Question about Dishwashers
Dishlex global 200 dishwasher. Eco button stays on and dishwasher continues to drain even without water. What is problem and how do I fix it?
    President:
  • 1,462 Answers
Bottom pan has probably got water in it. take off the bottom plate so you can see inside. disconnect from elec and mop water out and it will start. if problem re-occurs then you have a leak
Posted on Jul 13, 2008
  • Angus Ingham
    Angus Ingham Sep 09, 2011
    Fixed my problem perfectly. Cheers tresilla!
Dishlex Global 300 starts to fill with water, then
ok this sounds like your water has stopped coming in or timed out b4 the pressure switch is activated. hold eco button down, u will hear a beep then a light will come up, keep pushing the button until u see the light.reply and tell me which light has come up, and i can help u fix the problem.
Apr 24, 2010 | Dishwashers
Our Dishlex Global 300 appears to be stuck in Pre-wash. The Eco light is flashing and the water has drained. All other buttons are unresponsive. I have just replaced the seals and handle assembly.
If your getting 120 volts to your dishwasher, I would first ohm out your thermal fuse for continuity, turn your breaker OFF to your dishwasher first.
Jul 24, 2008 | Dishwashers
Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Jan 25, 2010 | Dishwashers
Pump motor runs continuously, ''Eco'' flashes continuously
Hi
soyunds like it flooded the base
You need to dry out the base of the machine thoroughly and it should re set
Feb 14, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Dishlex global dishwasher, stuck on eco, eco light flashes and drain pump runs
Try turning the taps on harder, I read that someone else had the same problem and this fixed it for them.
Aug 18, 2008 | Dishwashers
Dishlex dishwasher global 300. Dishwasher continues to drain with ECO light flashing. Service manual says it is due to an incorrect fill level or fill line.
Some diswashers have a sump in the bottom with a float switch. If the water level overflows the float will activate the switch which will kill the machine and run the drain pump continuously.
Jul 01, 2008 | Dishwashers
Dishlex 450
I had this problem and reset the dishwasher to solve. Turn off dishwasher for at least 20 seconds, turn on while pressing eco button and wait for about 30 seconds. Should hear beeps.
May 05, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Dishwashers Logo
212 people viewed this question
Top Dishwashers Experts
