Question about Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C)
Wireless connect Im having problems receiving wireless connect.How can I fix it?
    Novelist:
    Scholar:
  • 125 Answers
Make sure device is installed all drivers. Unplug, restart computer. Plug device back in and let windows reinstall device. One reinstalled restart computer and see if detects the system. I have answer another post tonight with the same device so go into igi_57 solutions and find other post for directions on how to go about connecting through the wireless window manager. Let me know if you have problems.
Posted on Aug 10, 2008
SAMSUNG SWA5000 Wireless Receiver Module stopped working **help help**
HiI have the same problem, have you found the solution?
cheers,
Dec 29, 2011 | Samsung SWA5000 Wireless Receiver
Blinking status
talk to your wireless manager about your problem. once my laptop didn't receive connection, and it took them a week to fix the problem and get the internet back.
you can also try unplugging the cable ot restarting the computer.
i wish you good luck.
Jul 26, 2010 | D-Link DI 514 Wireless Router (DI-514)
Wireless USB works, but mouse itself doesn't
Sir/Mam good day,
Is your mouse device also wireless? you need to resync it with it's receiver,
you may follow the methods below to make your wireless usb mouse works.
You need to press the button on your wireless mouse receiver, and make sure that the light on your wireless mouse
receiver blinks. But you need take note that some newer model of microsoft devices are permanently fixed to their receiver
and can't be reset. If your devices don't have a button, here's what to do:
If a dialog box appears on the screen in how many seconds, you need to follow the instructions from it. Or else, you need
to do this:
press and release the connect channel button on your wireless mouse, and make sure that the light from your receiver works
and the status on it's light is steady. If this happens then the synchronization is successfu. But if the problem is still
the same you need to repeat the previous steps once again.
As for the wireless mouse for notebook, this problem come out when the micro switch on the underneath of the mouse was not
released. You can use a pencil or anything with a sharp point to released it.
There are a lot of options why your wireless mouse receiver won't work, and a lot of solutions. Here's some of them:
*Try different ports on your computer, if the connection to some usb ports are not working you can connect to other ports
and see if it will work.
*And also the cables that are included with the wireless receiver, try to use another cables if the
device is still not working.
*If you're device is connected to a usb hub, disconnect it from the usb hub and directly connect it to
the available ports on your pc and see if it will work.
*When fixing this type of problem you need to have only one usb device
connected to your computer, which is in this case, your usb wireless mouse.
*When you have other usb devices, you need to
plug it out.
*If the methods mentioned previously still won't work, you need to reinsert your
wireless mouse batteries or install a new one.
*Another possible remedy to this problem is checking the interference, your wireless
usb mouse together with its receiver should be a distance away from anything that
transmits signals such as cellphones, radios or other similar devices. And also
any metal objects. because such things might interfere with the signal of your
wireless mouse.
* If the problem persists after doing all of the above steps, maybe it's time to update
your wireless mouse drivers, For installing latest driver update with your wireless
mouse, see the documentation that is included in your wireless mouse.
* If all of the methods above did not solve your wireless mouse problem. You can
connect your wireless mouse to another working computer to see whether the problem
lies with your wireless mouse or to the computer which your wireless mouse is
connected.
Final instruction:
If all of these methods fail, you better have your wireless usb mouse be check
by a professional computer technician in order not to further damage your device.
Hope this helps. Good luck and God bless
http://online-pcrepair.blogspot.com/
Jan 11, 2010 | Silver Jeans 1660-13SL Mouse
I can't get the video to work on the wii using the red, white & yellow cables. Will component cables fix my problem?
Your post indicates the use of a receiver. If you are in fact using a receiver, make sure you have a "video out" connection from the receiver to your television. Then make sure you have the correct input selection on the receiver, and on the TV.
Dec 28, 2009 | Yamaha RX-V463 Receiver
My pc acer keybrd just went stpid on me
At the usb port you have an item plugged into it that receives signals from the keyboard and mouse, push the connect button, if not go straight to your mouse, turn it over and push the connect button.
If you had to press the connect button on the receiver and the mouse if it had lights on it that was blinking it will stop if not check batteries.
Then and only then press the connect on the receiver then the keyboard and not the other way around. If there was a connect button on the receiver and you did this operation the lights will stop blinking and all should be sweet, if not replace batteries.
Hope it helps.
Sep 06, 2009 | ViewSonic Wireless Keyboard and Mouse...
Wireless connection problems, not receiving packets.
Goto Network Connections >> Right Click on the wireless icon >> Properties >> Select IPv4(or IP for XP) >> Click on Properties >> Now see from your friend's system(in the same way) if here the details entered MATCH. The DNS entry shud match here.
May 25, 2009 | Google Chrome
Wireless keyboard stopped connecting to receiver
Im sorry but you are going to have to phone and tell the device manager the problem again otherwise get a refund and go with the wired keyboards!
Hope this helps - JoshHoward
Feb 02, 2008 | Logitech Deluxe Access Keyboard
Belkin G+ wireless receiver
you will need to set up the router first, with a wired connection.  Write down the wireless settings for setup later.  Then setup the wireless receiver on the PC with the same settings that you had on the router.  You should remember that distance, obstacles, etc. will affect a signal.  Also, remember that you may not be the only one in your area with a wireless network, so remember to change the channel on the router to something other than the default, and set up security, at least WEP.
Oct 18, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Open Questions:
Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C) Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
