Question about Toshiba Computers & Internet
Toshiba 4010 is giving me a "warning, problem with the cooling system message" Machine gets real slow. How can I inhibit this message, I have it on a cooling pad?
    Problem Solver:
  • 6 Answers
The electrical components in a PC generate heat, and fans inside the PC help move the air to keep the components from getting too hot. Excess heat will cause the fans to run constantly, damage components, and limit the speed of the CPU. All of these problems with high power and high heat will cause applications to work slower than normal. One of the main functions of the BIOS is to monitor the temperature and adjust the operating conditions. While the sound of the fan running all the time can be annoying, it may the first clue that your PC is running as efficiently as possible. To help your PC as cool and as efficiently as possible, do one or more of the following corrective actions.
  1. Update the BIOS
  2. Keep air vents clear and clean
  3. Minimize disk operation
  4. Minimize CPU operations
  5. Check whether FAN is enabled in BIOS
Thanks Rajesh
Posted on Jul 13, 2008
What does high CPU usage mean?
Most times the hard drive is full, delete any thing you don't want ,to free up space . increase ram to four GB if you can. Get rid of add-ons Run a anti virus programe.
Mar 06, 2015 | Computers & Internet
My cooling system keeps giving error messages
you have to service air vent and check cpu cooler fan is working.
Oct 01, 2017 | Toshiba Portege R705P35
"A problem with the cooling system has been detected."
have you tried blowing out the internals of the notebook with compressed air? if the laptop is not actually overheating it could be a sensor problem. if that's the case you can more than likely disable these warnings in bios. hope this helps!
Jan 27, 2012 | Toshiba Qosmio G25 (G25-AV513) PC Notebook
Sony VAIO Laptop does not shut down with message "Please do not unplug updaing 11 of 55"
that message is from the automatic updates windows makes from time to time ...and this message usually appears after a fresh install with the operation system out of date ..and if you have the automatic updates ticked for to be made automatically ..The thing to be done is either let it install the updates...and it will shut down by itself...or ..start windows..and go to control panel ..and on the automatic updates...stop the updating process..This will cause a message to appear in the tray system every time ..to warn you that your computer is out of date ..and so ...but it has no real distress cause it will run like a charm even without the updates...(probably even faster ..cause if your computer is a little limited in resources the updates will slow it down a little ..
So ..this message is not a pest ..but the windows updating your operation system ..the only issue is when it is in error and takes more than the time it should ...usually it should not take more than a couple of hours for all 55 updates to be installed ...and this in case you have a slow computer...
Nov 04, 2011 | Sony VAIO Notebook
I have bought a new toshiba A665 a week ago. I have a problem saying. ' A problem in the cooling system has been identified. Switch off ur computer and return it for service.' Cooling fan is working but...
At a week old, get a replacement or fix it right away. Fix should be free, but no computer during service.....
Toshibas run too hot, in my opinion.... so you have to keep after the fans and keep lint cleaned out of it....
Overheating will yield un stable system,
Feb 26, 2011 | Toshiba (K000831860) Cooling Fan
I have got warning of "cooling system has been detected" and system performance is too slow. How to fix that problem?
If are using the desk top pc so can change the cpu fan.
When you use the laptop set the fan control disable if the system have in your BIOS, just do it from BIOS,and save it .
Hope it will solve .
Dec 24, 2010 | Toshiba Computers & Internet
Warning comes "cooling system face
Hi. Thanks for your question.
  • Well it seems that you have a cooling problem. It could be caused by many things.This warning may be displayed when system reaches dangerous for components temperature. You can do few things to prevent this from happening.
  1. Make sure laptop is always used on flat surface with it's vent holes not being blocked. People often use their laptops in beds or carpets which causes them to overheat.
  2. Make sure that any vent holes are clear of dust and dirt. If needed use small brush to remove dust. For best results brush + compressed air combination should be used.
  3. If all this isn't case you need to make sure that you can hear fan spinning. This could be a hardware failure and running your laptop like this could lead to permanent damage. ( if your fan isn't running please see this video to get an idea of where it is and how can it be replaced)
utube.png You-Tube video "i3T6om0UA-w" placeholder (do not delete) utube.png
Please do not hesitate to ask more questions if this is needed. Thank you for using FixYa
Dec 13, 2010 | Toshiba Satellite Laptop Cooler
How to fix my Toshiba laptop in cooling system please ?
you probably need to clean the cooling fan...it collects dust over time, and doesn't move the warm air out as it should...its fairly accessible by removing the bottom case cover...please rate my response.....
Jan 29, 2009 | Toshiba Satellite 1715XCDS Cooling Fan...
System warning pop-up
Are you sure that nothing is overheating? If your cpu fan is turning too slow it won't disipate the heat. Do you have a program showing cpu temp:? I would take the access off the bottom and make sure the cpu fan is clean. If that is not the problem I believe you can turn the warnings off in the bios settings
Jun 08, 2008 | Toshiba (K000016310) Cooling Fan
How to goto cmos setup in toshiba portege 4010 laptop
I guess by now you have either binned the machine or have found out how, but for anyone else reading this you press the "Esc" key as you power up.
Mar 28, 2008 | Toshiba Portege 4010 Notebook
Computers & Internet Logo
151 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
