Hey i have a 32 inch sharp aquos TV, about 2 months old. Today i discoved a very small faded black line going horizontally right in the middle of the TV. It is not noticeable far away, but up close it bothers me. Can anyone tell me why this is happening and how it can be fixed? Thanks so much.
Why does my sharp Aquos TV go out of resolution everytime I turn off the Wii game that is hooked up to it? Then I can reload Optimum cablevision- all I get is the program guide. Help
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
i need a pedestal stand for sharp aquos 32 inch tv and do not know where to get. check on line it seem no one has it. where can i get one? do not want to spend a lot of money not more than 50 dollars.
when it goes black then check with flashlight 2 in from screen and see if you see a picture, if so then inverter board is going out, you can google your model and inverter and find the replacement.
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
yes and no. That particular tv you have is done for, but if you just purchased it 6 months ago, you are still within you 1 year warranty with sharp. they will ask you to take it to a authorized service center and you need to follow through with the process. about a week or 2 will pass and the service center will deem the unit unrepairable and sharp will replace it if they cant solve the problem. give em call..good luck 2u
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
