FixYa.com
Tags:
Digital Cameras
Generic problem for all Digital Cameras
When i tURN IN THE
posted by WOOBIEWOO62 on Jul 13, 2008
When i tURN IN THE CAMERA IT FREEZEZ AND WHEN I TURN IT OFF THE LENSE WONT CLOSE AND IT SAYS LINSE ERRER
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 13, 2008
Not Rated (0)
t00nz
Rank:Guru Guru
Rating: 90%, 959 votes
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP Photosmart M425 Digital Camera HP Photosmart M537 Digital Camera Panasonic Lumix DMC-TZ3 Digital Camera Panasonic Lumix DMC-FZ7 Digital Camera Panasonic Lumix DMC-LZ2 Digital Camera Panasonic Lumix DMC-TZ1 Digital Camera Panasonic Lumix DMC-LS70 Digital Camera
Can you Help with these Digital Cameras problems?
Digital Cameras
after 5 seconds starts to
after 5 seconds starts to make... Answer This...
Digital Cameras
not recording
not recording Answer This...
Digital Cameras
Sony cybershot DSC-T2 will not
Sony cybershot DSC-T2 will not... Answer This...
Digital Cameras
My binoculars are not working
My binoculars are not working... Answer This...
Digital Cameras
can not open
can not open Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
