Question about Shuttle MK40VN Motherboard
Mk40vn My board is not recognizing my 80gig hdd. It only can see 30gig. It also cannot see my amd xp 2400. It only can see 1800.
  • 2 more comments
  • cfuller77 Jul 13, 2008
    I am using windows xp.I is a seagate hdd. I finally got it to recognize the hdd in the bios. It still is showing 30gig in xp. I may have to reload xp unless you have a better solution. It is still just seeing 1800mhz amd cpu in the bios and xp. I installed a 2400 amd xp. The specs say it should accept that. I wonder if I need to flash the bios? My bios is dated 2003. Your help is appreciated! Thanks cfuller77
  • cfuller77 Jul 18, 2008
    Well I got it to see the drive in the bios by changing the jumper on the drive! I also got it to see the cpu by changing a jumper on the board. I tried to run fdisk to format the drive. I did that, now I keep getting this cmos wrong when I boot up. It gives me the option to go to set up or f2 to load default. I tried both and reset cmos and bought new batt. It still will not keep the settings. Do you think it good be the cmos chip? Is there a difference between a cmos or bios chip? Oh I also flashed the bios with a windows utility on the shuttle website. I am running a old 6 gig drive in there now with xp on it. I can get it to boot with my cdrom to load xp on my 80 gig, because it won't save the settings. Too confusing? Help if you can cfuller77 I was told I can buy that cmos chip
    I found an bios upgrade on softpedia. It says 2005 Maybe I should try that first? What do you think? So you think that chip is bad? i will try to contact shuttle. Let me know if you have any more insight. I might do just as well finding a decent board that would fit that cpu. Here in dallas they have a comp. fleamarket twice a month. thanks cfuller77
  • Mike Peluso
    Mike Peluso May 11, 2010
    Are you seeing these from within Windows or while in the bios?
    What operating system are you using?
    What hard drive are you running. Ex: Seagate, Sumsung, WD, Maxtor?
    President:
  • 2,351 Answers
I did go to Shuttle to look for a bios upgrade & Shuttle does not list any bios files. I found one bios file at Softpedia & downloaded it to see the date. The .rom file is dated 11/28/2003. I gather your 2003 is close.
http://drivers.softpedia.com/progDownload/Shuttle-MK40VN-Bios-103-Download-6730.html
The current bios does not allow you to clock the CPU to its correct frequency.
AMD XP 2400+ frequency
Bus speed (MHz) = 266
Clock multiplier = 15
You can try turning on the over clocking, see the manual page 57. These setting would be normal for the AMD XP 2400+ CPU.
I'm looking at the max frequency for the Shuttle is topped out at
198MHz. As far as the IDE hard drive I'd like you to download the manufactures bootable floppy software & check the drive with this floppy disk. (Works in a dos like mode). No windows involved. The Mfg's software will test & repair the drive if needed & will also set the drive up, set cluster size, choose NTFS FAT or any other FAT you wish for windows XP. It's better than windows format. You'll fine there are other options you can turn on & off if you wish. (If you run the Mfg's software, disconnect any other hard disk drive by removing the data cable).
On a personal note, I always use the Mfg's bootable software to set up any drive be it IDE or SATA I, SATA II.
Shuttle site's.
http://global.shuttle.com/download03.jsp?PI=516&PL=2
Live chat:
http://us.shuttle.com/Scgsupport/Support2.htm
Good luck cfuller77!
If you find you need more help, just ask...
Mike
Posted on Jul 13, 2008
  • Mike Peluso
    Mike Peluso Jul 13, 2008
  • Mike Peluso
    Mike Peluso Jul 18, 2008
    Hi again cfuller77.
    Go to this link & call or email Shuttle to buy a new bios.
    http://us.shuttle.com/Scgsupport/Support...
    The term cmos/bios means the same. You can boot to the cd-rom by pressing the F8 key every two seconds. This will bring up windows boot device window. Use the up & down arrow key to high-light the cd-rom drive that you have the Win CD in.
    Since flashing the bios did not help & replacing the bios battery did not help, you're only other option would be to replace the bios chip with a new chip. The manufacture Asus charges $5.00 for a new bios, I would think Shuttle's price would be similar.
    If you call or email Shuttle it would not hurt to explain the issue's you are having with their MK40VN MB. I do not work with many Shuttle boards. I could be missing something here.
    Mike
Mk40vn no beep no powerled some hdd led some cd led after reset cmos jumper in right position no other jumpers are set on board i have no manual for jumper settings please help me susanne
in some motherboard when you change the c mos jumper the motherboard doesn't switch on change the pin to 1 and 2 normally which is c mos normal and 2 and 3 is to clear c mos you will see marking of all the jumpers in the motherboard set the pin correct to normal and also remove the power connector from the motherboard and short the green and the black wire and see whether the smps works if not working change them
Oct 01, 2011 | Shuttle MK40VN Motherboard
Ibm thinkpad r60 hard drive not recognized by
make sure your operating system having a sata drivers,if u r using sata HDD,try to install vista or 7 it show HDD but if you run XP it not detect HDD because XP dont have sata drivers,or burn XP using Nlight software add sata drivers in that
Nov 14, 2009 | IBM ThinkPad R60 Notebook
"error loading operating system"
Sounds like your Windows XP installation failed. Run the XP install again making sure to delete the existing partition and then create a new partition. You could also have a bad drive out of the box.
Sep 15, 2009 | Dell Latitude D600 Notebook
M/b cannot recognize SATA HDD
This is common to other mainboards, the SATA controller have it's own BIOS, but it only works correctly using two identical SATA HD's at same time for data protection purposes. If you have a free PCI slot there are expansion cards based on VIA chipset VT6421 with 2 internal SATA ports, other external and one IDE. See one here
May 11, 2009 | MSI K8MM-V Motherboard
HDD replacement
Depending on the age of the device and the drive architecture, there should be no limits. Go as large as your budget allows. Remember, only certain operating systems can utilize drives bigger than 137 GB (Windows XP SP and higher, Windows Vista) without splitting into multiple partitions.
Apr 01, 2009 | Computers & Internet
Winxp instalation
hi,
There is not way to install a windows xp os without SATA drivers. If you don't want to use the floppy disk to make the os recognize the HDD, you can integrate the drivers in the Windows Xp installation Cd, using software like Nlite.
Another solution is to use a IDE HDD, the old kind with the 80 wire ribbon cable.
Mar 31, 2009 | VIA ASUS A7V600X MB AMD KT600/ 400FSB/...
I have a gigbyte GA-MA790XT-UD4P mother board that when I try to install XP on a new Seagate 1TB Barracuda HDD, that it won't recognize during the install process
If your hdd is sata and you have an old mobo , windows xp (onlycvista will) will not recognize it. Integrate sata in xp (use nliteand goolgle how to) or use the flloopy disk to run sata driver
Mar 29, 2009 | Gigabyte GA-K8VM800M Motherboard
Upgrade possibillities for Acer Aspire T180
Specifications
Product
Aspire T180 Language
English Model
Aspire T180 Specifications Specifications
Processor
AMD AM2 Athlon 64 x 2 or Athlon 64 or Sempron (940 pin)
emory
256MB DDR2 533/667/800 SDRAM expandable to 4GB
1 Ok now that i found the spec for your computer here we go you can install the amd 64 x2 but not Phenom x4 9950
2 As for the graphic card you seem to know a little about computers so you can install and pci express x 16 graphics card that only needs one slot but remember some need power and this mean you my have to upgrade your power supply.So really you can by any single slot pci express graphics card for your computer so it comes down to how much you want to spend.
3.Ok for ram your max will be 4 gbs most likely ddr2 which mean that you have 4 ram spot in your computer.
hope this help please vote for me.
Oct 26, 2008 | Acer Aspire™ T180 PC Desktop
Cmos wrong
you need to enter the BIOS usually del key or f2 will come up lower right corner boot screen when in BIOS set for default close and save reboot see if this helps
Jul 17, 2008 | Shuttle MK40VN Motherboard
Duel boot system first xp then vista
Wow....
First I would check the BIOS settings. Make sure that the slave and master jumpers are correct on the drives.
Wouldn't it be easier to make one drive Windows XP on one drive while running Vista on the other?
It would make things easier to troubleshoot.
Jun 12, 2008 | Computers & Internet
Shuttle MK40VN Motherboard Logo
530 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
