Question about Logitech Z-5500 Computer Speakers
Can i setup these up outside of a computer and just plug them into a wall ?
Im thinking of buying them for my room buy i currently dont have a computer in my room so i was wondering if i could just have the system plugged into a wall and have my music run through my ipod. would this work ? thanks
I connect my ipod but cant get all the speakers to go just two satelites
Posted on Jul 29, 2008
  • 58 Answers
It should be possible as long as you can find an adapter to attach them to your ipod.
Posted on Jul 21, 2008
I want to buy portable air conditioner, but the buyer said that i need put the exhaust tube near a window open to expel hot air, in my room not have windows
You do have to use the exhaust tube, would need to put a hole in your wall. Also, these units really generate a lot of heat. We tried one, it almost seems as if it actually makes the room hotter! You would be better off buying a small regular unit, constructing a hole in the wall to the outside.
If you absolutely cannot do the hole, you could get an extension to the exhaust tubing and maybe use a window in another room?
Apr 04, 2011 | Heating & Cooling
Hi, I have a 2Wire 270 DSl Modem I had bought through Qwest since they are my ISP. My home is a 1500 Sft Ranch, if the modem is in the bedroom and the Mac Book is in the family room down the hall the...
If the walls in your house are made of lathe and plaster or concrete block, then the performance of WiFi through all the walls in your house will be very bad. The signal that you are receiving from your neighbor's modem is probably only going through two walls (the outside wall of their house and the outside wall of your house), while the signal from your modem is probably going through at least 4 or 5 walls.
I suggest that you do not buy a new modem, but buy a wireless access point, a spool of CAT6 cable and two Leviton RJ45 wall jacks. Run the CAT6 cable from the modem to your bedroom, install the Leviton RJ45 jacks on both ends of the cable, and then connect the wireless access point to the the jack in the bedroom and the modem to the jack near to it.
This will expand the wireless coverage in your house and allow you to buy much better wireless device than QWest would ever sell to you.
Here is a suggestion for Wireless Access Point.
You can buy the CAT6 cable and Leviton RJ45 jacks at Home Depot or Lowes.
Dec 30, 2010 | Computers & Internet
I need to replace some old storage heaters in my
you need to measure the height of celing size of room how many outside walls thickness of walls take this info to your local heating shop they will tell you the heat loss for each room and what size heating you need in kws you then choose the heaters you want
Apr 19, 2010 | Heating & Cooling
Need to connect to internet
you should be able to have a way to enter in for the log access, i beleive when you setup the connection on the ps3 it asks if theirs a securtiy feature, you say yes and it should ask for a password to be entered but im not sure, its what i had to do for my laptop and psp i had to make a new connection and make sure it knows i need to enter a security by selctignt the securtiy features so when i wanted to sign in it would use that password as needed! GL
Jan 20, 2010 | Sony Playstation 3 (PS3) Console
We built an outdoor room and the dryer vent is now "indoors".
you'll have to go to lowes or home depot and buy the rigid vent pipe not the flex type. Figure up the elbows and straight pcs. Usually vent pipe is 4,6,8 So make sure you get the correct size. Now as far as going through an existing interior since the vent pipe will be larger than the wall studs you want be able to go through the walls unless you have 6in. stud walls and the vent pipe for a dryer is usually 4in. I think. If you do have 6in interior walls you can run through them but make sure it's interior walls instead of outside wall interior walls usually dont have insulation. If you can't go through the walls your next option is simply through the each floor and out the roof or out the wall. Build a square chaise around the vent with 2x4 lumber, drywall and finish.Be careful if you go through the walls you may have to reroute wiring and water pipes.
Sep 07, 2009 | Samsung DV337 Electric Dryer
Need to know amprage and polarity
According to several sites this monitor needs a 12-volt 4-amp adapter. Virtually every laptop that uses a coaxial power plug has the center pin positive and the outside shell ground. A Google search for "ct1810 replacement adapter" turned up several sources. Here's an eBay auction currently running for one vendor. If you're outside the US you should be able to find a suitable replacement on the Internet or perhaps locally.
Apr 27, 2009 | Computers & Internet
Control Pod for Companion 5 volume control non-functional
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
Hope this helps/
Mar 13, 2009 | Bose Companion 5 Multimedia Speaker System...
GE thru-the-wall heat pump
pop off the front grill and look inside for a sticker
Oct 01, 2008 | GE Built-In Room Air Heat Cool Air...
Wireless ceiling fan
there are remote controlled fan out on the market.
there are also devices the make it remote, but the cord is for power so i dont think you can hide the wires to much without going thru the ceiling.
if you have no access of the cieling then the wire must be there for powering of the fan run along the wall, try stapling the wire to the cieling like around the egdes of the ceiling then perhap painting the wire the same color of the ceiling.
you do not have much option to work with.
you have to make sure you buy the right remote controll
but it still need power.
http://www.csnceilingfans.com/Ceiling-Fan-Remote-Controls-C14870.html
there a site for remote controls for fan or just buy a new fan all together. im sure they put the plug there for a reason because if you use the fan alot they do go bad.
Good luck
Aug 16, 2008 | Dryers
Connecting a router
To connect more than one computer to same network, you need to use a router. Two modems will not work on same network.
My suggestion:
Buy a wireless modem router for cable broadband (and eventually a wireless network card for the other computer.
Here is an example: Linksys BEFW11S4 Wireless-B 4-Port Cable/DSL
Ask retailer to get right model for your broadband.
Connect the remote computer with wireless.
Apr 22, 2008 | Computers & Internet
Logitech Z-5500 Computer Speakers Logo
37 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
