Question about Acer Veriton 3600GT PC Desktop
Help my computer wont start if I close my lid ....
My acer wont start if i close my computer lid . I usually lay down my CPU unit and Monitor on top of that CPU unit . The problem is when I open the CPU casing , the computer will work just fine but if I closed the casing the computer wont start . The CPU just run but no hard disk activity . Help me plz because this thing is infuriating me much because I got dateline to meddle with and this kind of situation just add up more oil to the fire.
  • Hanzza87 Jul 15, 2008
    Thanks , surely it was some the SATA cable to the HD that was loosen. And yeah , its respond at all when I hit the power button. The monitor is on , the fan were working just fine and there is a noise for the fan unit. But again thanks for helping me
    Scholar:
  • 43 Answers
It sounds to me that there might be a lose connection somewhere. The first thing to do is make sure that all cables are securely fastened.
When you say that your computer won't start when you put the cover back on and lay it on it's side does it respond at all when you hit the power button? Lights, anything displayed on the monitor, fan noise, etc.? Also when you leave the cover off is the computer laid on it's side like when the cover is on? does it work laying on it's side with the cover off?
MO
Posted on Jul 13, 2008
  • Michael Ortega
    Michael Ortega Jul 15, 2008
    Were you able to get it working?
Where is the lid switch on an acer aspire5349 laptop
Lid Close Switches of the post, and spring type, are usually mounted close to the Right Hinge. (Cabling goes up through the Left Hinge)
Magnetic Lid switches are usually mounted in with the Touchpad, and it's mounting bracket.
Looking at the Service Manual came to no avail.
Believe this is where it's located, Cory; or at least how to bypass it,
http://www.mp3car.com/acer/128279-where-is-the-lid-switch-acer-aspire5315.html
Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to the 'paragraph' that starts with Aspire 1200. (1200 in Blue)
Drop down to the 7th line. (5330 in Blue)
Scroll across, click on the blue -> 5340
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (5340), it may take up to 30 seconds, before the first page comes up.
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 13, 2012 | Computers & Internet
Flashing green light and monitor wont start
There are one or two capacitors that open in the power supply, sometimes it will have a bulge at the top, making it easy to spot.
Apr 05, 2012 | Acer Computers & Internet
My display unit of my ACER PC show no signal,but it is on. what can be the problem?
first shut down you computer remove the covers of the cpu then locate the memory and remove them wipe them clean with clean cloth and switch the computer on with out the memory and see if you hear any beeps if you hear beeps insert the memory and switch on the computer if still no beeps then remove the processor fan and clean the surface of the processor fan and the processor apply a thin layer heatsink solvent and clip the processor fan tighty to the socket
Jun 02, 2011 | Acer AL1716 17" LCD Monitor
Fisher Pakel dish drawer sends F1 alarm flashing. It usually happens when there is a drop or change in water pressure. Have had 3 repairs on this disappointing product. Only repair person for Fisher...
F1 is a flood fault ir happens when the machine detects water on the base of the unit, to clear this fault you can remove the bottom draw and use a towel to clean up the water this should clear the fault, But usually there is only water on the base if the lid is not closing properly, this can happen due to you putting long utensils in and the lid cannot pull down or you have faulty lid actuators witch is probably the case and they wont pull the lid down correctly, So if the lid wont come down properly water splashes over the top and floods the base. :)
Jul 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
Computer wont start acer aspire L-100
CPU overheated? When you cool it down it will start. You can check whether there are lots of dust on the CPU fan and the chase of the machine, they might block the air flow and overheat the CPU.
Jul 08, 2010 | Acer Aspire L100 PC Desktop
I would like to close the lid on my Aspire One Netbook and keep using my computer with my Acer Monitor. Is this possible without hibernating?
Yes this is you need to go in to Power Options in the control panel you will see when lid is closed set it to do nothing.
That will do it for you.
Good Luck and Happy Computing
Jan 09, 2010 | Acer X223WB 22" WIDESCREEN LCD Monitor
I just purchased a new cpu and plugged in my Acer X203H monitor that i have only had for around 3 months and when I turn on the computer and monitor, the monitor power light flashes orange and blue and has...
Sounds like your PC is diplaying out of your monitors range. Try pressing f8 while booting up to get safe mode. then turn down the video resolution to display what your monitor can handle. Good Luck.
Nov 20, 2009 | Acer X203H bd Monitor
Connecting an external monitor to acer 5720
I have had this before with my Dell Latitude C540/640. I don't know the ACER 5720 but here's a couple possible fixes for you.
1. Press the function key ( "fn" key, generally a blue key or blue lettering and usually in the bottom left corner of your keyboard) and press F8 (may be a different key on your laptop, again, not familure with the acer. The key usually has either CRT/LCD printed on it, or two monitors on it, one its just an outline of a monitor and the other is filled in. This will run you laptop through the three monitor options it has. (LCD - LCD & External - Just External)
2. Try closing and opening the lid of your laptop. Sounds a bit strange but it works sometimes for me. My guess is when you close you screen it would "dim/turn off" the LCD and re-opening it convinces it to turn the screen back on.
Hope this helps!
-David-
Jan 09, 2009 | Acer Aspire 5720 Notebook
ACER MONITOR AL1912
is your monitor and the cpu are of the same make,if not some times you get this problem because your monitor is not compatible with your cpu.you can solve this easily with help of your hardware vendor
Nov 04, 2007 | Acer AL1912B 19" LCD Monitor
Black Screen on ACER LCD 1916 Monitor
see there is power in monitor and check also that your monitor is getting signal from cpu just remove the data vga data cable from cpu and see is it showing any massage on screen like check signal or any other massage. and check your keybord also by pressing num lock key see the light is on and aoff when you pressing the num lock button . if nothing is happen that mean your monitor is not getting signal from cpu and it is not monitor problem . bye
Sep 25, 2007 | Acer AL1916W 19" LCD Monitor
Acer Veriton 3600GT PC Desktop Logo
195 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
