SOURCE: the fan is running, the fridge trys to start the
That sounds like short cycling and could be defective compressor start relay, overload and Capacitor need to be replaced. The longer it tries to start the hotter the compressor gets so I believe until these parts=> 67005560 Start Relay With Overload and Run Capacitor 65889-4 are checked or replaced you need to unplug. It also could be your compressor is not in good shape. If you would like to test your compressor follow these instructions here=> Whirlpool Products The location for these parts are here=> Maytag MFD2560HES and in photos part 10 and 11. I will assist you in any way if needed, Thanks, Sea Breeze
Make sure both fans run at all times compressor runs because fans do not always stop when they go bad. They run when they want to.
