Question about Nokia 6230
Nokia 6230 after installing some application its showing tat an error message tat out of memory.......
  • 983 Answers
This happens due to the firmware problem(this may be due to virus attack) ....
try giving the restore factory settings in your phone ...
if you still persist the problem then you just update the firmware of the phone that solves your problem ....
you can update the firmware with the normal datacable only ...
you can update to the latest firmware for your phone from the software called" Nokia Software Updater "...
you can download this for free from the website of nokia directly given below :
http://europe.nokia.com/A4579163
(your pc must be connected to net to download the latest firmware)
but remember dont disconnect the cell while updating the firmware is in process if you do so your phone will be severely damaged you can never use your phone ...
even the manufacture can t help with this if you interrupted during the firmware update ....
after you update the firmware all your problems will be solved ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Posted on Jul 13, 2008
How can i put a themes in my nokia n95 8gb?
Hi
Before installing any software go to
Menu> App.Manager> Options> Settings> Software Installation
In Software Installation make it ALL. This change is important, otherwise you will get an Error message Certificate Error. Contact the application supplier while installing most freeware
Also, if you see that some old themes are giving the Expired Certificate error, simply change the date of your phone to year either 2005 or 2006 or 2007 (check all as each theme has a different expiry) before installing the theme. After installation you can change back to today's date.
Now, here is the way to install themes and other applications in your Nokia . I use the USB Cable to do the installations.
1. First install the Nokia PC Suite software on your computer from the CD which you recieved with your Nokia
2. After Nokia PC Suite is installed in your PC, connect the Nokia to the PC with the USB cable which was provided in the box.
3. When the USB cable is connected, Nokia PC Suite will recognise that a phone is connected. You will then see an option on your phone?s screen asking if you want to connect via PC Suite or Data Transfer. Choose PC Suite.
4. Now, simply download the .sis or .java files (themes & applications) to your computer and Right Click on it with your mouse. You will see an option saying Install With Nokia Application Installer
5. Click Yes on the PC, and then Yes & Continue on the Phone when you see the prompts.
6. The phone will then ask you if you want to Install the Theme or Application in the Phone Memory or Memory Card.
I strongly recommend Installing themes in the Phone Memory! This helps in avoiding complications later on when Uninstalling.
When I first bought the Nokia N95, I made a mistake which a lot of new S60 3rd Edition users make, that is, I installed the Themes in the Memory Card instead of the Phone Memory. This was a huge mistake!
There is a bug in the Operating System of all S60 3rd Edition phones, due to which, if the theme is installed in the Memory Card, it cannot be deleted or removed, as it then does not show up in the Application Manager.
Ever since that mistake, I have made sure to always install themes and softwares in the Phone Memory, instead of the memory card. Yes, it eats up space on the phone, but it's worth it, as then it is easily removed as well.
And that's it, the theme or application is now installed!
Thanks for using Fixya.
Mar 14, 2011 | Nokia N95 Cellular Phone
I have not installed much applications on my nokia
Goto message setting and select the memory card.
Now all the messages stored in the memory card.
It defenitly works...
Rate it....
Mar 02, 2010 | Nokia N73 Cellular Phone
I keep having an error come up saying Messaging: Memory full close some applications. I have also had an error saying General: Memory full close some applications. I have no applications open can you...
clear your browser cache as well
set your messages in messaging - options- settings - other to 999 and e memory.
restore factory settings *#7780# default code is 12345 that might just might help you a bit and turn off and on your phone when you do all these things see if it helps any.
“Memory Full…Close some applications and try again” is a normal
message that usually comes on Nokia N70. It showed the memory used in the phone doesn’t have space anymore. But if the message still appears although the user already closed some applications it can be theproblem.
Someone who experience in this memory full problem said, an error message of memory full like above is appears each time he’s opened the
Camera. It also happens for a few times when he’s trying to open
messages, Gallery, or other applications. And then it will force to restart the phone.
Seems like it’s a RAM problem and might there are some applications unable to close completely. If your Nokia N70 phone has gone a start
menu button you can try to hold it down. This way will show you
everything that you have open and they can be closed easily so that
you can continue to take your photos.
So if it can resolve the problem you can reset/format by pressing *#7370#
Oct 30, 2009 | Nokia N97 Cell Phone
Phone memory
change your n70 message memory to memory card.... click on MESSAGE,OPTION,SETTINGS,OTHER,MEMORY IN USE, then change it to MEMORY CARD.. With thats u will be able to send meseges. thanks
Dec 31, 2008 | Nokia N72 Cellular Phone
MEMORY FULL IN PHONE
Just Reset Your Mobile Phone Settings RESTORE FACTORY SETTINGS
Automatically Remove all errors from your mobile phones
Before resetting Backup your Contacts Massages and All Gallery
Awais Shahid
Dec 29, 2008 | Nokia N72 Cellular Phone
Need puk code for 6230i nokia
call ur mobile service customer care number and ask ur puk code from them...they will ask ur last 4digit sim card number...give tat number to them...they will give puk code ...use tat code and continue ur operation
Nov 28, 2008 | Nokia 6230
Themes and installing application
download nokia pc suite....and download some themes or application at mobile9 for symbian 60
Apr 29, 2008 | Nokia 6230
Applications in nokia 6230
Dear friend , No applications will be supported by N6230. Regds Hema.
Sep 22, 2007 | Nokia 6230
Nokia 6230 Logo
97 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
