Question about Gateway Computers & Internet
Wireless device not detected after i did a recovery
    Scholar:
  • 43 Answers
Are you saying your wireless controller on your laptop/desktop cannot be detected?
I would check in Device Manager to see if the card is displayed.
1. Right Click on "MY COMPUTER" and select "PROPERTIES"
2. Go to the "HARDWARE" tab and select "DEVICE MANAGER"
3. Scroll down to "NETWORK ADAPTERS" and expand the component
4. Do you see your wireless network adapter? If so, does it have a "RED X" on it? You might need to enable it by right-clicking on it and selecting "ENABLE". If it has no "RED X" you might need to reinstall it using the original network drivers that came with your computer.
5. If you don't see your wireless network adapter do you see a "YELLOW QUESTION MARK"? If so, expand that to see if you see an unknown device that shows it's a network adapter. If so, you need to reinstall it using the original network drivers that came with your computer.
6. If you reinstalled your network drivers and still it's not working it's possible that the wireless adapter itself is better or you have some system related problem.
This is a preliminary set of troubleshooting steps. I would need to know the results of the above procedures and some additional information. Please let me know if I can assist any further.
MO
Posted on Jul 13, 2008
How do i turn on my hp windows vista bluetooth raido transmitter
To turn your bluetooth on do the following process.
1.Click Start , type wireless into the search field, and then select HP Wireless Assistant from the list.
2. By default, the Status column shows that both of the wireless devices are either on (enabled) or off (disabled). Also, by default, the Action column does not display.
If you want to control one of the wireless devices individually, without affecting the other devices, clickProperties , and then select the Independent controls for installed wireless devices option.
If you have removed the HP Wireless Assistant, it can be reinstalled using the Recovery Manager service.
  1. Click Start , type recovery into the search field, and then select Recovery Manger from the list to open HP Recovery Manager.
  2. Select Advanced options .
  3. Select Software program re-installation and then click Next .
  4. When prompted, click Next .
  5. Select HP Wireless Assistant and then click Next .
Follow the on-screen instructions to complete the installation of the HP Wireless Assistant.
You can verify the device is installed & enabled with Windows Mobility Center.
To turn Bluetooth devices on or off, do the following:
  1. Click Start , type mobility into the search field, and then select Windows Mobility Center from the list to open the Windows Mobility Center. Alternately, press the windows key and the letter x key at the same time.c01577398.gif
  2. Use the drop-down menu items in the Integrated Wireless Devices selection to turn the devices on or off.
    I think the above tips are helpful to you.
    Thank you for using fixya.
Oct 05, 2013 | Radio Communications
My intel wireless adapter displays error code 10 and this device cannot start.
Suggest you reinstall the driver from your drivers cd that you got with your laptop. Alternatively get driver from the manufacturer's website.
If you still get this issue, then usually points to a hardware failure
Make sure that you have already tried switching the PC off and back on again.
As a last resort, you may want to recover your pc back to its factory setting with your recovery disks and if still not detected, almost certainly a hardware problem
Hope this helps
Nov 12, 2010 | Intel PRO/Wireless 3945ABG Network...
I hava a hp 13" laptop that wont show wireless option in the internet properties. I have a wireless Lan Mini PCI card, but it is not being detected. Is there away to re enable the wireless?
Hi. Please check first if your computer was able to detect the device. You can look for this device in control panel then click system then click device manager. Your wireless adapter should be present under network adapters. f computer was able to detect the wireless adapter. Try to turn off/on the wireless switch. Usually, wireless switch is located infront of the laptop or on the side. You can also try pressing Fn + F5 key to disable/enable wireless network card.
Jun 13, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
My broadcom wireless lan adapter for windows vista not detected in device manager and hp wireless assaistant not working.
You can run HP update to download and install drivers on your PC/Laptop, or run Microsoft update too.
Your HP PC came with a tool called Recovery Manager, Click the vista start menu and in the search bar type (Recovery Manager) without the parenthesis and it should display programs like RECOVERY DISC CREATION and RECOVERY MANAGER , please select the RECOVERY MANAGER an if you have VISTA USER ACCOUNT CONTROL turned on you will have to allow the program to run.
OK, once program launch, select the advance Options and click on HARDWARE DRIVER RE-INSTALLATION and click next. follow the screen instructions to re-install the driver or drivers.
Make sure you are not running any other program when using recovery manager.
GOOD LUCK
Sep 15, 2009 | Acer (D10709-002) (D10709002) 802.11g/b...
Belkin f5d7051 not detecting
ivegot the same problem, it worked previously and then randomly it stopped working. I have reinstalled windows 7 and it is still the same, i cant install itand cant detect the usb adapter. Have you found the solucion? Please email me to marcos15eliseu@hotmail.com
Jul 27, 2009 | Belkin (F5D7050) (F5D7050VSNPDQ) Wireless...
Wireless on/off button doesn't detect wireless card.
drivers possibly or if its a switch then a bad switch
Apr 30, 2009 | Acer Aspire 6920 Notebook PC
My laptop has wirels ess card but in device manager says no wireless adapter what to do
in device manager do you see the driver
if you do click and update
or control panel add new
click next then yes for already installed
then automatically detect
if that does'nt detect then go back and choose option select from list
or you can go to recovery and reinstall your drivers and applications
let me know how you do
and don't forget to rate me
Feb 01, 2009 | Computers & Internet
I cannot enable my wireless adapter
the drivers needed updating, got to love Windows.
Dec 18, 2008 | HP Pavilion dv4000 Notebook
Wireless internet drivers
check in device manager, is your wireless card detected in device manager ?
if not, it's look like your wireless card is defective.
if yes but there is question mark, you need to re-install wireless driver.
if yes, and it isnot detect any network, is wireless card in your device manager enable ? if disable, right click on wirelees card and choose enable.
if step above not working, try to enable using wireless switch .
Jul 05, 2008 | Acer Aspire 5000 Notebook
Computers & Internet Logo
111 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
