Cant sign on messenger,but need no proxies for wecam
  • dave boy Jul 13, 2008
    thank you for getting back so soon,thought it may have had some thing to do with my fire wall settings i changed the setting for messenger,and found it now works ok,had problem connecting with webcam on as it needed no proxies,was the fire wall holding it back,have signed in and out a few times with no proxies and seems to work ok,many thanks for contacting me.
    daveboy
  • Rajesh Durai
    Rajesh Durai May 11, 2010
    Hi, do you get any error message when you try to login? May I know the operating system and the messanger you are using? Let me have the exact error code and the error message. Have you tried different messanger?>
    Problem Solver:
  • 6 Answers
Wow! that is great. you have done a good job. Always welcome. Take care.
Posted on Jul 13, 2008
Yahoo messenger has stop working on my pc
my advice is to remove that yahoo adn download it again
adn if it doesnt sign in when you do download it follow these steps because it worked with me
Click the "Messenger" menu and select "Connection Preferences."
Select "Firewall with no proxies."
Click "Apply." You should see a message asking you to sign in again.
Click "OK."
Enter your Yahoo! ID and password, then click "Sign In."
OR,
- Go to messenger right click and select Property
- Under Compatibility Tab
- In Privilege Level check Run This Program as Administrator and in compatibility section choose XP SP2
- Thats it now it should run Fine!
OR,
try using pidgin. its an open source messenger that you can use to run yahoo, aim,msn, icq, and more. you can have one consolidated list of contacts. comes standard with most linux distributions, and you can download it for windows.
Oct 27, 2012 | HP Computers & Internet
I cannot sing in to yahoo messenger
there may be several problems with your messenger
before anything chek that you are connecting to internet and your username and password are correct .
then:
1) check your proxy setting in internet explorer
(in IE menu go to tools/internet option/connections) then if you are dial up , double click on your account and desable proxy. if you use adsl you must click on "Lan setting" and desable proxy
2) in yahoo messenger's menu go to "connection perference" and "connect directly to the internet" must be cheked
3) check that your anti virus is allowing to your messenger (usually it's done automatically) ;)
4) if the problem still persists , reinstall yahoo messenger
Jun 27, 2011 | Computers & Internet
I cant sign into yahoo messenger
first, make sure your entering the right information in the username and password boxes.
I know it sounds dumb, but it had to be said.
if it continues to have problems, go into your yahoo email and try signing in from the email program
there is a link up near your login name.
if you get into your email, theoretically you should be able to sign into chat.
I would change your password for messenger and try logging in again.
is it possible someone was trying to get into your messenger and saved a wrong password,
go to login screen on messenger and erase your password and type in your correct password.
and login.
if you still continue to have problems, either update messenger or reinstall the messenger program and see if that works for you.
Good Luck
Jun 03, 2009 | Gateway GT4024 PC Desktop
Error81003005
See below
Hope this helps
Here's how I solve it:
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
My solution is good only if you have set your proxy server previously in your Internet Explorer. I've noticed this behaviour since in our school, I need to set the proxy server to access the internet. But at home, I don't need to. So when I am at home, this is the normal situation I encounter when I forget to unset back the proxy settings.
On the other hand, the other way around should work. What I mean here is, if you connect to a network that has a proxy server, you need to setup the proxy settings in order for you to use their internet services. Thus, access to yahoo could be established.
[Solution #2]
One area to look also if the proxy is not the one causing the problem, you can check if you have your DNS Server address(es) set, which - in case you have changed your network, can't be accessible to the new network. Thus, it can cause this error.
So, you may unset the DNS Servers (Go to Network Properties >> General Tab >> TCP/IP Properties >> General Tab > Obtain DNS Server address automatically) and try logging in your YM.
[Solution #3]
If the above solutions does not go well, this last one might be the savior. Instead of constantly banging your heads with those re-logins and reconfigurations, you can track back your YM version and replace it with an old version instead. I did this and it works for me well. I had before a version 9 Yahoo Messenger and when I replace it with a version 8, the problem was solved. This should be your last resort if the previous won't work. Remember also to be patient. If it bugs you, don't bug down... bug up!
Dec 30, 2008 | Computers & Internet
I cant log in to msn live. it says it has an error code 81000306.
Error: 81000306 1. Make sure that you are connected to the Internet. Start Microsoft Internet Explorer, and then try to visit the following Web sites:
Messenger service status Microsoft web site If you cannot visit these sites, contact your Internet service provider (ISP) for information about how to set up your Internet connection so that you can visit both secure (https) and non-secure (http) sites. 2. If you are able to visit the Messenger service status page and notice that there is a service issue, please visit the site later to determine when the service is available so that you can sign into Messenger. If the site indicates that the all systems are stable and running, go to the next step.
3. Clear the proxy settings in MSN Messenger. 3.a. Start Messenger.
3.b. On the Tools menu, click Options.
3.c. Click Connection in the left navigation pane.
3.d. Click Advanced Settings in the Connection Settings section.
3.e. Delete the content of the SOCKS field.
3.f. Click OK two times to save the settings.
3.g. After you clear the proxy settings, verify if you are able to sign into Messenger. If you are still not able to sign into Messenger then please go to the next step.
4. If you are using Windows Vista, disable the Auto Tuning Networking feature: 4.a. Click Start, click All Programs, click Accessories, and then right-click Command Prompt and choose Run as administrator.
4.b. Click Continue when Windows requests permission to continue.
4.c. At the command prompt, type the following command, and then press ENTER: netsh interface tcp set global autotuninglevel=disabled
Note: This command disables the Window Auto Tuning feature. 4.d. After you disable the Auto Tuning Networking feature, verify if you are able to sign into Messenger. 5. If you are still not able to sign into Messenger then please re-enable this feature using the information below and then go to the next step. 5.a. Re-enable the Auto Tuning Networking feature by typing the following command at the command prompt, and then pressing ENTER: netsh interface tcp set global autotuninglevel=normal
Note: This command enables Window Auto Tuning again so that you can take advantage of the network throughput performance increase it provides.
6. If you are using Windows Vista and you also use a router (eg. Linksys, D-Link, Netgear) on your home network to connect to the internet please visit the router manufacturer’s website to update to the latest firmware for that product.
RICHARDM69
Dec 04, 2008 | Computers & Internet
I cannot get logged into yahoo instant messenger. When and if I get logged in, I'm cut off at 11 p.m. every night. I downloaded the 9 but still doesn't help. thanks, lavina
You may want to contact your Internet Service Provider and ask them if they block out Yahoo Messenger service. Also an option under Connection Preferences before you sign in to your Messenger, where you can set it to Firewall with No Proxies. You select what type of internet you have below and hit apply. This will however disable some features such as file sharing, and possible webcams.
Windows live messenger sign in error code 81000306
That means Windows Live Messenger is unable to contact the authentication server.
Open up Live Messenger and go to Tools and go to Options. Under Connection Settings, choose Advanced Settings. Make sure there are nothing in the proxy fields. Make sure the SOCKS area has nothing in it and click okay until you get back to the Messenger window and try to sign in.
If that doesn't work and you are running Windows Vista, click start, type: cmd, right-click cmd.exe when it appears under Applications, click Run As Administrator, type the following: "netsh int tcp set global autotuninglevel=disabled", rress enter, restart your computer”
Hope this helps!
Oct 18, 2008 | Computers & Internet
When i log on it says Messenger encountered a connection problem. Please check the network connection and then click try again (81003004)
Is this Yahoo messenger? if so,try this:
Click messenger / Choose connect via a proxy server/choose http proxy
Joe
Oct 09, 2008 | Computers & Internet
Error code 80072ee7
This error occurs when you are not connected to the internet, check your internet connection and make sure it is working properly.
The most likely cause for this problem is that your firewall does not allow Messenger to access the internet. This happens often if you install a new version of Messenger. Make sure Messenger is allowed access in your firewall rules. See our article on using Messenger through a firewall application.
This error might also occur if a proxy server is enabled in Messenger or Internet Explorer while you do not use one. To remove the proxy settings, click the "Tools" menu and then "Options..." at your Messenger main window. Then in the options screen click "Connection" in the list to the left. Next, click the "Advanced Settings..." button. You can try and uncheck all checkboxes in this screen except the one labeled "TCP" to let Messenger connect through a direct connection. If that does not work you can restore the settings again by checking the boxes you unchecked before.
Source
Please rate this solution.
Sep 20, 2008 | Computers & Internet
Error code 80048820
MSN Message error 80048820, unable to signin
Problems:
- While you try to Sign in MSN Messenger you getting an error message with the no. 80048820
- Unable to Sing in
Probably reasons-
- Your system time/date incorrect
- Internet Proxy setting incorrect
- softpub.dll disable/missing
- Firewall does not allow to access, etc.
Solution-
Step#1
- Remove Internet Explorer proxy server settings and check the 'Automatically detect settings'.
- Launch Internet Explorer, click "Tools" and then click Internet Options. From the Internet Options dialog box, go to the Connections tab. Click LAN Setting. Uncheck the Use a proxy server for your LAN checkbox. Finally tick/check: 'Automatically detect settings'.
Step#2
- Correct the computer system's Time/Day as current (if required).
Step#3
- Click Start (Button), and then click Run, type regsvr32 softpub.dll click ok.
Step#4
- Turn off the firewall. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
Reference from:
http://www.trulybangladesh.com/itnews.php
Aug 12, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
