Question about NetGear WG111T 108 Mbps 802.11g Wireless USB 2.0 Network Adapter (NETWNGWG111T)
Cannot connect to my laptop with a built in wireless.
Hi bought a NETGEAR WG111TGER usb wireless adaptor ,I've installed it on my desktop pc ,I've also upgraded Windows XP to service pack 2. Whether I use XP or the netgear software I cannot find the wireless network on both my desktop or my laptop.I have an HP laptop and and an Intel mother board with usb 1 ports. I really want to use my desktop pc to connect to the internet from my laptop. My desktop is link to the internet via an ADSL wired router,tell me how I can do this.
Thanks
MAlcolm
  • 854 Answers
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
Windows 2000/ME/Win98SE:
Note: Windows 2000 may require you to be logged on with administrator rights.
2. Insert the NETGEAR adapter resource CD into your CD-ROM drive. The setup page will then load.
3. Afterwards, click on the Install Driver & Utility link.
4. Make sure to follow the Install Shield Wizard steps, and click Finish when done to restart your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
2. Insert the NETGEAR adapter into the available expansion slot.
4. On the Found New Hardware Wizard, click on Next, then follow the prompt to proceed.
5. After the installation completes, click Finish to close the wizard. Please make sure that you can see the NETGEAR icon located at the lower right portion of your computer screen.
Note: If Windows displays Digital Signature Not Found warning, click Yes to continue.
C. Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Posted on Jul 07, 2009
Stuck At Detecting Adapter
Disconnect it, remove any software that was installed and restart the computer. Do not connect the device until you finish installing the device's software or the software installation prompts you to connect the device.
If that doesn't work, here's Microsoft's solution:
http://windows.microsoft.com/en-us/windows-vista/update-a-driver-for-hardware-that-isnt-working-properly
If that doesn't work, go to Netgear's website for support and/or post the problems in the forums.
I hope this helps.
Dec 19, 2012 | NetGear WNA1100 Wireless-N 150 USB Adapter...
Wireless connection with a wireless router (Netgear WNDR 4000) a pc and a laptop.
I assume you connect your printer to the desktop with the USB cable.
I assume the laptop is connected to the Wifi network.
First you need to setup the printer to connect to the wireless network. Follow the printer installation instructions to do that.
Next insert the install Disc into the laptop and follow the installation instructions. Use the network installation section.
The printer has a built-in server for printing.
If UPNP is enabled on the router then you should be able to browse the printer on the network.
Sep 30, 2017 | NetGear WGPS606 (WGPS606NAR) Print Server
I have a desktop HP connected to internet Broadband service via a "2wire" router thru my Windstream phone account. I have a Dell laptop that I'm able to use with the wireless connection...
you wont see the pc screen on the tv if that is what your expecting, if the tv is capable of receiving netflix then it will pick that up seperately from the pc, it will only need a wireless connection to access the broadband, you will also need a valid subscription to the netflix service. The fact you have proved you have a valid wireless connection means its connected. There will be an options button to select the internet content to view on viera cast
quote from panasonic ---
VIERA Cast's assorted online content just keeps getting better - in addition to the popular contents such as YouTube and Picasa Web Albums, it now offers Pandora Internet Radio, movies streamed from Netflix*, exciting sports from FOX Sports, tweeting web communications with Twitter, and even home video and audio conferencing with Skype. It also provides USB terminals for a keyboard and Wireless LAN Adaptor. No PC required. Skype function requires an optional communication camera TY-CC10.
Skype service will be available late June 2010.
*Netflix unlimited membership required. Service on Viera Cast TV will be available summer 2010.
*Keyboard and Wireless LAN Adaptor are not included.
Apr 17, 2011 | Panasonic Computers & Internet
How do I connect my netgear router to my desktop internet to use with my laptop. Followed instructions but when cable is disconnect from my laptop I can't connect to the internet
First Connect the Desktop with Netgear Router with the Ethernet cable. Open the Netgear GUI and configure a Wireless Network. Once its configured, switch On the WiFi switch from your Laptop and try to connect your Laptop. Make sure your laptop has an in-built Wifi adapter, if it doesn't then you would need to buy an USB based Wifi Adapter.
Also if you want to use the Internet with your Desktop PC without being connected with the Netgear Router then make sure it has Wireless connection capability.
May 10, 2010 | Computers & Internet
Cannot connect to my wireless router
You can download driver for windows-7 compatible
(download and install in computer)
http://kb.netgear.com/app/answers/detail/a_id/12962
If your issue not resolve please revert back to us for further
Thanks for using Fixya
Apr 09, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Connecting to wireless from my basement!
you need to add a repeater or signal booster for reciving signal in basement from uper floor.
My expierince is that whatever roueter you buy doenst matter it will not work properly if you are using wirless on 2 diffrent floors. on a same floor it can work smoothly even having walls.
Oct 02, 2009 | Dell TrueMobile 2300 Wireless Broadband...
I would like to go wireless with my system,(linksys router). Plea
HI,
You would have to proper hardware to go online wireless
1. Should have wireless cards on PC and laptops
2. Should have a wireless modem/router
3. Configure the devices and you would be able to go online
proton
Sep 01, 2009 | Acer Aspire One Netbook 8.9" Notebook
NETGEAR Wireless G USB Adaptor Problems
I contacted Bigpond after my whole internet collapsed due to my amature abilities in fixing the internet. >_<" yet they fixed my internet connection by disconnecting my current (DLINK DIR-300) router from the network. hmmmm... the technician also confirmed that my current broadband modem (2WIRE 2071-A) isnt capable of supplying a shared connection to more than one computer!! she also directed me towards a modem with an inbuilt wifi router that "supposedly" is the best option right now. (2701HGV-W) I'm a bit shaky and the stupid NETGEAR adaptor problem still exists - im willing to buy the new modem if its guaranteed to abolish this problem and give me a better internet wise outlook - please any suggestions will be appreiciated =)
Apr 23, 2009 | NetGear Wireless-G USB Adapter...
I have 2 computers. I can connect to the internet wirelessly with the XP one through a Netgear router. My HP Touchsmart,Vista Home Premium, purchased recently,will connect through an Ethernet cable, but...
Are you sure that your PC has a built in wireless function and not just a regular modem ??
If you just have a modem you will need to purchase a USB wireless interface the link below will take you to one perfectly compatible with your router.
http://www.ebuyer.com/product/60014
Good luck ;)
Carl
Dec 02, 2008 | HP Computers & Internet
Hi there, I just bought a netgear Rangemax next wireless router WNR834B with RANGEMAX™ NEXT WIRELESS N USB 2.0 ADAPTER – WN121T with no installation CD and i have connected the router to my modem and its...
Get the driver for the WN121T from the NetGear webset and install it before pluging the adapter into the notebook. Use a wired connection on the notebook until you have the drive downloaded.
Jun 19, 2008 | Computers & Internet
Computers & Internet Logo
158 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
