Question about Mitsubishi VS-5043 50" Rear Projection Television
TROUBLE SHOOTING TV
I HAVE THE PROBLEM IT SEEMS EVERYONE ELSE IS HAVING A POWER SURGE AND NOW I TRY TO TURN ON TV IT TURNS ON THEN RIGHT BACK OFF AGAIN AND MAKES THE CLICKING NOISE. FIRST WHERE IS THE RESET BUTTON?
    Genius:
  • 2,920 Answers
Youve lost your power supply there is no reset for your model tv.
Posted on Aug 25, 2008
We can't look at our recordings and when we try to click on my recordings the box shuts off
Hi, my name is Cheri Torres and I am with DISH Network Customer Service. I came across your post and wanted to see if I could help. I do have a few questions about the issue that you are having so that I can give you the best possible answer on how to fix this. When you try to access your recordings do you ever get an error message and if so what is the three digit number in the top right corner of the error message? Once your receiver box turns off does it reboot itself and turn back on or do you have to do something specific to get the receiver box to turn back on? One trouble shooting step you may want to try if you already have not is unplugging your DISH receiver from the power source outlet for 10 seconds then plug back in. In order to respond back to my questions you can either post back here or you can also email me at Cheri.Torres@Dishnetwork.com and I will be happy to assist you further. Thanks! :)
Jan 24, 2011 | DISH Network ViP 612
TX-47F430S seems to be the common problem of going back into standby. Powers up shows the logs and then goes back to low power. The light never goes blue. The fiber optical laser turns on and stays on but...
This is known as SLEEP MODE / STANDY MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control2_bing.gif. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These steps are done to over-ride the sleep mode.
Roan
Jan 29, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
My TX-47 was/is in power saver mode. A few days
Simple solutions:
6. These step is done to over-ride the sleep mode.
Roan
Oct 18, 2009 | Westinghouse TX-47F430S 47 in. LCD TV
DELL 926 scan request fail
if you do not have anti verios you get down load free version on internet. i use avast.downnload it and run
Oct 16, 2017 | Dell 962 Photo All-In-One InkJet Printer
DLP tv trouble shooting
Try and clean the filters or the plastic fan guards.
Jul 30, 2008 | Home Security
Surge from lightning strike damaged tv and won't turn on.
Unless you are skilled at trouble shooting power supplies , you will be better off getting a skilled repair center to repair yourset. If its repairable I have seen surges from lightning strikes make the set no longer cost effective to repair.
Jun 18, 2008 | Televison & Video
Tv wont turn on
Have you tried unplugging your set for ten minutes and plugging it back in? Sometimes this will reset it. Also try hiolding the menu and input buttons in at the same time to see if you can enter the self diagnosis function built into the set. You should notice the light blink a two digit code. If thats unsuccesful your probaly looking at some bad capacitors in the power suppies or regulators. How are your trouble shooting skills?
Another problem that may be causing this is repaired by doing the following:
Remove the VP plug and solder a 4.7 mfd 35/50 volt electrolytic capacitor between pins 5 and 11 of the VP connector with the pos lead to pin 5. Solder a .01 cap between pins 7 and 9. You might also want to check out www.FreeFlatScreens.com/default.aspx?referer=7509165 for an opportunity to earn a free replacement for this set with a little effort on your part.
Apr 23, 2008 | Mitsubishi VS-45609 TV
27 inch Panasonic TAU tv won't turn on, then sparks when you unplug and replug it in
You first need to rplace the outlet if it sparks where the surge protector is plugged in as it should not spark for any reason. then you need to make sure thast its not the outlet causing your problem by running an long extensition corn or moving the set to a differant outlet.
Sep 11, 2006 | Panasonic CT-32G11 32" TV
TV Turns off on its own ?
You can check the board where the components are mounted and resolder any that look bad. a brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. all can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced.
Dec 21, 2005 | Panasonic PT-53WX42 53" Rear Projection...
Televison & Video Logo
114 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
