Question about HP Officejet 4355 All-In-One InkJet Printer
Related to printer connection
I just want to know how to connect printer or install whole connection
  • 3 Answers
I900D printing lines
Turn off the printer and open the printer back door. Use a spot light and give look inside properly. Make sure there no paper. Some time small part of the paper creates the problem. So you can do one thing after open the back door, top side etc make the printer upside down etc. So if anything inside that's will come out. After cleaning again connect it with PC and turn on. Now give a look. If you face same problem then Un-install the printer driver and software from the PC. Then restart the PC and Printer both. Now connect the Printer with PC via USB and install again the driver & software. Then try to print and let me know the result.
Aug 09, 2012 | Canon I900D InkJet Photo Printer
F380 All in one printer power not come
This is a purely power related issue and the main power supply has failed.
You will need this unit as a whole , check if there is any short after releasing the connection and confirming that there was no load trip off.
Sep 26, 2011 | Office Equipment & Supplies
COMPUTER DOES NOT RECOGNIZE SCANNER
Remove the printer from the printers list. Uninstall the driver software for the printer. Then do a search, using search for files and folders, looking for any files that are related to the samsung SCX4826FN and delete the files found.
Restart your computer. Unplug your printer. Re-install the Samsung software and shut down you computer. Re-connect the printer to the computer and start up your computer. The computer will find the new hardware and look for the driver you installed. The driver should install automatically.
This process should re-new all the connections to your all in one printer/scanner.
I hope you found this information helpful. Good luck. Let me know if you still have connetion problems after going thru this process.
Brian
Jan 24, 2011 | Samsung SCX4826FN AllInOne Laser Printer
Why wont my z640 printer install
On What? Your bike? A little more info would go a long way.. This is an older model printer. Not supported on Windows Vista or Win 7, nor on Linux.. IS supported on XP or lower. Search for the driver at lexmark.com Lexmarks needs to install the software first, BEFORE connecting the printer. Install SW. Connect printer, Should detect it and install autmatically in Win XP. If you did not do this, UN-install evrything related to this printer first then start over correctly.
Read the manual. Don't have it? Download it from Lexmark.com
Lexmarks are notorius for install issues.
If you're on Win Vista or higher, upgrade your printer! These old inkjets will cost a fortune in ink cartridges. Use them too much, they run out. Try to avoid using them and they'll dry out on you. Got kids? they'll print anything and everything. I know from experience. Lexmark ink in particular is costly for what you get, in my opinion.
Nov 08, 2010 | Lexmark Office Equipment & Supplies
I want to install hp officejet 4355-All-in-one.how i can
Hi.
Install the driver software before connecting the printer USB cable to the computer, then connect the printer. The only action required after installing the software and connecting the printer, is authorizing system changes if asked by Windows or by your security software.
If you have misplaced the original driver disk you can download the software here:HP Officejet 4355 All-in-One Printer - HP Customer Care.
Regards.
Apr 13, 2010 | HP Officejet 4355 All-In-One InkJet...
Turn on the printer, tried to print when paper feed started the whole machine made a griding noise and seized up. NO PAPER JAM AMD MAIN LIGHT RED
Its better to remove the printer from all the accessories connected to it like cable, power , back tray, cartridge,etc.. then remove all the printer related drivers and softwares from system. now turn on your printer withour connecting to system. then connect to system and put the driver cd in cd drive. Install the driver, restart your system and try printing. he problem would fixed most of the time in this way. I hoep this is useful to you.
Nov 07, 2009 | Samsung CLP 300 Laser Printer
I have a brother mfc wireless printer 7840w. It came with an install cd that I am trying to install it on my laptop - hp windows vistas. during the install there are three options - one is usb, ethernet,...
ok this is not fiewall issue your printer did not or you did not configure this correctly
you have to first install this using USB cable that came with it .... important .... do not connect printer first ... install you software first and it will ask you to connect your printer
once you install this you will have an option assign IP addrress to your printer
once you configure your printer with DHCP or static IP you are good to go
go to your printer setup and add your printer via either IP address or the name you gave when you configured your printer
good luck
Jun 04, 2009 | Computers & Internet
I have a hp psc 2175 all-in-one printer w/out install cd
You didn't mention what you were using for an Operating System but you can choose whichever one you're using at THIS LINK.
As far as hooking it up, HP has instructions at THIS LINK and it says 2170 but that includes 2175. They do whole "series" of printers.
I hope those links are helpful and if you have any other problems let me know.
Apr 09, 2009 | HP PSC 2175 All-In-One InkJet Printer
Dell 948 wireless printer
hi,
u need to have wireless internet connection, first uninstall the printer sw, while reinstalling choose wireless install, follow inst, connect the printer, configure wireless adapter by choosing the correct wireless nw and by entering the security key(WEP, WPA), if wireless adapter not detected then, unplug all cables from back of printer,removed wirless adapter, press power button for 20 secs without any cables connected, connect cables, restart printer, connect the wireless adapter, u will get msg nw card detected, then try reconfiguring by entering the correct keys, in case if u dont know the security key contact ur internet service provider, once correct details are entered it will configure successfully, unplug usb cable from printer and pc, install printer sw, issue resolved, if there is no communication then check the firewall settings, anything relating to printer give full access, restart pc, try printing,
ps: if usb cable is connected to printer the nw card will be disabled.
Nov 03, 2008 | Dell 948 All-In-One InkJet Printer
Printer driver not working
Hi there, i dont know if this is of any relevence however, i have just spent the whole afternoon trying to install my new printer, every time i installed my disk a little icon popped up saying usb didnt recognise the device, despite endless frustration i did it another way, If your printer is a usb connection then before inserting the disk connect the printer to the computer and switch on, this then brings up the wizzard which should help you install, if this doesnt work...trust me it took me ages, try different usb ports, i finally found one that picked up the printer, after it detected the device i was then able to continue with instalation via the disk and wohoo many hours later i have a printer, unfortunatley i have now run out of paper doh!!! i hope this helps someone :-)
Mar 03, 2008 | Computers & Internet
HP Officejet 4355 All-In-One InkJet Printer Logo
Ben Johnson
