Question about HP Compaq Presario v3000z Notebook
Problem with new install xp
When i try to install xp so it's can't find my harddisk. arror is could not find any hardisk in your system. pls solw this problem what i do.
    President:
  • HP Master
  • 1,314 Answers
Actually, if I'm reading between the lines, it sounds like we are upgrading from windows vista to windows xp and, when installing and booting from the xp cd, the hard drive can't be found. That can be easily remedied by turning off the ahci mode in the computer's bios. Change it to the other option that's there, save and exit, then reboot. Your windows xp cd will become available.
Posted on Jul 13, 2008
    Scholar:
  • 43 Answers
First of all, was there a reason that you wanted to reinstall windows? If you were having problems with the operating system and now upon reload the hard disk is not appearing it could mean that the disk or the system board itself is bad.
If you pull the XP disk out and just try to boot your computer up are you able to login and use your computer from the previous/original install of XP?
If so, then perhaps you're using a special hard drive controller that supports RAID. If you have a RAID controller you'll need to load the drivers of that controller on a Floppy disk. During the initial startup of the XP install it will give you the opportunity to click the F6 button on the keyboard to load additional device drivers. You want to click F6 when it prompts you at the bottom of the screen and wait for it to prompt you to put your floppy disk (with the RAID controller drivers) in the floppy drive.
Hope this helps. If you need more help just let me know.
MO
Hi,I've an external case (diamondmax 11 Model:6H500F0)--500GB SATA 3.0GB HDD. And I wanna to activate it,but I Dont have the Installation CD,plz I need your help URGENTLY. (I've an widows XP for my...
Maxtor DiamondMax 11 is a SATA Hardisk and you need SATA External Case. After adding the Harddisk, all you have to do is connect it to the system via the cable of the external case. There is no need for additional drivers/ CD as all the external harddisks are 'plug and play'and the Operating System detects them automatically.
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Maxtor DiamondMax 11 400GB 7200rpm 133MBps...
Did not see second sata harddisk
To know if your Hardisk is detected follow this steps:
In Windows XP
1. Open Control Panel
2. Go to Administrative Tools
3. Open Computer Management
4. Double Click Storage
5. Open Disk Management
All the list of Hardisk is here, your hardisk is not formatted that's why, so you have to proceed to format just right click that unformatted hardisk and choose format, specify the label for your hardisk or simply leave it blank.
Jan 11, 2010 | HP dc7600 Small Form Factor P4 640...
Hye..my acer aspire laptop very bad causes of virus infection and mess with all my files and folders. so, it think reformat is the best solution for me. But unlucky, when i restarted my Laptop and install...
Hello !
You have said that you have done installation and Harddisk are not recognised this is a indication of damaged Harddisk ie its registry is bad or its not working .
I recomend a new Harddisk then you will able to use your laptop
Before you change the harddisk you should check the IDE cables by swapping them coz sometimes they could be faulty, connect new cable to the harddisk then on it try installation again .
Good luck
Nov 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
Computer will reboot on Virus/Spyware scan at random. I have: 1. Installed clean XP SP2 parallel system and booted that one. Same problem. 2. Memory Test at boot time is OK. 3. Air circulation from Power...
The weak airflow from the power supply unit (PSU) is suspect. Virus / Malware scanning is a disk and processor intensive operation - resulting in greater load on both. Increased load translates to heat. Check to be sure that the processor (CPU) fan is running, too. An overheating PSU and CPU can cause all types of problems.
Are you using a genuine XP install disk/image or a disk of questionable origin? Use of bogus OS disks is "asking for trouble".
If your system BIOS or set up (accessed during boot) allows, try to located the page that displays component temperatures and fan speeds. Check this immediately after rebooting from a an unplanned shut down - if unable to locate this set up page, download HWMonitor at:
http://www.cpuid.com/hwmonitor.php
It is a free program - choose the 32 or 64 bit version. Note fan RPM and CPU core temps to help determine where heat is coming from - or which fans aren't operating correctly.
Sep 18, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Operating system not found
When you power up the computer press F1 ore F2 or "del" key toenter in bios then check your hardisk is detected or not.
If not then if you have desktop open cpu cabinet then reconnect power cable and ide or sata cable to harddisk also check your harddisk is set to master.
Jul 29, 2009 | Microsoft Windows XP Professional
System not booting harddisk connected in master &cd drive conected in slave os win xp sp2 wts the main problem
plz set ur hardisk as the 1st boot device in the bios setup. u can enter the bios setup by pressing the del or f2 key when u power on the mission
Feb 21, 2009 | Microsoft Windows XP Professional for PC
When installing a used hd...PC says no hard drive found
Do you have another harddisk installed already if so, you need to change the jumper settings maybe both the hardisks are having the jumper positioned as master device. which u need to set ur OS or Operating software HDD to master and the second one as a slave.
Nov 12, 2008 | Microsoft Windows XP Professional
Acer laptop is not detecting harddisk
kiran,
i thought you have SATA interface, in that case your XP will not be able to access your HDD. But now as you told there is no option for SATA means you don't have SATA interface in your motherboard and the problem might be in your HDD.
  1. So, check out your HDD connection from motherboard and try to install again if no luck then do the following step.
  2. If you have important data/files on your HDD make a backup copy. Then make try to delete all partition and make new partition, then proceed further installation OR if you have recovery disk try to use it to recover your system as factory setting.
Thanks
Iqbal
May 17, 2008 | Acer Aspire 5004WLMi Notebook
Cannot install win xp
Hi Phine_24,
I think you've problem with Harddisk.Try to find spare one and install again it should work. Very strange is that if you remove your hardisk out and test externally it should sometime work fine but sometime fail.I think it's a starting sector or some check up that windows or hardware need and it couldn't access it.
goodluck,takecare.
May 04, 2008 | Computers & Internet
HP Compaq Presario v3000z Notebook Logo
62 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
