NTLDR is compressed Press Ctrl Alt Del to restart
  • jarenc Apr 03, 2009
    every time i press ctrl alt del it reboots it and comes back to the same screen where it says the same thing
    Scholar:
  • 43 Answers
Did you just recently run "Disk Cleanup"?
The only way I know system files get compressed is through "Disk Cleanup" unless it's done manually.
You can try and boot into safe mode and decompress the file:
1. Restart computer
2. Start tapping the F8 key on your keyboard until you get a menu of boot options.
3. Select Safe Mode
4. Your machine will boot in a diagnostic looking mode, but should allow you to get to your desktop
5. Go to the START MENU and select RUN
6. Type in: cmd
7. Click OK (this will take you to a command line)
8. Type in >cd c:\windows
(Note: not necessary to type the ">". It's only there for reference)
9. Hit the ENTER key
10. Type in >compact /U /S /A /I *.*
11. Hit the ENTER key
12. Let it run it's course until you return to a c:\windows> with a blinking curso.
13. Type in >exit
14. Hit the ENTER key
15. Restart the computer.
I would be anxious to see if this works for you. NTLDR is a system file and might not allow access to it while in the actual operating system. The next option would be to use a 3rd party boot utility like BartPE with the "compact" application packaged with it or the only other option to reload the Operating System. Remember to backup your files before reloading. You could use an IDE/SATA to USB converter to connect your Hard Drive in your computer to another computer using the USB interface and backup all your files. The converters usually cost close to $30.
Let me know if I can be of any other help.
MO
Posted on Jul 13, 2008
NTLDR is missing press CTRL ALT DEL to restart.. How to fix wothout windows xp install or program disk
Try pressing F8 just before it tries to boot, you may be able to get into your system and back up your data. Then check out flea bay for a copy of XP.
Apr 09, 2014 | Dell Computers & Internet
"NTLDR IS COMPRESSED PRESS CTRL+ALT+DEL TO
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
Feb 22, 2011 | eMachines T6524 PC Desktop
I have t3504 emachine and am trying to restore
try replacing your hard drive. the do the restoring again.
Jun 03, 2010 | E-Machines T3504 PC Desktop
NTLDR is missing..how can i log-in to the windows?huhu..pls help
NTLDR is missing Press Ctrl+Alt+Del to Restart hmm..there's still no effect even if i press Ctrl+Alt+Delete..what should i do?
Aug 28, 2009 | ASUS Eee PC 1000H Laptop
NTRL is compressed Press Ctrl+Alt+Del to restart
First you need to boot to the recovery console.
To boot to the recovery console follow these steps:
1. Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer. Click(or press any key) to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3. When prompted type "1" or if you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5. Now you should be at the comman prompt and ready to repair the ntldr file!
Now all you need to do is enter the following commands(in order) and each command on a new line just like you see them here:
cd \
attrib -c ntldr
exit
Your computer should now reboot, and everything "should" work!
Please rate this fixya
Jan 26, 2009 | Gateway GT5220 PC Desktop
NTLDR Missing, Press Ctrl+Alt+Del to restart
What happened is when you changed the drive letters you switched one that should not have been changed.... You need to change it back so the original C: is C:
Because the original NTLDR file was on the C: drive which is the Windows XP Boot Loader and when you swapped it it couldnt find the ntldr on the new C:
From my opinion the only way to switch it back is to reinstall the OS onto the drive you want to be C:
Dec 18, 2008 | Microsoft Windows XP Media Center Edition...
Can i get out of ntdrl compressed
no you need to fet a copy of XP and repair the system, as NTldr is the initial platform for windows to boot from.
Sep 07, 2008 | Computers & Internet
Compressed boot manager
Windows Vista includes a new Boot Manager (BootMgr) that replaces the old NT Loader (Ntldr).
If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529
More Info MS KB 927391
This can usually be solved by checking the boot devices, and if no problems found then use Windows Recovery Environment (WinRE) and perform a "Startup Repair".
If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart
This can usually be solved by using Windows Recovery Environment (WinRE) and perform a "Startup Repair". If that fails then use WinRE to enter the "Command Prompt" and execute these commands:
  • compact /U C:\bootmgr
  • compact /U C:\ntldr
Aug 28, 2008 | Computers & Internet
NTLDR is missing. Press CTRL-ALT-DEL to restart
NTLDR MISSING PRESS CTRL+ALT+DEL TO SESTART. WEN I DO THEN WINDOW WITH ALL THE SET UP COMES. PLEASE HELP!!1
Apr 24, 2008 | Compaq Evo D500 PC Desktop
Computers & Internet Logo
384 people viewed this question
David Payne
David Payne
