MY COMPUTER TELLS ME SYSTEM COULD NOT FIND THE ENVIRONMENT OPTION ENTERED
    Scholar:
  • 43 Answers
What's going on at the time? Can you provide the full error message?
Posted on Jul 13, 2008
File: \Windows\system32\ntkrnlpa.exe. status: 0xc0000098 windows failed to load and no recovery disk
Running the Windows Memory Diagnostic Tool
If Startup Repair is unable to get your system running again, and if neither System Restore nor Windows Complete PC Restore has returned your computer to a condition of reliable health, consider the possibility that you have failing memory. To test this hypothesis, click Windows Memory Diagnostic Tool in the Startup Recovery Options menu. The Windows Memory Diagnostic Tool will ask whether you want to restart now and check for problems (the recommended option) or check instead on your next startup. Because you're having trouble getting to that next startup, you presumably want the first option. For more information on this you can refer the link below.
Make system repairs from the Windows Recovery Environment
http://windows.microsoft.com/en-US/windows-vista/Make-system-repairs-from-the-Windows-Recovery-Environment-from-Windows-Vista-Inside-Out
Run check disk command from Windows Recovery environment to fix bad sector on your hard drive
a) Insert the Vista DVD, and boot from the DVD.
b) As you want to boot the computer from the Windows Vista DVD, you need to press a key, on your keyboard when you see the prompt. You should now see a black screen with a white status bar at the bottom stating Windows is loading files.... After a while, the status bar will turn completely white and you will see a screen stating that Windows is loading. The Windows Setup environment will continue to load and when finished you will be presented with a screen that prompts you for information about your location and language.
c) At this screen you should configure the Language to install, Time and currency format, and Keyboard or input method options so that they are set correctly. When done, press the Next button. You will now be at the main Windows Vista setup screen where you would normally install Vista on to a computer.
d) As we want to repair the computer, you should click on the Repair your computer option. This will bring you to a new screen where the repair process will look for all Windows Vista installations on your computer. When done you will be presented with the System Recovery Options dialog box
e) Select the Vista installation you would like to repair
f) From the system recovery options, choose command prompt and enter the command chkdsk /r.
For both the above steps you can refer the link mentioned below.
http://windowshelp.microsoft.com/Windows/en-US/Help/95b4c03a-ac42-49a4-a90d-8f3736a995271033.mspx
Jun 13, 2011 | Dell Computers & Internet
My pen drive is not detected in any system,when i entered in my laptop ,system tells,one of the USB diver attached to this computer has malfunctioned and window does not reconised it
Please follow the steps as mentioned below to resolve the issue.
1) Turn off the Computer and Disconnect the AC Power and Battery for the Computer.
2) Press and Hold the Power Button for 30 seconds to discharge the Residual power in the Computer.
3) Now reconnect the Power and replace the Battery back. This should resolve the issue.
Bye
Dec 19, 2010 | Computers & Internet
I have just purchased a HP 2133 mini-note. On first installation, installation failed and now it just loops and wont do anything. How can I facilitate first installtion bearing in mind there are no disks...
The majority of these PCs have a recovery partition on the internal hard drive, here is the instructions for using it.
Recovering information using Windows Recovery Environment (WinRE)
Windows Recovery Environment (WinRE) can perform a recovery from either an optional external hard
drive or from recovery discs.
CAUTION: Using Windows Recovery Environment (WinRE) will completely erase hard drive contents
and reformat the hard drive. All files you have created and any software installed on the computer will
be permanently removed. When reformatting is complete, the recovery process will restore the operating
system, as well as the drivers, software, and utilities from the backup used for recovery.
To initiate recovery using WinRE, follow these steps:
NOTE: This process will take several minutes.
1. If possible, back up all personal files.
2. Restart the computer, and then press f8 before the Windows operating system loads.
3. Select Repair your computer.
NOTE: The "Repair your computer" option is displayed only if the WinRE partition is intact. If the
option is not displayed, refer to “Recovering information using a Windows Vista operating system
DVD (purchased separately).”
4. Follow the on-screen instructions.
5. Click Next.
6. Select your user name, type your password (if applicable), and then click OK.
7. If you are using recovery discs, insert the last disc of the recovery disc backup set.
NOTE: Inserting the last disc of the backup set confirms the presence of a valid backup. If you
insert any other disc, the backup will not be recognized.
– or –
If you are using an optional external hard drive, connect it to the computer.
8. Click Windows Complete PC Restore.
9. Follow the on-screen instructions.
this is getting long , so ill will post more steps in comment.....
Nov 20, 2008 | HP Computers & Internet
When I restart (and sometimes when i use start)my computer freezes at HP invent. Then I have to turn it off by pressing the ON button for 5 or more seconds. Wait a few seconds and press the ON button again...
Try this, it may work for you. What I’m going to suggest is entering the DOS environment and making necessary changes to get your pc up and running.
- Reboot> At reboot watch for DOS screen option “enter setup” via a F button option. You have to watch closely because on some pc’s this option goes by quick, so be ready to act. Once in the DOS environment navigate to “boot options” choose safe mode . Save changes and exit. When your os is up go immediately to system restore: Click Start>all programs>accessories>system tools>system restore. Choose a date before your issue arose.>click next/continue and wait for system to restore. Reboot, and enter DOS environment once more and go to boot options and choose “Normal boot”>save changes and exit and you should be done. I hope this helped or at least gave you some ideas for further investigation.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
p.s. This suggestion is made with the assumption that you are versed at navigating around your pc. If this assumption is not correct, hit me back and I will explain in more detail on how to resolve your issue.
Oct 24, 2008 | HP Computers & Internet
Network computer freezing every day
It may need warmer clother, lol, JUST kidding. You may need to enter the dos environment and safe boot.
anaanymous
Oct 24, 2008 | Computers & Internet
My computer wont start up it keeps asking for ntoskrnl.exe it says its missing or may be corrupt i have no disc this is a different computer i cant seem to get anything to work are there any specific ways...
Hi little,
anaanymous
Oct 18, 2008 | Computers & Internet
My computer is not booting up, blank screen
This may or may not help, but, we have to start somewhere. Reboot, watch for the "enter setup option" (F? button). You in DOS environment now. Navigate to windows boot/startup options, choose safe mode, reboot. Once your os is up go immediately to -start>all programs>accessories>system tools>system restore. Choose a date option before problem existed and click next/OK. Sit back and wait for system to do its stuff. If by chance it boots up in safe mode after this exercise is completed you can go back into DOS and choose normal boot.
anaanymous
Oct 14, 2008 | Compaq Computers & Internet
Think i might have deleted some thing on my hpw1907 computer cause now it keeps telling me it cant find the environment option entered
[NOTE: You may need your (or any compatible, as in exact same version) Windows installation CD for the following to benefit you.]
Boot into Windows. CLICK Start>Run and type into the resulting dialog box, "sfc /scannow" (without the quotation marks).
NOTE: there is a space between "fc" and "scannow".
The System File Checker will scan your system files for any corrupt or missing system files and replace them with known good examples. It may ask you to insert your Windows installation CD into the optical drive.
When it finishes, reboot.
Jul 19, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
