Question about HTC Touch P3450 Smartphone
Want to remove the clock
My HTC touch phone diplays clock & other shortcut items on the front page of the phone. I dont want all these things.. which is hiding background picture of mine... Pls tell how to remove those things...
  • 40 Answers
Just follow this
- press "Start"
- choose "settings"
- enter "today" in the first tab named "private"
- choose the second tab named "Elements" or something like that
- toggle "HTC Home"
- press "OK" in the right top corner of the screen
- no more clock on your screen
Posted on Jul 22, 2008
How do i fid the message icon to put back on home screen ?
After unlocking your HTC One, look right above the HTC logo on the bottom center of the phone face. Right above it is a square of nine white squares. Touch that square. Now, you'll see a list of ALL applications installed. That list can be sorted in multiple ways. To sort alphabetically, touch and hold anywhere on that screen of icons and pull down a bit. A menu will appear on the screen allowing you to select to sort alphabetically.. Once that's done, look for the Messages icon. 3112a4d4-3eeb-4c5b-9d46-d1057184e632.jpg
Touch and hold the icon. At the top of the screen a new menu will appear. While still holding the icon, drag it up to the word :Shortcut". The menu will disappear and your desktop will be available to drop the icon onto. If there is room, it'll now be on your desktop (once you let go). If there isn't room, while still holding, drag it to the left or right side to change desktop pages. Locate a page that has room, and let go. The icon will then be on that page. If you have no room, then you'll have to create a new page. If you do need more pages, repost for that instruction.
May 21, 2014 | HTC Mobile Phone One S Black
Tip
Nokia 5800 Tips
5800 Tips and Tricks
1. To bring out the Shortcuts on your Screen/Desktop-> Settings/Personal/Home Screen/Home Screen Theme and select Shortcut bar, you can then select which shortcut to display if goto "Shortcuts". This will also bring out the "Track" playing being displayed when you open the Music Player.
2. Tap the Clock to bring out the Clock menu and make your alarm, alarm repeat is now built-in.
3. Tap the "General" or Date (the set Profile besides the clock) and the Profile selection menu pops out, almost similar to pressing the "Power" button in all S60, but here the Remove memory is not shown, but "Calendar" shortcut is included and the other profiles as well.
4. If you are on the Numeric Keypad, pressing the [#] key alternately will toggle the General and Silent Profiles, same as before, which means long press on zero [0] will bring out bookmarks for the Web.
5. Tapping on the displayed To do or Calendar entry will bring you immediately to that particular item.
6. Tapping the Active Icon on the Top Left (near the battery indicator) will give you shortcuts for any of the active icons.
7. Long press on the Green Call Button will still activate the Voice Command Prompt
8. Long press on the center button is similar to the Long press on the "Menu" key (the yin-yang key on most S60) which will bring out the menu for all the active applications.
9. Go to Applications/File Manager and setup "Backup" for automated backup schedule of your phone data.
10. How to update your Nokia 5800 firmware using your phone.
Presss *#0000# to display phone factory information and firmware
Now press options and select check for updates
The newest update is sent to your phone from nokia
Download and install updates.
This is done using GPRS or WIFI Connectivity.
General Tips
1. Use Dialer and press # for about 2 seconds will switch the profile between Silent and General; press and hold 0 will open the web browser; press and hold 1 will open the voice mailbox
2. There is a shortcut key for Music, Gallery, Share, Video, Web shortcut at the top right corner just below the front camera
3. Press and hold the Green caller button when standby mode will activate the voice command. You could call the name from the contact or application name.
4. Organize your sms by grouping them like outlook by Messaging -> Option -> Setting -> Text message -> Other -> Show messages in groups -> Yes
5. Notification light will blink if there is unread sms/missed call. It could be turned off at Settings -> Notification light -> Off
6. If the touch input is not accurate, you could calibrate your screen at Touch Input-> Touch Screen Calibration -> ( Tap around the 4 dots at the corner)
7. Turning control functions:
a. Rotate your screen horizontal or vertical
b. Silence your phone for incoming call by rotate your phone with screen facing down.
c. Snooze the alarm by rotating phone screen facing down
8. Theme effect will give 3D and transition effect if on but will slow down your tube considerably. Settings -> Personal -> Themes -> General -> Themes effects -> On/Off
9. Shortcut to exit application : Press and hold the middle white button then press and hold the program that you wish to quit, an open/exit option will pop out (useful for those haven’t install handy taskman yet)
10. When using handwriting input, slide from left to right is Spacebar, right to left is Backspace
11. Organize your menu by Menu -> option -> organize. You could drag and drop the location of the application you wish to relocate.
on May 12, 2010 | Cell Phones
Touch Pro2 won't go past the htc load up screen
Make sure your TouchFlo app is turned on. Goto Start, settings, Personal TAB, Today icon, Items Tab. Scroll down the list of items and check the TouchFlo 3D item then click OK.
Apr 14, 2010 | HTC Touch Pro Smartphone
I have a htc touch p3450 and is frozen i want boot but and dont now how
  1. remove the battery cover.
  2. observe that by the USB port, there is a small indentation. This is the reset switch access.
  3. Keep the slider closed.
  4. power the phone on.
  5. press the “talk” and “end” buttons; while holding them down, use the stylus to probe into the reset switch hole at a 45 degree angle to the major axis of the phone.
  6. when you get to the “press enter to reset the phone” page, press the center dpad.
Mar 05, 2010 | HTC Touch P3450 Smartphone
Is HTC Touch Viva T2223 upgradable to WM 6.5?
yes it is, but you cannot upgrade it to the new upcoming 7.1
Jan 17, 2010 | HTC Touch Viva Cell Phone
Russian to english?
to change your language setting back to english Turn on your HTC Touch. Touch "Start" on your Home screen. Then "Settings."> System > Regional Settings. Select the proper region for english language then. Touch "OK" when prompted and "Exit."
  • Confirm that your selection has taken effect by checking the language of any menu item from the Start screen. Your selections should be in english.hope this helps pls do let me know.thanks.
  • Jan 11, 2010 | HTC Touch Cellular Phone
    I lost my external clock on env touch how do i get it back
    that ^ is for the internal clock, for the external clock, you need to go to your shortcuts and add 'clock widget" then u grab that shortcut and drag it to the top of your screen
    Dec 21, 2009 | LG enV Touch VX11000 Cell Phone
    I can't figure out how to remove shortcuts from the home screen of my LG Chocolate Touch. I can drag shortcuts such as calendar or calculator to my home screen so that I can simply open them in one touch....
    go to your main menu, go to settings. go to displays. scroll down to "short cut bin" snd make sure it is turned on. a faded arrow will now appear on the right side of your display screen. drag the icon you want to get rid of to the arrow which will turn into a trash can.
    Nov 12, 2009 | LG CHOCOLATE VX8500 Cellular Phone
    My clock has shrunk on my HTC Touch Pro
    The onlu thing I can think of is manually going to the settings, go to system, scrool down to remove programs, and click on the file name of the download and removing it that woay. THat should work and if it doesnt, take it to ur comapny wtore. They will most likely give u another one for free because they are lazy.
    Jun 22, 2009 | HTC Touch Pro Smartphone
    Htc touch diamond
    i have a HTC diamond phone .& i want HTC diamond software. so please sand me . ma mail address . bye
    Jan 29, 2009 | HTC Touch Diamond Smartphone
    HTC Touch P3450 Smartphone Logo
    111 people viewed this question
    Top HTC Computers & Internet Experts
    SANJEEV KUMAR SURI
    SANJEEV KUMAR SURI
    Tom Chichester
    Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
