Question about GE WDSR2080D Top Load Washer
G.E. washer model wdsr2080d2cc
QUESTION IS THE MACHINE SPINN ON EITHER CYCLE?
My machine will do nothing but spin, is there a reset button
or do you think a part needs replacing?
Posted on Aug 02, 2008
After the final spinn cycle ther is still water in the washer
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
The machine will not spinn, the washing is very wet when finnished washing
clothes are wet after spinning this is due to faulty Motor coupler. test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:If it's spinning when you lift the lid, the coupler is fine.If not then the coupler is broken.It has to be replaced;.This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. ----------------------- If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn motor pulley or tub bearing. Replace the applicable component. Thanks.
Sep 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
Spinn cycle made LOTS of noise won't spinn any longer
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,<br />When my washer did that, I found that the shocks that hold the tub were bad...<br /><br />Check out this tip I wrote about the noise and vibration that front load washers can make..<br /><br />Washer Problems Washer noise when spinning<br /><a href="http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when" target="_blank">http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span><span style="FONT-FAMILY: Arial; COLOR: black; FONT-SIZE: 10.5pt"></span><br />
Aug 25, 2010 | Frigidaire ATF6000ES Front Load Washer
The drum will not spinn?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | LG WM1814CW Front Load Washer
Water still in machine
Depending on how high your drain hose is some of the water after the final spin can drain back into the outer tube of the machine. This wont hurt anything but when not using the maching, not a bad idea to leave the door ajared to prevent the washer from giving off a bad odour,
Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have Kenmore Series 70 using about 4 years. I realized that my washer won't empty out the water and won't work any of spinn either. Someone told me that need to switch time click and others? How can you...
Assuming that this is a basic Kenmore / Whirlpool direct drive, top load, neutral drain washer.
If the machine fills with water and goes through its' agitate cycle, the motor is working as is the transmission (At least in one direction.
The timer on type of machine reverses the motor to drive the pump and run the spin cycle.
If the machine.
Check this Sears parts site and the Whirlpool Installation and maintenance document to see how the machine works. It appears that you do need a timer.
Sears parts:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components.
Whirlpool document:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Sep 22, 2009 | Kenmore Washing Machines
Clothes still very wet after spin
Common problem if drain tube goes to laundry tub. Tub drain is slow, so water is siphoned back into washer at end of cycle.
Other solutions: Partial blockage of drain tube before or at water pump. Take off front washer panel, exposing pump and disconnect hoses. Remove obstructions and re-assemble.
Jun 12, 2009 | Maytag PAV2300 Top Load Washer
ROARING SOUND IN SPINN CYCLE
your bearings are shot your washer needs to be rebuilt it would be cheaper to go buy a new machine
Dec 23, 2008 | Maytag Legacy Top Load Washer
Noisey during wash cycle
sounds as if your brake pads have broken, try removing the lower acess panel you should see the broken pads lying somewhere under the machine(at least pieces of them), i bet if you spinn the machine the drum doesnt come to a complete sudden stop after lifting the top( it should if the brakes are engaging
Sep 26, 2008 | Amana 3.2 cu. ft. Top-Load Washer
No spin cicle
what is the model number of the washer
May 11, 2008 | Washing Machines
GE WDSR2080D Top Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
