Computers & Internet Logo
Posted on Jan 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can not get by daughters compute to hook up to my netgear wireless router. My other computers had no problem in getting connected. We have tried everything and can not get it to take the router
Anonymous
Level 3:
Genius:
  • Master 1,400 Answers
  • Posted on Jan 12, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1400
Questions
Helped
392570
Points
4210
Hello
Have you tried going to control panel,network and sharing center.
Once there, make sure all pcs are on the same network,either homgroup or public.
Your daughters needs to be on the same network as the others.Also be sure the firewall is not blocking any connections.
You may also want to reboot the router do this by...
1 shut down all pcs
2 Unplug all cables from router including power.
3 Let router set for a min then plug all cables back in and power up
4 Once you get stedy lights on router restart pcs.
Cannot connect to internet through netgear n300 wireless router
They are pretty straight forward. Connect the ISP modem to main uplink port. Then connect pc to any other port. Done!
Try resetting it by holding the reset in till it cycles through. This will clear all custom setting and try again.
I normally don't suggest firmware upgrades, but try updating.
192.168.0.1 Defual login if you cleared custom is User: admin Password: admin
http://www.downloads.netgear.com/files/DGND3300v2_UM_14Oct10.pdf
Other than that the unit is damaged / defective.
My daughter is trying to use her laptop at home. where do I find the security code for my netgear router
The encryption code is configured in the wireless settings.
Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
I just had an NetGear Wireless "N-150 Router" (WNR1000) sent to Me from Comcast of which all would appear to be hooked-up and running well; to the best of My knowledge. But yet My girlfriends...
If all your gear is working fine then the issue lies with the girlfriend's laptop wi fi chip. I had the same issue and had to return the laptop for another.
I have a windows xp laptop computer that is not very new. I bought a netgear router and hooked it up to my desktop computer and was able to get wi-fi for my daughter on her i-pod. Now I am trying to get...
Pretty simple. It should be set to auto discovery. As long as the WiFi is working ie switched on you shoyuld find your home network pretty easiily. You do need ot knwo the SSID (the name of the network adn teh pasword. Right click on the wireless icon in teh tray to the bottom right adn show the list of netwoprk sits found. One of those should be yours. Simply 'connect' to the network adn entire the Passphrasethat was preassigned when you set up the network an it should automagically connect.
Laptop can not connect to netgear wireless router
I would suggest using the network setup wizard, in the control panel. Best option is to copy the data to a pen drive and transfer to your daughters laptop.
I am trying to setup a desktop (connected to
i have netgear fs 605 vs/fs608 v2 how to get connected with internet ?
1helpful
I ordered a wireless router so I can hook up my PS3. My computer is not compatible with wifi so I thought I'd just leave it hooked up to the modem. The instructions tell me to put the CD into my computer...
You have to use the computer to insert the CD
As your computer is not wireless compatible, you can have this connected to the router itself on the wired connections and use PS3 on wireless
Do NOT connect your computer to modem and also Netgear to modem.
Either one of them won't work. Instead connect modem to Netgear and computer to Netgear with an ethernet cable.
After this type of connection is made, try to setup the router with the CD inserted into computer.
This is how things work!
NetGear NETGEAR WNDR3300 RangeMax Dual Band router
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer and XBox needs to be configured with the Netgear wireless settings.
Follow these steps. : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
My netgear wireless router
Is it th win 2000 computer that you want to get a wireless connection? Do you have a wireless adapter on that computer that you want to go wireless?
2answers
Wireless router
If you have a computer wired to the router, Try this steps.
1.Open a browser and then go to http://192.168.1.1
2. Username admin and password is password
3. You should be able to access the router's utility page then and get the wireless settings of the router.
Once you get the wireless settings of the router, just connect to the name(SSID) you set up and then connect to it.
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
