Oko-lavamat 6200 washing mashine does not rinse
OKO-LAVAMAT 6200 Washing mashine does not rinse.
Finishes main wash skipping rinses.At rinse makes a noise for a while and moves to the next step.Everything else works.
  • 1 more comment
  • artorosx Jul 13, 2008
    oko-lavamat 6200 washing mashine does not have the feature "Rinse Hold".it does not rinse on the main wash programme(should rinse 3 times).
    It makes a noise and after a while it goes to drain and spin.
    Thanks
    Sorry bat the recycling of water seemes to me irrelevant
    it was helpful. many thanks
  • 78 Answers
Your Motor is on it's way out. From what I have read. I just fixed someone's problem like this in Live Chat. If you get a new motor for your washer, it will work fine. Thanks for using FixYa!
Posted on Jul 13, 2008
  • 868 Answers
Replace the water inlet valve.If you need 100% assurance that I'm correct ten go to any hardware store in town and purchase a hose "Y" and ask them for it and install it and run any cycle you want.After it completes the cycle and shuts off you now can determine if changing the water valve is needed here. (see pix).... it will look very similar to this one. Please Rate This !!
  • 4,889 Answers
If the washer won’t finish a cycle, it probably means that your timer went bad or stalled. You can take the control panel off and and look at the contacts for scorching or corrosion. Check this and post back.
  • 2,071 Answers
WHAT IS WRONG WITH YOUR WASHING MACHINE?
oko-lavamat  6200 washing mashine does not rinse - small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Whirlpool Style
Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
    Scholar:
  • 148 Answers
It could be the motor it might be fine in one speed but not the other as some motors have multiple speeds
  • Washing Mach... Master
  • 19,396 Answers
When this happens it is usually a problem with the timer. By replacing the timer/programmer you should be able to fix it.
You can find parts here:
If you input model number on this website you will get replacement parts price.
  • 813 Answers
A cloudy water recovery and recycling apparatus and method of use. The apparatus recovers cloudy water defined as water recovered from the rinse cycle of a clothes washing machine. The apparatus is comprised of an electronic controller, a storage tank, a trap having a lint screen, a pumping means, and a pressurized storage container. Water from a clothes washing machine is separated into rinse water and wash water by an electronic controller. The wash water is disposed of and the rinse water is strained to remove lint, collected in the storage tank, treated with dye and bactericide, pumped from the storage tank to a pressurized container and then utilized to flush at least one toilet
    Brigadier General:
  • 6,966 Answers
Pls check if your model has a feature called "Rinse Hold" and determine if it is enabled or engaged. If yes, try turning this feature off.
If the above is not corrective nor applicable, would appreciate a postback for additional information.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Jul 13, 2008
    Hi again,
    Appreciate the postback and additional information. I understand that your unit has no "Rinse Hold" feature.
    It would appear that your unit is jumping the sequence and thus could be a defective controller board (most likely).
    Would you be so kind to comment back the E-number or the PNC of your 6200? They normally are stenciled/printed on the name plate often at the back of the unit. It would be something like "95007403800".
    Cheers.
    Genius:
  • 1,665 Answers
Valve may be clogged
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Jul 13, 2008
    Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
    If you're sure the machine isn't working the way it used to--or should--try these tests:
    • Is the hot water turned on? If not, turn it on.
    • Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct.
    • Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
    Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
    If you're sure the machine is not working the way it used to--or should--check the following.
    • Is the cold water turned on? If not, turn it on.
    • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
    • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
Hi can anyone help me please im looking for a user manual for an AEG oko lavamat 75620 washing machine
do google search for "user manual AEG oko lavamat 75620" on page 2 about 4th down you will see a pdf manual for your model ( it's the "update" model but they are virtually identical to use ) don't download straight away it's foreign but don't despair click the option Translate this page and you'll then download an english version of the standard commonly experienced when Nigerian or Ugandan ex govt ministers let you know, via email, of an opportunity to help them smuggle millions out of their respective countries. never-the-less you will be able to run your machine from it.
Mar 17, 2013 | AEG Washing Machines
My 12 year old AEG OKO LAVAMAT is making a grinding sound when it fills. It's fine at all other times. I've tried cleaning out the filter, and running it empty.
This is usually caused by the recycling pump running empty whilst the washing is still soaking up the initial fill water. as the water begins to soak the clothes it then starts to pass through the drum into the pump and the whole thing quietens down. running empty will not work. to test this theory try opening the drawer very slightly and filling it manually with a hose before starting the machine, (ONLY TO THE NORMAL LEVEL) and see if the noise is still as bad.
Feb 09, 2013 | AEG Washing Machines
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
Aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
Need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Apr 09, 2008 | Washing Machines
Aeg 76669 oko lavamat machine not starting all six lights [pre wash, main wash, rinse, rinse , spin, and end] flashing machine three years old just successfully completed wash cycle, loaded up for next...
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Jan 10, 2008 | AEG Washing Machines
Washing Machines Logo
303 people viewed this question
Top Washing Machines Experts
