I connecteit be corrected. T
I connected a 4-port USB (Micro Innovations) Hub to my computer. When I connect somethibg to this hub, it states that its being connected to a USB 1.0. But the hub is connect to a USB 2.0. Why is this happening? Can it be corrected. Thanks
  • 95 Answers
Its probably a USB 1.1 hub or the comp only has USB 1.1
Posted on Oct 29, 2009
    Genius:
  • 1,011 Answers
U must installed the USB 2.0 driver in your install. The problem is they support USB 2.0 driver. so u must updated. ok
Posted on Jul 18, 2008
I installed a 4 port hub to speed up my file tranfer to a flash drive. The files transfer but not any faster then using the front usb ports. It is normal?
Yes. While the speed from the USB device to the USB hub may be faster (USB 2.0 protocol, rather than the slower USB 1.1 protocol), your hub is still connected to a USB 1.1 port on your computer.
Aug 22, 2010 | Belkin ExpressBus (F5U021) 4-Port USB Hub
My Mouse Fails To Work On One Of the USB Ports
I have had several ports go bad for no apparent reason. its happened on internal and external devices.
Frankly, unless this is a thing of principal for you I would just go and order a new hub from Amazon for a few bucks and be done with it. Even if its under warranty you would probably be required to ship the dead one back so that would cost more than getting a new one.
Just my 2 cents
Apr 01, 2017 | Micro Innovations (USB204N) 4-Port
How do I set up a d-link dub-h4 to my laptop I have a power connection, a connection on the rear of the hub-4 going to an adapter connecting to the ps/2 connector on the laptop. Do I need one of the...
The connection on the rear of the hub should go to a USB connection on the laptop, not a PS/2 connection. A PS/2 to USB adapter is used to connect a PS/2 keyboard or mouse to a USB connection.
Feb 23, 2010 | D-Link (DUB-H4) 4-Port USB Hub
I connected the external floppy drive to a USB hub which in turn is connected directly to a USB port on my Dell desktop which runs Windows XP Home Edition 64 bit version and the drive just runs and will...
Yes, the external floppy drive must be connected directly to a USB port on the computer instead of to a USB hub.The PC can't see the drive thru the USB hub. Applies to both 32 and 64 bit.
Sep 07, 2009 | Computers & Internet
4 port USB hub not working...
Try connecting the hub to another USB port. You may even connect this same device to another computer and check if that works. This will help isolate the issue better.
Jun 23, 2009 | Dynex 4-Port USB 2.0 Hub
Iogear 4 port USB 2.0 HUB (Model GUH285) now working properly
I think it clearly states that the device is defective.... you need to call IOGEAR for RMA if its still under warranty
Jan 25, 2009 | IOGear 4 Port Hi-Speed USB 2.0 Hub
Installing USB Hub
After installing the USB controller card into a PCI slot inside your computer, connect the 4 port hub to it with the supplied cable. (at the back of the computer)
Do not connect the DVD Recorder to the old usb ports. They will still work, but obviously not 2.0.
Connecting the power supply for the hub is optional, but usually a good idea.
If your computer still doesn't recognize the hub, make sure you have all of the latest windows updates and try running Add New Hardware in control panel. Also, just unplugging the hub and plugging it back in will sometimes work. Use a different port on the controller card if necessary.
As a last resort, you may need to disable the onboard usb controller through your system bios.
Good Luck
Sep 11, 2008 | CyberPower CPH420P 4-Port USB Hub
USB hub
Do you have Windows XP and at least Service pack 2 installed.
Service Pack 2 comes bundled with the neccessary drivers for USB 2.0
In device manager under the USB heading you must have:
PCI to USB Enhanced Host Controller
In the list.
Jul 12, 2008 | Micro Innovations (USB204N) 4-Port
USB204N Micro
im using vista too, when i had 2 hubs only one was working. but i did have the hub plugged into the other hub once i linked it directly to the pc's usb port, it worked... the problem was i wanted that port for an external hard drive, but now i just plugged that into one of the hubs!! problem fixed
Oct 25, 2007 | Micro Innovations (USB204N) 4-Port
Computers & Internet Logo
344 people viewed this question
David Payne
David Payne
