Question about Husqvarna Designer I
Husqvarna Viking Designer I (feed dogs will not lower)
Hi! I just bought a well loved Husqvarna Designer I from my local quilt shop today. I have been reading the manual and getting to know my new machine. It sews great, however I can not get the feed dogs to lower. I looked at the manual, took the extension bed off and flipped the little switch on the fron of the bed to the left, but nothing happens. I did this while the machine was on and also while it was off (the manual did not specify which was, so I tried both). Is this problem new operator error or is there something wrong with the feeddog lever. Thanks!
  • 202 Answers
Its likely this machines feedogs have either never been lowered or not lowered for a long time. Thus the old oil has hardend and is causing the mechanism to freeze up. A tech would take the bottom cover off, follow the connections from the lowering knob, button or switch to the feeddogs and putting a bit of oil or penetrant on each moving connection. Don't force anything, gently tap where you beleive its sticking and turn, push or flip the switch, knob or button slowly bit by bit, back and forth until they drop. They will work loose then make sure they get a bit of oil again. Hope this helps. Good luck.
Posted on Jul 15, 2008
Bobbin winder is malfunctioning. Has difficulty engaging in place and will not wind.
VIKING QUILT DESIGNER II USER MANUAL Pdf Download.
www.manualslib.com > ... > Sewing Machine > Quilt Designer II
View and Download Viking Quilt Designer II user manual online. Quilt Designer IISewing Machine pdf manual download.
Viking Husquavarna Designer II Sewing Machine - YouTube
? 1:27
www.youtube.com/watch?v=k0mXebnmzT4
May 30, 2008 - Uploaded by proudpop9pj
Here you can view my Viking Designer II Sewing Machine at work. The first two times I used the foot pedal, the ...
Aug 12, 2015 | Husqvarna Designer I
Viking designer 1
Hi, Free motion quilting is done with your programmed quilting stitches, Lower the feed dogs using the small white dial on the front of the machine behind the accessory tray, pick from one of the quilting stitches. they do make a free motion quilting tool ( I think they call it a hoop), but it just sets on top the material and helps you guide your material thru the machine. Hope this helps
Aug 29, 2014 | Husqvarna Sewing Machines
Husqvarna quilt designer II will not calibrate
Sounds like the touch screen has gone bad. You should take it to your nearest authorized husqvarnaviking dealer. You can find your nearest dealer at http://www.husqvarnaviking.com/us
May 11, 2014 | Husqvarna Sewing Machines
How to read the hours of operation Husqvarna designer 2
You need a service cassette (Service D-card) to do that on the Designer 2 and the Quilt Designer. It is expensive and only available to authorized service techs.
Mar 02, 2014 | Husqvarna Designer I
I can not remember how to lower the feed dogs on my Husqvarna quilt designer and I can not find my manual
I think the Quilt Des. is the same as the Designer 1 (which is what I have) and the lower feed dogs is a serrated dial (looks like part of a circle sticking out of the machine) located on the lower front of the free arm about 2 inches to the right of in line with the needle. You turn the dial towards the left to lower the feed dogs and to the right to raise them.
Oct 09, 2010 | Husqvarna Designer I
4D d-Card Reader/Writer Kit and Husqvarna Quilt Designer II
Assume you are loading your designs using Organizer? Yes? I have very limited experience of this, preferring to use Disk Manager (but you need to have this program which I am guessing you don't).
It is my understanding that Organizer will only load one design to an embroidery media, not a whole menu of various designs. However you obviously are not "seeing" even one design. Did a pre-loaded Husqvarna card come with your machine? I think it should have, but if it didn't then that doesn't help you very much either.
I am wondering if the D-card is not "formatted" for embroidery recognition. The Designer machines like to receive their designs in a certain file arrangement but I'm afraid I can't offer you advice on how to format the card - I do my formatting through Disk Manager.
However, while I was writing the above it did occur to me - are you loading designs that are the .shv format? Your machine will not recognize .hus, .vip, .vp3 or any other format. Please write back to this group and let me know if any of the above was useful to you. I belong to a Yahoo group that deals exclusively with Designer machines, so I will ask the group members if they can come up with any helpful advice.
Jul 01, 2010 | Husqvarna Designer I
Remove thread message in husqvarna viking sapphire 870 quilt
I had this same problem, on my Designer Diamond. I blew it out with an air can and that didn't work, but then I decided to turn it off, then back on and start sewing a line in reverse. That seemed to fix it. My machine is working fine now.
May 29, 2010 | Husqvarna Sewing Machines
How to use quilting feet for designer se
There is a manual for how to use all the husqavarna sewing feet. The old book had a pinkish cover. Check with a dealer or do more checking on line for a copy.
Mar 28, 2010 | Husqvarna Designer I
Sewing Machines Logo
442 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
