Question about Motorola TalkAbout T5000 2-Way Radio
How do I Reset my T5000 2 way radio to factory default
I have a Motorola Radius CP100 & CLS Demo UHF/VHFradios, I was able to reset both radios to factory setting by pressing the menu and ptt for a few seconds while I turn on the power. Now I can communicate on both radios.
My question is how do I reset my T5000 for factory default setting so I can also integrate it with my radios mentioned above?
  • moa2510 Sep 27, 2008
    How do I Reset my T5000 2 way radio to factory default problem
  • Anonymous May 02, 2009
    how do i turn on the microphone it seems to be shut off on one
  • Motorola Master
  • 1,654 Answers
The T5000 Talkabout radio default settings are not the same as the CP100 and CLS. The CLS and the CP100 UHF are capable of being programmed to match one another on several frequencies, however, the TalkAbout T5000 is not capable of any of them.
The Talkabout radios, as a general rule, are limited to FRS and GMRS frequencies. The CP100 and CLS are from the business and light consumer divisions. They will do most of the common 56 UHF business frequencies.
If you would like to look at the frequency charts yourself, here are some links.
Here are the frequencies possible on the T5000
Here is a link to the CLS radio manual
Here is a link to a CP100 user manual
Posted on Jul 21, 2008
Is motorola cls-1110 compatible with bpr40 radios
yes, with conditions. The CLS comes preprogrammed with frequencies and tone codes. The BPR requires software and cables. It is not a preprogrammed business radio, but a fully programmable business radio. If your BPR radios are first: UHF, then they can be programmed to match the CLS. Do note, a few of the CLS frequencies are approved by the FCC for low power only, meaning a maximum of 2 watt power output. Find a dealer willing to do the programming for you if you do not understand. Our shop does it often.
Mar 14, 2015 | Motorola CLS 1110 (1 Channel) 2-Way Radio
How can I get my Motorola CLS1110 to talk to my Baofeng BF 888s?
The CLS has preprogrammed frequencies. The Bao can be user programmed. If both are Uhf, the Bao must match the CLS unless one of the CLS frequencies is already in use in the Bao. So, are you already using CLS and adding radios? You need the actual frequency and tone code. If you do not understand, contact a dealer like us, local is even better! Channel 1 is only an indicator, not a frequency.
Mar 01, 2015 | Motorola Radio Communications
What are the default PL codes for the Motorola VL50?
I don't have a VL50, but a CLS is frequency two, code one. There is a way to reset to Factory default: press & hold PTT switch and the Monitor as you turn it on. If I got it wrong, try the scan switch instead of monitor. How this helps, if you want the actual numbers, post again please.
Feb 11, 2015 | Motorola Radio Communications
How do I factory reset a oricome 200rx uhf
Factory reset
If the radio's display locks up or stops functioning properly, you might need to reset your UHF radio. Caution: this procedure clears all the information you have stored in your UHF radio.
Before you reset your UHF radio, try turning it off and on again. If your UHF radio is still not functioning correctly you may need to reset the UHF radio! While holding the F/DPX button, turn the UHF radio on. INITI AL will be displayed for 1 to 2 seconds, the radio will then return to its original display.
Oct 02, 2014 | Radio Communications
Can the freq 156,600 be put in this radio if so how do i do it
No, 156.600 MHz is not one of the 27 VHF frequencies available in the CP100 VHF radio. (If by chance you have a typo and you meant to ask about the common frequency of 154.600 MHz, aka green dot, it is available in the CP100 VHF.)
Here is a link to a website with the user guide: The frequency chart is on page 34. Programming instructions begin on page 20.
Best regards.
Best regards.
Feb 09, 2014 | Motorola Radius Cp100 Uhf 1ch Two Way...
Motorola Radius CP200 flashing yellow when charged
The battery is no longer taking a charge properly and needs to be replaced.
Feb 12, 2013 | Motorola Mint Radius Cp200 Uhf 4ch Radio
How do you reset Motorola CLS 1410
The radio has fixed frequencies. If you wish to remove the options, they must be done individually for each channel. Here is a link to the manual:
Jan 22, 2013 | Motorola CLS 1410 (4 Channels) 2-Way Radio
I need a pdf manual for a motorola p10 two way uhf radio
Here it is: The Manual for Motorola Radius P10 Two Way Radio.
Hope this helps!
Remember to Thumb me Up! :D
May 30, 2011 | Motorola Radius P10 Two Way Radio.
Can not change code and frequency
First, we would suggest resetting the radio to the factory default settings by turning the radio on while holding Push to Talk and Menu button for 3 seconds.
After doing this, check to see your radios function with one another. If they do, then proceed to programming the radio to the frequency/PL codes you are wanting. If the radios do not communicate after resetting them, one of the radios has a problem.
Here is a link to the user guide: You will find programming instructions on page 28, with a frequency chart located on page 26.
Best regards.
Jul 15, 2010 | Motorola CLS 1410 (4 Channels) 2-Way Radio
How to get a Talkabout T5720 to communicate with a
The frequency range and operatngmode of the two radios are compatible. To get the Radius operating on a GMRS channel you'll need a Motorola programming cable and software, OR a trip to a Motorola dealer for frequency programming. Considering the cost involved, the 2-watt output of the Radius, and the 1-watt output of the Talkabout, you would be better off performance and cost wise buying a pair of 5-watt GMRS portables.
Jan 11, 2010 | Motorola Talkabout T5720 (7 Channels)...
Motorola TalkAbout T5000 2-Way Radio Logo
1,637 people viewed this question
Top Motorola Radio Communications Experts
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
