolts, be careful not to drop them down into your dryer. Now you need to install a bonding jumper from the neutral terminal to the dryer’s frame. The bonding jumper is either a metallic strap (typically copper or copperclad) or a green wire that is connected between your dryer’s neutral (white wire) terminal and the green ground screw connected to your dryer’s frame.
Installing this bonding jumper is an extremely important step when changing from a 4-wire to a 3-wire power cord to prevent electrical shocks when touching anything metallic on your dryer.
If you do not have the original bonding strap, you can make one. You need a short piece of green 10 AWG wire, 2 ring terminals, a pair of wire strippers and a pair of crimpers. Strip both ends of the green 10 AWG wire and crimp one ring terminal onto each end of the wire. Now connect one end of the wire to the neutral (center) terminal and the other end to the dryer’s frame; where your ground is connected now. a9fc1b2.jpg Loosen the screws at the connector and pull the cord out. Now thread your new cord through the connector and tighten down. This only needs to be snug do not over tighten. Sometimes the old connector will work with the new cord and sometimes not. If not, your new cord will include a connector that you may use. To hook up your new 3-wire dryer cord, connect each wire to the dryer’s terminal block. The 2 outer wires are your “hot” wires and the center wire is the neutral. Replace the access panel cover and your new 3-wire dryer cord is installed Before plugging in your new dryer cord, I recommend turning off the breaker to your dryer receptacle. Then plug in your dryer. Now turn the breaker back on. This is not fool proof, but it is a safer way to turn on the power to your dryer if you made a mistake connecting your new dryer cord.
If your dryer is different from the one described above and would like a second opinion on your connections, email a picture of the terminal block to info at ezdiyelectricity dot com. I will post the pictures on this page to help others with the same dryer.
Posted on Apr 05, 2009
SolutionGuy
  • 331 Answers
SOURCE: four prong plug to three prong plug
Kalola,
You can if you want to, but it's not generally necessary. Here's a picture of a 3 prong configuration with a ground strap...
That green wire with the yellow stripe is a ground and it is most definitely connected to the cabinet somewhere. So it will serve as the ground strap (in the above picture).
Here's the thing... say you were going from a 3 prong to a 4 prong. That is, the dryer was originally "designed" for a 3 prong. This means you'd have to "retrofit" it a bit. Take a look at this pic... ( I made this for someone else, so please disregard my somewhat hostile remarks, OK?)
The ground strap has been removed and has been replaced by the ground to the frame. Yours probably does NOT have a ground strap, though... yours uses that Green/Yellow wire for frame ground.
All of that to say this. Don't lose sleep over it. Ya done good.
SG
Posted on May 02, 2009
SOURCE: Change 3 prong dryer cord to 4 prong
I have a Maytage Gas Dryer Model SDG515DAWW that Starts up fine but once it heats up ahd the gas shuts off the first time it will not come back on. The blower keeps running but no heat
Posted on Dec 14, 2009
Frigidaire dryer faqe7001lw blinking lights
Try resetting the computer like a cars e.c.m. by turning the dryer on and plugging it from the outlet. It worked for me once w our new Malta front loaders
Apr 07, 2012 | Frigidaire FAQE7001LW Dryer
Cycle starts and then quits, lites all come on and beeps sound starts
If you remove the bottom panel the drain plug housing and the pump are all one piece -two screws hold it in place to the bottom of the washer - remove these - pull it free - and then three screws hold the pump to the plug housing. - after you detach you may find more of a clog - if not there may be a reset switch on the pump - if that doesn't work try spinning the pump and reattaching to run a very light load.
Dec 24, 2010 | Frigidaire FTF2140FS Front Load Washer /...
Which wires is the hot wire, nautral and ground because I have a three prone plus changing it to a four prone in the back of the dryer.
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Oct 29, 2010 | Hotpoint NBXR463EBWW Electric Dryer
My plug is a three prung plug and the dryer is a four prung plug what colors goto what on a three prung
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 17, 2010 | Kenmore 62602 Electric Dryer
Is there a adapter that is made for this product,my wall socket in the laundry room is made for a 4 prong cord, but the machine is a three prong Frigidaire FEX831CS Top Load... stakable
Sorry there is no adapter for the plug. You need to change the cord from the dryer or change the plug in wall. You can get a parts at homedepot.
Nov 15, 2009 | Frigidaire FEX831CS Top Load Stacked...
Convert three pin plug to four pin
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Sep 06, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Nov 16, 2008 | GE Dryers
Dryers Logo
79 people viewed this question
Top Dryers Experts
