Question about Olympus FE-210 Digital Camera
Black screen hey i bought my olympus fe 210 for my birthday and i was taking pictures for about 30 days. when it came to christmas i was taking a lode of pictures. i did not drop the camera or do anything bad to it i just kept it safe but when i woke up the next morning the screen was black i waited till know and checked other dates but it has not changed i have tried to replace the batteries and memory card but nothing happend i dont whant to spend money on some repair man because its stupid but i dont whant to buy a knew one help me find a free way to fix it
  • 958 Answers
Mine is almost the sameproblem. if i shoot, thre is just black screen, and the pictures taken were also black. but i could still see the old pictures that i took if i look at therm at the screen, i brought it to a tech and they replaced the whole lens assembly. and now everyhing works fine.
Posted on Jul 16, 2008
I have an Olympus FE-230 and it suddenly starts taking black and white pictures. I don't know what I did, but how can I get color back?
I have had my Olympus FE-210 for about 2 1/2 years just recently it started to display an all black screen after I took pictures and like many of you I would turn it off and back on just to get 1 picture out. After testing it over and again I may have solved the problem: First: remove all of the pictures and memory card from the camera Second: go into the menu and find the reset button it will then display that the camera will return to default(factory setting) after I did this I was able to take over 35 continuous pictures using every setting and scene setting the camera has If this doesn't work I would suggest buying a new camera Hopes this helps!!
Jun 11, 2009 | Olympus FE-210 Digital Camera
My olympus fe 210 has the lcd screen broken, I would like to fix it by myself, how to replace it?
Hello Fabio,
You can find the replacement LCD screen for Olympus FE210 here:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ObjectPath=/Shops/160419/Categories/Olympus
Jun 01, 2009 | Olympus FE-210 Digital Camera
Digital camera won't take pic
HELLO NEWFIE,
YOUR CAMERA HAS A VERY COMMON PROBLEM THAT THE FE-210 HAS. YOU MUST PAINSTAKINGLY TAKE APART YOUR CAMERA PIECE BY PIECE. MAKE SURE TO CAREFULLY REMOVE THE SMALL SCREWS THAT ARE UNDER THE COVER PLATES FOR THE USB, VIDEO OUT AND DC INPUT SLOTS. ON THE RIBBON FOR THE FACE AND THE LCD, YOU MUST "LIFT UP" ON THE RIBBON LOCKS. SOME ARE BLACK AND LOOK LIKE A TAB AND SOME ARE WHITE AND LOOK LIKE A "PUSH IN" TYPE OF LOCK. THEY BOTH SWIVEL "UP", NOT PULL OUT!!! RETAIN THE WHITE LOCK AS IT WILL NEED TO BE PUT BACK IN THE SAME WAY. ONCE THE FRONT COVER IS OFF, REMOVE THE LCD THE SAME WAY. IT WILL HAVE 2 SCREWS IN OPP. CORNERS AND A RIBBON WITH A BLACK LOCK. ONCE THE LCD IS REMOVED, REMOVE THE MAIN BOARD BY REMOVING ALL OF THE SCREWS IN THE CORNERS AND THE ONES THAT HAVE "GOLD" AROUND THEM. THERE IS A SMALL SCREW UNDER THE DOOR FOR YOUR BATTERIES, DO NOT FORGET TO REMOVE THIS ONE ALSO. NOW, LIFT THE MAIN BOARD UP SO THAT YOU CAN SEE THE SMALL GOLD GEAR NEAR THE SHUTTER OPENING. TAKE A SMALL SCREW DRIVER, SUCH AS THE ONE YOU HAVE BEEN USING AND ROTATE THE GEAR. THIS WILL FIX YOUR PROB. NOW REVERSE THIS PROCESS AND YOU WILL BE UP AND SNAPPING.
Jan 15, 2009 | Olympus FE-210 Digital Camera
Image on screen
It would appear that the LCD screen in broken.
Jul 26, 2008 | Olympus FE-210 Digital Camera
Olympus FE-210 Problem
try to reset the camera through the camera menu or send to repair
Jul 22, 2008 | Olympus FE-210 Digital Camera
Digital camera woes
Hey libra2,
I would try resetting the camera to its default factory settings. Directions on how to do this are on page 20 of your camera manual, and I have included a link to a PDF download of your camera manual in case you need it. I hope this helps!
http://www.olympusamerica.com/files/FE-210%20Advanced%20Manual.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Jul 13, 2008 | Olympus FE-210 Digital Camera
BLACK SCREEN, OLYMPUS FE210
You must go to a camera technician. There are some parts inside that already been loosen. That's what happened to my camera before.
Feb 16, 2008 | Olympus FE-210 Digital Camera
Lcd screen is black
you have to disamled your camera and reconnect the LCD it happens when the cable of the LCD is half out
Nov 28, 2007 | Olympus FE-170 Digital Camera
Camera acting strange.
i have the same problem. wat did u end up doing with it?
Nov 04, 2007 | Olympus FE-210 Digital Camera
Olympus FE-210 Digital Camera Logo
203 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
