Even though you Uninstall the Game, some files would be stored in the Registry. All you need to do is to Remove the Files Manually from the Registry. I will guide you through the steps:
Note: Before doing this, you need to uninstall the Game first
1. Click on Start
2. Go to RUN (pressing “Windows” + “R” keys simultaneously)
3. In the Box type "regedit" > click Enter
4. A box will pop up with title = Registry Editor, In that Select "HKEY_CURRENT_USER" > Click on "Software" >
Note: These are all the programs which are installed in the computer.
5. You need to search for the EA game Folder > The Sims
6. Now Right Click on EA games Folder and select Delete and click Yes.
7. By doing this, which would delete the Sims files from the registry
Restart the computer and Reinstall the Game.
I'm sure this would work for you.
If you wish to downgrade to XP you'll need to purchase an XP disk and then do a reformat on your computer. As far as being able to completely remove all of the files from the Sims 2 from your pc...
Login to Windows as your Administrator or primary ID
Go to your "Start" Menu
Go to "Control Panel"
Go to "Programs and Features"
Single click on the Sims 2
At the top of the folder next to "Organize" and "Views" it will say "Uninstall/Change" Click on "Uninstall/Change" it will ask you if you also want to delete all saved games. click yes then follow any further prompts it gives you. This should solve your problem for you.
