Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
Model 601V2 dishdraw showing U3 error message
  • 15 Answers
I have had my Fisher Paykel dishdrawer for 8 years and it has never completely worked. I would get a U3 code on the top drawer intermittently. I have had my drains rerouted twice, LP - HP reset, service men replace the back flow flap and mother boards without luck... until I was able to get my hands on the service manual. Turns out the solution is quite easy. If you have a problem with the U3 code it means the drawer is not draining appropriately, The washer only gives a preprogrammed 60 sec to drain the drawer. So if your drawer is overfilled, it will think it has a drain problem. The following is taken from the service manual...
"U3 - Time to fill was too short, indicating water was still in the tub.
Possible Causes:
· Drain pump is blocked.
· Drain hose is blocked.
· Sprayarm or rotor not turning
freely.
· Motor electronics have failed.
· Machine set to 'LP' on a high
pressure water supply.
The tub fills with approximately 2.2 litres of water, level with the base of the spray arm attachment. Once this level is reached, the wash pump (which has sensed the fill at 30 second intervals during the fill), becomes primed and pumps the water through the spray arm which will then rotate.
The water level is monitored by sensing the motor load through the electronics."
The solution is to turn your water supply valve part of the way on to limit the gpm flow to the drawer. This way, the drawer will not have over-filled in the 30 sec it took to sense the motor load. I have tried it and wow no more U3. Hope it makes sense and hope it works for you.
jim
Posted on Feb 09, 2009
I am getting the error U3 coming up with a red light and the cycle stops at that point. I am not sure of the dishdrawer model number and have been through a number of the user manuels but cannot find the...
There are a few reasons for U3 to appear.
One that is most common is due to water not filling in time before the wash cycle commences. This can be due to water pressure setting not being consistent with the mains water pressure. Check this by confirming if you are in low water pressure or normal pressure area. The dishwasher should be set at LP or HP accordingly. Refer to the manual for the procedure.
May 07, 2011 | Fisher and Paykel 23 in. DD603H SS...
U3 error code
I believe U3 error on your model of dishwasher could also mean a couple of other things like either the drain hose has an obstruction (kink) or the inlet water pressure is not correct.
Hope this helps in finding out what could be the actual reason. T
o find the kink if any, pull the drawer out as much as possible and feel the hose. Might be better if you took the bottom drawer out from the casing and inspect the hose completely. As the problem is limited to upper drawer you do not have to worry about what is under the bottom drawer. Check the water pressure setting is same for both drawers. If so then that is not an issue as bottom drawer is working ok according to your description. See your manual for instruction on how to check the water supply pressure setting on your dishwasher.
Jun 13, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
Our F&P DD601V2 double dishdraw is showing error 'U3' and the water does not totally drain out after a cycle, any ideas? Thanks
This applies to all DD601 and DD603 dishdrawers.
U3 is either one of the following:
- Drain pump is blocked.
- Drain hose is blocked.
- Sprayarm or rotor not turning freely.
- Motor electronics have failed.
- Machine set to 'LP' on a high pressure water supply.
Often it's just the last one, "Machine set to 'LP' on a high pressure water supply.", as this can be unintentionally changed by a user from an uncommon course of events. Sometimes, due to the technical design of the way the buttons work, if water bridges the 2 "Programme" and "Eco" buttons (inside on the top right of the tub), pressing either one, or both, (or just having your finger in the water) for longer than 5 seconds brings up a special mode that a user, in their ignorant attempts to get out of it, can erroneously change the pressure setting, subsequently causing a U3 error. It happened to me once when I was cleaning the machine, wiping around the Programme buttons.
To change to the proper High or Low Pressure settings:
1) LCD Display on. Hold the Programme and Eco touch switches simultaneously for 5 seconds.
2) Machine beeps and "HP" or "LP" is displayed in the LCD.
3) Push the Start/Pause button to toggle between them.
4) Push the Power button when correct selection complete.
Apr 07, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishdrawer DD601 v2 Error F1 on the bottom draw.
Below is the link to the service manual
http://www.scribd.com/doc/6462163/DD601V2-Manual
This will be able to explain the problems better that I can in the tiny space I get to write in.
Mat
Please rate me
Mar 15, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel Double dishdrawer - U3 error. Stops washing about 5 minutes into the cycle.
when you start the unit let it run for a minute then pause it before it starts to fill and check to see if it's drained it's water if not then you have a drain fault cheers. fell free to Chat live if you want me to talk you through it cheers
Aug 11, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
When I plug in my sandisk u3 titanium 2G cruzer on mac I only get u3system icon - the cruzer icon does not show up
How do I get the sandisk cruzer 2.0 titanium to show up on desktop - only u3 system shows.
Yes, it did work prior on my old emac with Panther macosx v10.3.9 and on a new imac. Sometimes it would eject fine and other times after I ejected it and after the icon disappeared, - It would bring up an error message that it was ejected wrong and might have problems.
That is what it said yesterday and when I tried to use it again - The only icon that shows up is the u3 system.
May 31, 2008 | Computers & Internet
Double Drawer Dishwasher
The last two faults are logged into EE memory.
The other U (user) faults have been removed. The old U2 fault, which was the tub forced open during a cycle, has
been removed completely. Instead if the tub is forced open the product simply pauses as if someone had pressed
the start/pause button. The old U3 fault, which indicated a failure to drain i.e. water left in the tub, will not show up a
fault and the DishDrawer will continue through the cycle
Jan 21, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
F & P Double Drawer
Are you sure of the model?? flash a U3 the following is from The FP Manual on the DD-603 Model...........
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
1,591 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
