Bosch Hydropower 16H instantaneous gas hot water unit not firing??
  • qnator Jan 03, 2009
    same problem, does not ignite.
    common -
    http://www.productreview.com.au/showitem...
    lots of people with the same problem and no help from bosch. sounds like a garbage product
  • Dave Morgan
    Dave Morgan Apr 07, 2018
    The Bosch Hydropower units have poor electrical design, anyway assuming the heater is working properly, I would get it serviced for this that is ), backflush water circuit, just unplug in and out water pipes and connect a hose to the outlet its easy enough to find a fitting or something, but you may need to bend the pipes around a little but do not hurt them!, the crud buildup in the pipes will reduce your efficiency like if you use it with unfiltered rain tank water you would want to clean it about every 5 years on the other hand if you have hard water as in bore water then I dont know but I think calcium buildup will be your problem. hard water clogs up everything, disassemble and clean out water inlet manifold, there is a mesh screen in there, on mine it was in bits all through the ports clogging everything up. Now if needed clean over the whole unit with compressed air to spruce it up and reduce fire hazard or if your diy then it's nice to clean things before working on them imo. Don't ask me what all that would cost!
    You don't need to mess round with the gas side that's all fine.
    Now here's what you do to fix em, this is for a Bosch Hydropower 10H but I assume it probably applies to the other hydropower models too. Ok for those wanting more information the water flow runs the electronics @ 1.5v DC wich charges the high voltage pilot igniter but it also runs the 2 solenoids for the pilot gas circuit and that pilot circuit operates the diaphragm for the main gas valve. The thing is those 2 little solenoids are grounded through the whole unit, if you look it,s not great, so what I did was add a piece of wire say 5 amp should be heaps, now connect the wire to the fixing point for ground next to the electrical box and now connect the other end to one of the chunky screws that holds on one of the gas solenoids(DON'T REMOVE SOLENOIDS UNLESS YOUR REPLACING THEM THEY ARE VERY FRAGILE AND DON'T ABSOLUTELY DON'T UNSCREW THE SCREWS ON THE LITTLE COLORED PLASTIC BIT, That said I used the green one at the back, don't worry it wont leak gas as long as you only remove one screw but of course (>TURN OFF THE GAS<). Tighten up all the screws, again it doesnt hurt to go over the unit and check all the screws and bolts, there is one screw for calibrating the sliding knob also. And that's it turn on the gas and water and go test your brand new water heater!
    More info, you can test the generator with a multimeter, just unplug it and test the voltage with the water running through it obviously. Mine was about 1.6v
    You could also test the resistance of the gas solenoids with and without extra wire, etc.
    Fyi there is a brass screw about half way up on the left side of the unit facing out that I use to bleed the gas line, at least that's what I use it for. Just unscrew it a bit while its trying to light you just have to flick the switch a few times until the gas comes through then screw it up again.
    Also it doesn't hurt to go over everything with some soapy water in a sprayer to check for gas leaks especially if unit is old or if you can smell gas, I imagine if there was a gas leak inside the cover that would cause some issues.
    Anyway you wont believe how well it works after this mod, it ALWAYS starts as long as u have gas, it will stay lit at pretty low flow levels so you can mess round with the cold tap and it wont cut out to a point, I used to just have the cover off cos I was always messing with it trying to get it to light or tuning the knobs man it drove me nuts. Now I just leave it at the mid point between my summer and winter settings.
    I also disconnected the lights to help it work better but I think that's overkill. You don't really need to blast the hot tap anymore if you have enough flow it will just come on.
    Oh and if you still need or want to better control the temps then get plumber to install a tempering valve. The flow control knob I just have cracked open but I think If you have not enough pressure at hot tap you could open flow more and also turn up the heat more.
    P.S. my 10H was about 10yo when I serviced it.
    The Wizz.
We had this problem and no plumbers were able to fix it. Finally we got someone from Bosch around and they found part of the ignitor had been installed upside down, since then no problems at all.
Posted on Oct 17, 2010
Need help with Bosch hydropower 13h tankless hot water system
when you turn on the hot water tap there is a pressure switch in the line that sends a signal to a gas solenoid to pass the gas and at the same time to the pizo to start the flame
I would have that pressure switched checked as it may be sticking ( internal contamination) or have dirty corroded points
as gas is involved I would suggest a gas technician do the jib
when you turn off the tap, that pressure switch is shut off so the gas is turned off at the solenoid and the pizo is stopped.
May 21, 2015 | Bosch Water Heaters
Bosch hydropower 13h gas water heater not working
the tank is possibly full of gunk and the thermostat is not sensing the request for hot .flush tank if you can thru the bottom drain a few times if it is bad enough that ou get no water out then only option is to replace with a new unit
Bosch hydropower 10h won't ignite
The Bosch Hydropower units have poor electrical design, anyway assuming the heater is working properly, I would get it serviced for this that is <(TURN OFF GAS>), backflush water circuit, just unplug in and out water pipes and connect a hose to the outlet its easy enough to find a fitting or something, but you may need to bend the pipes around a little but do not hurt them!, the crud buildup in the pipes will reduce your efficiency like if you use it with unfiltered rain tank water you would want to clean it about every 5 years on the other hand if you have hard water as in bore water then I dont know but I think calcium buildup will be your problem. hard water clogs up everything, disassemble and clean out water inlet manifold, there is a mesh screen in there, on mine it was in bits all through the ports clogging everything up. Now if needed clean over the whole unit with compressed air to spruce it up and reduce fire hazard or if your diy then it's nice to clean things before working on them imo. Don't ask me what all that would cost! You don't need to mess round with the gas side that's all fine. Now here's what you do to fix em, this is for a Bosch Hydropower 10H but I assume it probably applies to the other hydropower models too. Ok for those wanting more information the water flow runs the electronics @ 1.5v DC wich charges the high voltage pilot igniter but it also runs the 2 solenoids for the pilot gas circuit and that pilot circuit operates the diaphragm for the main gas valve. The thing is those 2 little solenoids are grounded through the whole unit, if you look it,s not great, so what I did was add a piece of wire say 5 amp should be heaps, now connect the wire to the fixing point for ground next to the electrical box and now connect the other end to one of the chunky screws that holds on one of the gas solenoids(DON'T REMOVE SOLENOIDS UNLESS YOUR REPLACING THEM THEY ARE VERY FRAGILE AND DON'T ABSOLUTELY DON'T UNSCREW THE SCREWS ON THE LITTLE COLORED PLASTIC BIT, That said I used the green one at the back, don't worry it wont leak gas as long as you only remove one screw but of course (>TURN OFF THE GAS<). Tighten up all the screws, again it does'nt hurt to go over the unit and check all the screws and bolts, there is one screw for calibrating the sliding knob also. And that's it turn on the gas and water and go test your brand new water heater! More info, you can test the generator with a multimeter, just unplug it and test the voltage with the water running through it obviously. Mine was about 1.6v You could also test the resistance of the gas solenoids with and without extra wire, etc. Fyi there is a brass screw about half way up on the left side of the unit facing out that I use to bleed the gas line, at least that's what I use it for. Just unscrew it a bit while its trying to light you just have to flick the switch a few times until the gas comes through then screw it up again. Also it doesn't hurt to go over everything with some soapy water in a sprayer to check for gas leaks especially if unit is old or if you can smell gas, I imagine if there was a gas leak inside the cover that would cause some issues. Anyway you wont believe how well it works after this mod, it ALWAYS starts as long as u have gas, it will stay lit at pretty low flow levels so you can mess round with the cold tap and it wont cut out to a point, I used to just have the cover off cos I was always messing with it trying to get it to light or tuning the knobs man it drove me nuts. Now I just leave it at the mid point between my summer and winter settings. I also disconnected the lights to help it work better but I think that's overkill. You don't really need to blast the hot tap anymore if you have enough flow it will just come on. Oh and if you still need or want to better control the temps then get plumber to install a tempering valve. The flow control knob I just have cracked open but I think If you have not enough pressure at hot tap you could open flow more and also turn up the heat more. P.S. my 10H was about 10yo when I serviced it. The Wizz.
Oct 20, 2013 | Bosch Water Heaters
I have a instantaneous water system 10H Hydropower ...did not get a manual when installed....I need to have hotter water as it's winter and the water is like warm...not sure what to adjust...opened...
take the cover off the 10 h unit light up the burner by turning on the tap turn the water flow tap on the front of unit (white knob) clock wise slowly feel hot water pipe coming out off unit when temp increases put cover back on check temp at sink if too hot turn knob anti clock wise
May 23, 2011 | Bosch Water Heaters
I have a 16h Bosh hydropower hot water heater . The unit suddenly has no spark .I have taken off the little generater cap and thouroughly cleaned it and the internal turbine . With no improvement . All...
sounds like the generator has packed up. check water flow and clean any filters on the water line. you will need a service agent to check milli volts on generator and power pack
Dec 15, 2010 | Bosch 1600H-LP Liquid Propane AquaStar...
Hot water goes cold
Did you find a solution because I am experiencing the same problem, but only since i change to a new shower head?
Regards
Christine
Feb 07, 2010 | Bosch Cooktops
Bosch gas hot water system won't turn on
i have a bosch 16h hydroflow hot water system that will not ignite.
Mar 27, 2009 | Water Heaters
I have a 2nd hand Bosch HydroPower LPG hot water system and am trying to find a manual. do you have one or is it pretty straighforwward in terms of installation? Mike
I have just dug my manual out (16H) because mine is faulty. email me and I will photocopy it at work this week and email it back to you.
Installation should be pretty straightforward and the manual's not that in depth. There are however some sections on adjusting the gas and the like that you might want to read over.
mchankey at gmail.com
regards
Mark
Dec 04, 2008 | Bosch & Tankless LP Hot Water Heater
Our Bosch 16H Hydropower shuts off 30 secs to a minute after heating has started. We have used a variety of settings and only when we have the lower dial on minimum (fully anticlock) and the slider above...
Hi John
The manual is very limited in information it said to check there is
  • high water flow going through your system
  • and check your gas settings is correct!
  • The slide adjustment is your gas flow, which regulates your temperature
  • I have also increase the the gas regulator, which increases the gas flow
I have also been told its not a good idea to have a water saving head on your shower as this restrict the water out put.
Jul 03, 2008 | Heating & Cooling
Heating & Cooling Logo
3,920 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
