I have Marantz tuner & preamp AC500 conected to 5 amplifiers and speakers in 13 rooms. System was working great for 12 years. Now, I have to reduce the volume on Marantz preamp, from 12 to 9 to avoid amplifiers clicking (going to prevent mode). Am I correct that preamp output changed for some reason so that I can't play as loud as before?? Do preamp deritoriate with time?? What should I do??
  • 1,512 Answers
Hi Andrew49
If all the amps are going into protection mode, then the preamp may be pushing a DC component with the signal. This is a little serious,and should be investigated further. There may be some deterioration in the electronics of the preamp causing this. I would suspect a leaky transistor or bypass/coupling capacitor in the DC coupled output stages. should not be too hard fix for a good HiFi tech.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jul 13, 2008
Center channel dosen't work on 10 yr old marantz 500$ receiver. Should I just buy a new one?
I'd do some more investigation first. Have you determined if the amplifier for the channel works or if it's a preamp problem using the built-in speaker setup controls?
With this unit's great audio processing features you might be able to bypass a failed amplifier using the pre-outs and drive an external amp for the missing channel.
You could always just get a modest stereo amp (like a Carver M-100T and bridge it), or use the extra channel for another center speaker or a subwoofer, for example.
Aug 12, 2010 | Marantz SR5500 Receiver
I have a great, old but working well Marantz 4140 amplifier. do you know where I can find the meter illumination fuse lights? 8V 0.8A
yep! contact antique electronics in phoenix ariz they have supplied me for over 30 years with parts for all old vintage radios and amps
Jan 20, 2010 | Audio Players & Recorders
Adcom 7500, Adcom 5400(bi-amp), Marantz AV-9000, Dakiom HA103
Try just the power amp on ..nothing connected
no Dakiom thingy either. It's a matter of elimination. Start at the output device and work back. Keep the Dakiom out of the loop.
If there's hum with just the Adcom..then it's the ADCOM
Mar 25, 2009 | Adcom GFA-7500 5-Channel Amplifier
Marantz amp will not put out any sound
If it went out with no indications of trouble it's probably a fuse in the output circuit. It might be an out put amp but typically they let you know they're going bad with a little noise.
Feb 16, 2009 | Marantz Audio Players & Recorders
Sonance 275 no getting sound to speakers
The Sonamp 275 has Signal LEDs on the front panel, above the Volume pots. If signal is present at the RCA inputs, the Signal LEDs will be blinking.
Most likely, there isn't any line level audio signal coming from the receiver. Hook RCAs to Tape Output or MD output and check system using the Tuner which is an analog signal.
Jan 11, 2009 | Sonance SAT275 2-Channel Amplifier
Can I remotely control speaker outputs on the Marantz PM 8003?
HI...
You need an 8 ohm stereo "L-pad"
Try partsexpress.com
or
mcmelectronics.com
Dec 21, 2008 | Marantz Audio Players & Recorders
Stereo connection
Hi spanky
Sorry for the delays in getting back to you. Been busy here this week.
OK. to connect the 2275 to the 1152,there are 2 ways of going about this.
You can plug the pre- out of the 2275 to the power amp-in of the 1152. In doing this you are using the power amp section of the 1152 and the preamp functions of the 2275. Your other gear like CD player, tape deck and so on also plug into the 2275.
the other(better) way is to plug the pre-out of the 2275 into the tuner inputs of the 1152, leaving the volume at about 40% on the 2275 and use the 1152 as an integrated amp. This means you are using the 2275 as a tuner only. When you do this, you will need to use an RCA lead to jumper the pre-out/poweramp-in connections on the back of the 1152, and the 2275 ... L to L and R to R respectively.
I am still wondering why you want to use 2 integrated amps (each having a preamp and a poweramp section) The only real benefit the 2275 brings to your system will be tuner functions. You could just get a tuner and run the 1152 to be an ideal rig.
Let me know what your ideal setup you are wishing to build would have. Speakers, other gear like CD, tape deck, etc.
regards
robotek
Jul 23, 2008 | Audio Players & Recorders
Vintage Stereo Connection ???
Hi spanky
Where to start :) I am excited thinking about them :p You got 2 totally cool pieces of classic vintage gear there in the C2 and the Marantz. I have a C2 preamp myself (gathering dust but wont sell it cos its excellent) and the marantz would be totally cool to have(but then I am a little biased towards 70's vintage marantz). They ruled the roost in HiFi amps throughout that decade.
Because they are both integrated amps, you could use them as standalone systems with a pair of speakers, and just plug your favourite gear into them. If you just wanted to run up a nice sounding HiFi, I would sell the kenwood gear and just keep the Marantz. The Kenwood kr1100 has the edge in power, so if it is grunt you are looking for use that. Because vintage sound is all about stereo, you only really need an integrated amp to get great results.
the specs are
# Kenwood Model Eleven G (KR-11000G) Receiver
120W per channel min RMS, both channels driven, at 8 ohms from 20 to 20.000 Hz with no more than 0.03% total harmonic distortion.
Dynamic power output 440W at 4 ohms
Power bandwidth 5 Hz to 70.000 HZ
Frequency response 5 Hz to 100.000 HZ -1.5dB
Signal to noise ratio 115dB
The marantz is a little lower in power at 75rms a channel, but will have the sonic edge in vintage sound over the kr1100. Look them up on ebay and you will find that they do have some value to collectors and people seeking nice tone. There is an 1152 for sale here for AU$900
Best bet is to fire up the 2 integrated amps,and see how they are going. Run them for several hours to be sure there is no strange noises and crackles. Then decide if you want power or finesse.
You could also run both amps from the C2 preamp by connecting to the Amp in connections to the rear of the integrated amps.
happy to talk to you more about it, hit me with a Fixya if my advice was helpful to you. I would keep the marantz, use that and sell the rest and buy some nice speakers:)
regards
robotek
Jul 20, 2008 | Audio Players & Recorders
Marantz AC 500U
Hi
Sorry for the delay in getting back to you, you have an odd problem happening there, the pre-amp being the common denominator to the syptoms. Perhaps you could try reducing the attenuators to say 60% and retry at the same levels you used to use at the preamp. It is unlikely that there is a fault occurring that would increase the output of the preamp, more likely to be a DC component getting through. It could also be possible that the amps if all the same make and model have through over the period of installation developed the same fault.
There will have to be a common contributor to the symptoms. It is not uncommon for the same problem to affect a particular model at the same point of its life. Best approach and easiest to fault find it would be to change out the preamp with something similer to test the system and see what happens. At least tyouy will know where to start looking. Hope I have been able to help you, still happy to discuss it further. In the Free section our only reward is a FixYa ratings. Cheers
robotek
Jul 13, 2008 | Audio Players & Recorders
Connecting 2 stereo amplifiers using one as a preamp and the other as a booster
I would take from the tape out of the pioneer and feed into the aux input of the marantz you will then have to adjust the volume levels on each amp as required
Oct 28, 2007 | Audio Players & Recorders
106 people viewed this question
 Grubhead
Grubhead
