FixYa.com
Tags:
Car Video Players
Generic problem for all Car Video Players
Grond Wire
posted by rchrist364 on Jul 13, 2008
My names Alex, I have a jensen vm9512. Where do I plave the pink wire to ground it?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 23, 2008
Not Rated (0)
j_del
Rank:Guru Guru
Rating: 90%, 197 votes
You should be able to use any screw that goes into a metal part of the car to ground it. Simply grounding that wire may not work with the Jensen (it didn't on mine).
During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Audiovox VM9512 Car DVD Player Audiovox AVD300T Car DVD Player Audiovox AVP7380 Car Video Player Audiovox D1020 Car DVD Player Audiovox VOD102 Car DVD Player Audiovox MVDVD4 Car Video Player Audiovox MVP300C Complete Mobile Video System Car Video Player
Can you Help with these Car Video Players problems?
Lanzar SDBT75N Car DVD Player
Monitor wont flip up
The monitor will slide out but... Answer This...
Panasonic CQ-VD7001U Car DVD Player
Panasonic CQ-VD7001U Car DVD...
do i need a power cord to hook... Answer This...
Kenwood KVT-715DVD Car DVD Player
green wire hookup?
does the green wire have to be... Answer This...
Car Video Players
setting angel for dvd to eject
when attempting to eject... Answer This...
Car Video Players
Farenheit TID-407 AM/FM/DVD/...
when wanting to eject dvd, the... Answer This...
Repair Service
Find Car Video Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
