Question about DISH Network IR Remote Control
Draining batteries I've had DishNetwork with the IR/UHF Pro 6.0 for many years. Everytime I put batteries in the remote, it drains the batteries within 2 days. Doesn't matter if the batteries are new, they always drain. I do not have this problem with the main remote, just the UHF remote. I assumed there is a button stuck, but I nothing seems to be stuck. PLEASE HELP!!
  • 1 more comment
  • Anonymous Dec 30, 2008
    I have a  DishNetwork  IR/UHF Pro 6.0 . Everytime I put batteries in the remote, it drains the batteries within days. To make matters worse Dish will not replace they want to sell me another defected remote.  NUTS
  • LonnieM Jan 28, 2009
    I have the same problem with my IR/UHF PRO 4.0 draining batteries. I actually got this replaced free by dishnetwork, but now the NEW ONE IS DOING THE SAME THIMG ARGH>>>
  • Anonymous Mar 23, 2014
    Remotes are about 4 years old
  • 51 Answers
Probably caused by a short inside the remote, it will need to be replaced
Posted on Aug 06, 2008
Recent IR20.0 remote problem developed after 2 years without any issues. The remote no longer communicates to my 722k dvr reciever while my LG Tv is turned on. I have Hdmi run directly from reciever to my...
Hi Robert, my name is Cheri Torres and I work on the Social Media Team at DISH. It sounds like your remote is experiencing IR(Infrared) interference from your LG TV. You can resolve this issue by converting your TV1 remote to UHF(Ultra High Frequency) instead of IR. In order to do this you will need a UHF remote, the 20.0 remote is only an IR remote. Please email me directly at Cheri.Torres@Dish.com with your account number or phone number on the account so that I can look into getting a UHF remote sent out. Thank you.
Cheri Torres
Social Media Representative
DISH L.L.C.
Apr 08, 2012 | DISH Network IR Remote Control
Uhf pro fcc id DKNFSK01 MY REMOTE WILL NOT WORK AT ALL I'VE PUT NEW BATTERIES IN IT AND IT LIGHTS UP BUT WILL NOT WORK THE RECIEVER AT ALL ANY HELP WOULD BE GREAT THAT YOU
Hey edwards879,
It sounds like the remote needs to be addressed to the receiver.
I have provided the steps below to assist you with that, you can also check out this link: http://www.dishnetwork.com/SupportSection/remote-setup
Addressing Remote to Receiver:
1.) Go to System Info screen.
2.) Hold down the SAT button until all mode lights light up.
3.) Enter a number between 1 and 15 using the numeric keypad on the remote.
4.) Press the pound (#) button.
5.) Once the SAT button blinks three times, press record.
6.) Test remote and see if works.
If you reprogram it and it still doesn't work the remote may need to be replaced. If that's the case or if you have any other questions let me know!
Tommy Faust
DISH Network
Jul 20, 2011 | DISH Network IR Remote Control
#1 remote in IR Mode, #2 remote in UHF mode, dual HD receiver model 722; #2 remote works perfectly, #1 remote works for a while then stops working. Have to hold the remote within an inch of the IR on the...
bp22911,
It sounds like it may be an interference issue with the IR. Some LCD TV's can cause interference with an IR signal which will cause problems with the remote. Something you can try to fix is disabling the Auto Back-Lighting feature on the TV itself and see if that helps. If not, the easiest way to fix would be to make the TV1 remote UHF.
This would require a 21.0 remote as a 20.0 is IR only. Look on the back of the remote at the top to see what model you have.
With a 21.0 go to System Information. On the back of the remote inside the battery cover is a switch that says IR And UHF and make sure the green 1 is showing. Flip it to UHF and press Record 3 times. The Primary Address should now have UHF in it. Try the remote and see if it works.
If it doesn't or you continue to have problems you can post here or email me at thomas.faust@dishnetwork.com
Tommy Faust
DISH Network
Apr 13, 2011 | DISH Network IR Remote Control
I have a 4.4 ir/uhf pro dish network, i did oened and i an not close it because does have a part that i do not know how it goes, this part is only in the #2 remotes thats mean in the 2nd tv and has a part...
Himarieyvette2, my name is Mike Houston of DISH Network and I was going over yourpost and see where you're 4.4 IR/UHF Pro remote did not have a part. If youtake out the chip it is a two sided tab and will allow the remote to work forTV1 (Green side) and TV2 (Blue Side). I will send this link http://www.dishnetwork.com/SupportSection/setup-remoteto help with the steps to setup the remote.
Feb 26, 2011 | Universal Remote Control DISH Network...
I have 722 and a ir/uhf remote. Remote is set to uhf. All was ok until about 2 weeks into use and remote does not work unless 6 inches from antenna. I tried wizard numerous times and resetting to ir and...
Hello, this is Becki Barned, with DISH Network customer service. For this issue, since you have already replaced the remote and have the 5 foot coax cable on the antenna, then at this point, we would want to send a tech out for you. The technician can determine if this is an issue with the receiver box, or can set up a back feed for you. I can help you out with this issue further. You can e-mail me at becki.barned@dishnetwork.com .
Becki Barned
DISH Network Customer Service
Jan 16, 2011 | Universal Remote Control DISH Network...
I am trying to find the codes for a Dish Network remote ( 6.4 IR/UHF PRO ) to program TV Emerson LC320EM1 and if possible for the Lenoxx Sound Home Theater. Thanks in advance for any help.
Hello, my name is Daniel Busa with DISH Network customer service below, are the codes for your emerson tv and a limk with instructions if the codes don't work try the powerscan method in the link I gave you.
632,516,627,654,720,532,500,526,534,536,541,573,,590,636,642,648,652
Jan 06, 2011 | DISH Network IR Remote Control
HOW CAN i RESET SAT CODE FOR DIH REMOTE CONTROL FOR DIFFERENT DISH BOX
nmg55
Not all remote are compatible with all our receivers. Depending on the receiver and remote model numbers, if they are compatible you can readdress the remote to the receiver. I have provided a link for readdressing the remote to the receiver. I hope this helps.
Instructions on how to readdress the remote to the receiver:
Remotes and receivers models:
222 -
21.0 IR / UHF Pro
222k - 21.0 IR / UHF Pro
301 -
3.4 IR
311 -
3.4 IR
322 -
4.4 IR / UHF Pro
381 -
6.4 IR / UHF Pro
411 -
20.0 IR
501 -
6.4 IR / UHF Pro
508 -
6.4 IR / UHF Pro
510 -
6.4 IR / UHF Pro
512 -
6.4 IR / UHF Pro
522 -
6.4 IR / UHF Pro
612 -
21.0 IR / UHF Pro
622 -
21.0 IR / UHF Pro
625 -
6.4 IR / UHF Pro
722 -
21.0 IR / UHF Pro
722k - 21.0 IR / UHF Pro
Ray Calo
DISH Network
Nov 06, 2010 | DISH Network IR Remote Control
DishNetwork IR Remote Control Problem
First the only way the 6.3 will work is if it has the green number 1 on the tab facing you. Assuming this is the case you will need a new remote. This primarily is the remote for the second room away from the receiver. Thanks for using Fix Ya.
Apr 15, 2009 | DISH Network IR Remote Control
Remote code for Sylvania LC420SS8
Hello frozen thank you for using FixYa.com for your answer my name is David.
Well I had to do a little bit of a search but one of these codes should help you out.
Sylvania 506, 525, 536, 566,
568, 569, 573, 600,
610, 652, 654, 656,
659, 660, 664, 665,
666, 671, 672, 674,
677, 723, 724, 729,733
I retrieved these from the following link that help you again in the future
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/remotes/IR-to-UHFProUpgradeKit132327.pdf
thank you again for choosing fixYa.com for your answers.
Nov 08, 2008 | Sylvania LC320SL8 Television
I HAVE AREMOTE FROM DISH NETWORK THAT WAS MANUFACUFACTURED BY YOUR COMPANY. IT WILL NOT DO ANYTHING. I KEEP CHANGING THE BATTERIES AND IT SAYS LOW BATTERY. NOW I CAN NOT EVEN CHANGE STATIONS. WHAT DO I...
Jim,
If the remote keeps draining batteries at an unusual rate, which is what it sounds like you are describing, there is an internal fault in the circuitry of the remote and the remote must be replaced. Once you get the new remote I can help you program it to your receiver and to your tv. It is a fairly simple process but will probablty get lost before you get your new remote if I explain it to you now. Make sure that the remote is the same model type that you have now. The remote model number will be on the back and will be a two digit number e.g. 8.0, 6.3 etc. There are three basic types of remotes: Infra red, UHF, and UHF pro which is an IR/ UHF combo; and you want to ensure you get the proper type. Let me know when you have the new remote so I can get you set up correctly again and I apologize for the inconvenience you have had with this equipment.
Sincerrely,
Jim
Sep 28, 2008 | RCA DIRECTV Satellite Remote Control
DISH Network IR Remote Control Logo
674 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
