Question about HP Pavilion dv6000z Notebook
Monitor won't work with new computer
I have HP Pavilion monitors mx70 and f1703 - neither will work with my new HP dx7400 SFF computer but both work fine with my pavilion 720a why ? Do I need to buy another monitor ? if so what should I be looking for ? I have put the wrong product in the box below - mine wasn't listed.
  • karen999 Jul 14, 2008
    Thanks for your suggestion, however there is only one monitor connection present.
  • karen999 Oct 16, 2008
    Turns out Etherelean was correct and all I needed was an adaptor to connect the f1703 to the second monitor plug. Thanks !
U need to get a newer monitor!!!!!
Posted on Oct 16, 2008
    Problem Solver:
  • 12 Answers
The computer in question has two graphics cards in it. A GEForce 8400GS Graphics card and an onboard graphics card. It could be possible you are plugging the monitor cable into the wrong graphics card slot. The onboard graphics card slot may be a different color than the GEForce graphics card slot. Check the back of the computer to see if there is another spot to plug in the monitor.
Posted on Jul 14, 2008
My hp f1703 monitor just turns off on it's own.
Common failure in this monitor is the poor soldering works on the doughnut (4) shape inductors in the inverter board, http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/
Feb 18, 2010 | HP Pavilion F1703 17" LCD Monitor
Monitor won't come on right away
Sounds like the CRT is starting to go bad cause its taking longer and longer for it to boot up. CRT's aren't available now so a new monitor would be the only option.
Apr 09, 2009 | HP Pavilion MX70 17" CRT Monitor
Monitor is missing pins?
If the monitor is working correctly, there is no problem. Not all 15 pins are used, therefore there is usually two missing.
Jan 24, 2009 | HP Pavilion MX70 17" CRT Monitor
Possilbe to reset monitor?
This document pertains to MX50, MX70, MX75 and MX90 CRT monitors.
NOTE: To reset the monitor to factory settings:
  1. Turn off the monitor by pressing the POWER button.
  2. Press and hold the plus (+) button and then
  3. Whith the Plus (+) button pressed, press the power button to turn on the monitor.
  4. Release both buttons.
Jan 01, 2009 | HP Pavilion MX70 17" CRT Monitor
I want to know if my monitor is Vista compatable
Yes, the monitor is Vista compatible. A monitor is just a display device, simply showing you what's coming from the computer's video card. That video circuitry is what would need to be compatible with Vista.
If you are upgrading an older computer by installing Vista, you might need to be concerned about video hardware compatibility. If you are upgrading by simply replacing the computer with a new one, it will already be Vista ready. In either case, the monitor will be fine.
Please take a moment to rate this solution if you've found it what you need, and thanks for asking here!
Dec 27, 2008 | HP Pavilion MX70 17" CRT Monitor
Lcd monitor problem
use the economical approach replace the ac power supply if this doesnt work replace your monitor with a new one.
Because its probably the same amount of cost to fix it as it is to get a new monitor.
Jan 01, 2008 | HP Pavilion F1703 17" LCD Monitor
Shaking Problem with LCD Screen - HP Pavilion F1703
It sounds like you need to use your "DeGausse" button to reset the magnetics in the screen.
Dec 25, 2007 | HP Pavilion F1703 17" LCD Monitor
HP Pavilion dv6000z Notebook Logo
151 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
