Question about Mercury P4VM800M7 Motherboard
System automaticaly off
my system automatically turn off after one hours,i am change os,smps,data cable etc .But no change this problem
  • 24 Answers
Fiend your solution direct from mercury. Here is your solution.....
Posted on Sep 03, 2009
  • 395 Answers
Change Power settings in Control Panel.
Posted on Aug 17, 2008
  • 36 Answers
due to over heating this problem can happen. (if processor fan not working properly or heat sink not properly seated) check cpu fan. heat sink it properly seated or not. remove fan and heat sink and install properly use heat sink component (a white colour gel). also check power management setup in ur os.
Posted on Jul 13, 2008
Dell inspiron m5030 keeps turning it self off
This problem is due to the following:
  • Your computer is overheating
  • Critical problems with your registry
  • Critical state of the system files
  • Hard disk data cable and power cord are loose
  • RAM is not properly connected
  • Problem with the SMPS connections
For fixing computer automatically shuts down issue, you shall remove the motherboard and reconnect all the connections. Take help of a hardware expert while doing the task.
The solution to fix computer automatically shuts down is to download and run a good and reputed Registry Cleaner software, use RegInOut to fix this problem.
Jan 03, 2012 | Dell Inspiron M5030 Laptop
1 beep and restart automatically
According to your problem first check the SMPS of your system. To check the fault first try to turn your system on by a new or good conditioned SMPS. Check the RAM also. Open the RAM out from slot makes it clean from dust & moisture by an eraser, and then install it again. Check the reboot switch also. May be the OS of your system is corrupted. Repair the OS with the Operating system disk by repair option. If anything doesn't help you then may be this is the fault of your system motherboard. Then you have to check this properly and repair it.
Jul 04, 2011 | Computers & Internet
I would like to remove Windows7 and install Windows Vista. How do i remove Windows7? Thanks
Hi ,
Just launch the Vista install disc , it will automaticaly erase Windows 7 and install a new fresh version of Vista .
Caution : Back up your data and especially the drivers before proceeding .
Best regards .
Feb 10, 2011 | Computers & Internet
is ur Win7 a proper licenced one ?
if yes...then just register in MS wesite and update you Win7 OS...the driver required will automaticaly updated from MS...
Nov 01, 2010 | Computers & Internet
Computer suddenly shut down and won't restart
This type of shutdown problem occurs mainly due to following few reasons, 1) SMPS problem 2) RAM failure 3) Over heated mother board chip(s) or seldom over heated CPU 4) Virus or worm problem or OS problem. 5) Over heated power cords
Do the following steps one by one (to detect the exact source of problem) First replace the CMOS battery, change SMPS, check power cord, run the PC directly (without UPS), remove the data cable from hdd. if it runs well then set the data cable with hdd, if it does not work then definitely there is mother board/cpu problem. And if it creates same problem after fitting the data cable - change the hdd or format hdd and reinstall os. your problem would be solved.
Jun 05, 2010 | Gateway GT5465E Refurbished Intel Desktop...
Driver installed automaticaly in w7 but doesnt print
1st You should download proper Printer Driver. sometime windows don't install proper Driver Here you can download Driver Epson LX Printer Driver After this install the Printer driver in the system.
Installation of Printer Driver Go to the control panel Click on the System Icon Click on the Hardware Tab Click on the Device Manager then Select the Unknown Device or printer device where yellow Question Marks sign on it. Right click on it and uninstall it. After this go to the top of the device manager and click on scan for hardware changes. Driver installation Wizard start. Brows Your Driver from the Hard Disk and click on next. Driver will be install.
May 07, 2010 | Epson LX-300+ II Matrix Printer
My computer sarts automatically when I want to shut down
it seems that your computer restart when you attempt to shut down. this problem due to short in power button in the cabinet. open the right side of the cabinet.most probably there will be red&white twisted thin wire from front panel for power, the colour may vary manufacture to carfull with it. see at left bottom of your dell PC mother board the wire will lead to two pin specifying power, restart, hdd etc.. short it with your screw driver. if system turn on then it is problem with switch replace it or if it not work then reboot the os.
Oct 24, 2009 | Dell OPTIPLEX 745 PC Desktop
Computer Restart again and again
remove the cmos battery from the motherboard for at least 1 hour then replace , if it continues to reboot it may also be your hard disk or os causing it
hope this helps
Jan 05, 2009 | ASUS P5LD2-VM Motherboard
Mercury P4VM800M7 Motherboard Logo
97 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
