Logitech Z-5500 500 Watts 5.1 Surround Sound System. on this system can i just plug it into a wall and play the music from my ipod or does it need to be setup from a computer ? thanks
You Have 2 get a double headphone jack
Posted on Aug 18, 2008
How to stop music from playing music while surround sound is on the tv
First make sure the cables around the television and the surround sound system are not damaged. Then make sure the any grounding on the external sheathing of the cable is making good contact and that the braiding is not touching any other cable under the plug. You could try some better aftermarket connecting cables, and the ones that come with systems are used for price cheapness. Keep a space between cables and don't wrap them around each other. If none of that works, get some Ferrite Rings and thread three on each cable to the surround sound system, one at each end of the cable and one in the middle.
Cables with good braiding and gold flashed connectors as shown on this page are an indication of quality.
RCA Surround Sound Connections Analog 5 1 Audio Explained
Nov 06, 2016 | Audio Players & Recorders
How do i get a Regents HT-391 surround sound system to play sound from my Logitech Revue with Google TV?
More than likely the regent system is needing and alternate audio source, via- analog, digital coax, optical ect... HAs it always been this way, or use to work?
May 22, 2014 | Logitech Revue with Google TV Refurbished
We have a Bose Lifestyle model 5 music center and it won't go into surround sound mode. It will play a CD and all 5 speakers work. Any suggestions??
Are you sure the red and white wires plugged into the audio output on your TV because I had the same problem and learned thats where you plug them into
Nov 06, 2012 | Bose Lifestyle Model 5 Music Center
Lg HTS how do i change from stereo sound to Surround. The rear and centre speakers are not working at present
Music only plays through those two speakers, only movies with 5.1 format will play through all your speakers
Sep 18, 2012 | LG 5.1ch 1100w bluray hts 5 speakrperp...
I just created my own pc. i decided to go against getting a sound card. My sound works coming from the mobo. I hear the music from my display moniter speakers. When i connect my headphones to the front...
You need to change the sound profile from 2 speaker system to surround sound. You will find this in the control panel area program.
Hope this helps.
Thanks
Jason
Oct 25, 2010 | Logitech X-530 Computer Speakers
How many watts?
Logitech X-530 70-Watt 5.1 Surround Sound Speaker System
Apr 14, 2010 | Logitech X-530 Computer Speakers
Logitech Z-5300 subwoofer from computer to i-pod problem...
The best thing to do is to contact the manufacturers. From this i understood that your speaker system is new. You surely have the manufacturer's guarantee. So its better to contact them than to get it repaired or replaced for free. Sir please do not try to open the sub as it will void the guarantee policy.
Hope your subs come into play as soon as possible.......
All the best...
Jan 05, 2010 | Logitech Z-5300e Surround Sound System...
I have the logitech x-540 5.1 speaker system, do i need an adapter to plug in to my macbook and iPod? so I am able to have hear all 5 speakers together?
Yes, you do, the adapter has 1 green end, which gets plugged into your computer and then the other end has 3 connectors, green, yellow, and black, which then goes into one thick cable. I have the set up right now.
Dec 03, 2009 | Logitech X-540 Multimedia Surround Sound...
My surround system is playing on the dvd but there is no sound
check your cable settings if its inserted in the correct plug-in....also check if its not muted....also try to play other disc if there is a sound coming from the speakers
Nov 13, 2009 | Logitech Audio Players & Recorders
Logitech x540 speakers- rear speakers distorted on matrix mode
I installed my soundcard which is the sound blaster SE audigy but when i try to test the sound i see that it does not sound separately.What i have to do to make them sound saperately when i'm testing it ?
Apr 16, 2008 | Logitech X-540 Computer Speakers
67 people viewed this question
 Grubhead
Grubhead
