Compac n6000 usb port problem - Computers & Internet
    Problem Solver:
  • 6 Answers
The issue could be due to corrupt USB Driver. I will give you a few steps to re-install the Drivers.
Please perform the following steps to uninstall USB Port.
1. Right-click on My Computer icon and select Properties.
2. Click Hardware tab. Click the Device Manager button and double-click the Universal Serial Bus Controllers.
3. Select a device listed under Universal Serial Bus Controller, right-click and Uninstall.
4. Click Yes to confirm the uninstallation of the device.
NOTE: Repeat step 3 and 4 until all the devices under Universal Serial Bus Controller are removed.
The USB port is now uninstalled. Now, restart the system. The system automatically detects and reinstalls the USB port.
Step 2:-
Try the following update for the USB port.
http://support.microsoft.com/kb/822603
Thanks
Rajesh
Posted on Jul 13, 2008
How to Use Different Stand to Cooling the Laptop?
get a cooling pad / fan that runs off the usb port.
http://www.officeworks.com.au/shop/officeworks/p/deepcool-n6000-notebook-cooler-annbn6000
You know why they are called notebooks rather than laptops ?
Because they get really hot when placed on a lap !
Oct 18, 2016 | Computers & Internet
How to remove hard drive from fujitsu n6000
On the bottom of your Fujitsu N6000 laptop, find the hard drive door to access the hard drive.
2. Remove the Screws.
3. In this step, you will either need to pry out your Fujitsu N6000 hard drive caddy, or simply remove the door.
4. Once the Fujitsu N6000 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Fujitsu N6000 hard drive.
Good Luck
Aug 31, 2014 | Computers & Internet
How to change shutter speed
This is a link to the manual for the N6000 which is similar to the N6006 http://cdn-10.nikon-cdn.com/pdf/manuals/archive/N6000.pdf . Look on page 46.
Mar 06, 2014 | Nikon N6006 35mm SLR Camera
Compac computer won't turn on and the power light blinks constantly what can i do to fix this problem
Does it beep? if it does, whats the beep pattern...ie long long short, or short short short
if nothing else, something is causing a short...check the usb ports (real common) the contacts break from wear and short out, have your power supply tested.
Aug 20, 2012 | HP Compaq Presario SR1303wm PC Desktop
The screen on my Fujitsu Notebook N6000 just went blank
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 06, 2012 | Fujitsu Siemens Fujitsu LifeBook N6000...
How to have a bluethooth connection for my compac presario laptop
this model does not feature blue toooth by default, you will need to buy an extermal usb bluetooth dongle.
Jan 28, 2011 | HP Compaq Presario V2000 Notebook
Does a compaq presario 5000 support flash drives
Yes, it does.
The Compac Presario 5000 series have between 2 and 4 USB 1.1 Ports.
Note here that the ports are version 1.1, which is considerably slower that version 2.0.
USB 1.1: 12 MBits/second
USB 2.0: 480 MBits/second
Aside form the speed, they are both compatible with your computer.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Sep 26, 2009 | Compaq Presario 5000 PC Desktop
I hv problem with my hp compac d330dt it has lost the usb ports oparation what can i do to download its motherboard drivers?
Visit http://www.compaq.com and select your product and download the drivers. If you exactly know the model number of peripherals whose drivers are required, you can also download them from http://www.opendrivers.com (ehteshamhusain@gmail.com)
Jul 11, 2009 | Computers & Internet
How to hook up 6210 printer to compac presario computer?
Your printer has a USB aside from the PicbridgeHP PCL3 connection so you should be able to install it in any computer with a working USB port.
Nov 05, 2008 | HP OfficeJet 6210 All-In-One InkJet...
My Lexmark x75 cant not comunicate with my compac pc. computer Cant you help me pleas
  1. THERE MAY BE THE PROBLEM WITH USB DRIVERS IN UR PC .
  2. TO RECTIFY --- RIGHT CLICK THE MY COMPUTER ICON
  3. CLICK PROPERTIES AND THEN CLICK HARDWARE N GO TO DEVICE MANAGER
  4. UNINSTALL ALL USB PORTS AND THEN SCAN FOR HARD WARE CHANGES
  5. UR PC WILL DETECT UR PRINTER N ASK FOR PRINTER DRIVERS
  6. RELOAD DRIVERS N UR PC WILL COMMNICATE WITH UR PRINTER.
  7. FOR FURTHER ASSISTANCE FEEL FREE TO ASK AND WISH U SUCCESS -BYE.
Jun 03, 2008 | Lexmark Office Equipment & Supplies
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
